Author Topic: [IC] IKKI68 AURORA | A Gasket Mount Polycarbonate Kit - Update Dec. 20th  (Read 154984 times)
Offline treeleaf64
    • treeleaf64
Re: [IC] IKKI68 AURORA | A Gasket Mount Polycarbonate Kit
« Reply #50 on: Thu, 17 September 2020, 22:14:34 »
I will 64000% buy this.
This is a guaranteed buy from me.
Guaranteed. Guaranteed . Guaranteed
Thank you for making this. Thank you. Thank you. Thank you Thank you Thank you
If you can't tell, I'm very very excited. Good luck and i really hope this goes to GB
나무 잎
Everyone must pay the cat tax
Offline Techichi
« Reply #51 on: Fri, 18 September 2020, 08:07:59 »
That charcoal tho. Watching closely.
Offline HungerMechanic
« Reply #52 on: Fri, 18 September 2020, 14:16:10 »
I think the smart move is to go with purple and mint. Purple, because many people have requested pink or purple.
Mint, because it is relatively uncommon and beautiful in this case.
I also like Charcoal. Would go with many, many keysets.
Offline Pulsing Penguin
« Reply #53 on: Thu, 24 September 2020, 00:22:15 »
im in i reckon
Offline hottrout
  • I'd Hit Dat Key
« Reply #54 on: Thu, 24 September 2020, 04:54:41 »
Just wanted to check if ISO will be supported both on the PCB and the plate?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline dopzy
« Reply #55 on: Thu, 24 September 2020, 05:34:42 »
will split backspace be possible? at least on the solder version?
Bumping this question as I'm also wondering about split backspace support on the PCB  :)
Offline LASERman Projects
  • Soldering is my native language.
« Reply #56 on: Thu, 24 September 2020, 05:54:40 »
Split spacebar support is clearly mentioned as a Key Feature. Go read first post.
Sent from my Pixel 4 XL using Tapatalk
Offline dopzy
« Reply #57 on: Thu, 24 September 2020, 07:44:35 »
The question is about backspace, not spacebar. Supporting it on the PCB allow owners to opt into having a UNIX (or HHKB if you wish) layout with two 1U keys instead of one 2U backspace. Backspace itself is traditionally relocated to the row below (row above ANSI enter key). It's a great layout if you need constant access to various meta characters.
Sun keyboard with 2U backspace dropped in favour of two keys for meta characters:
HHKB:
« Reply #58 on: Thu, 24 September 2020, 07:54:45 »
My bad - misread on the smartphone. Sorry.
« Last Edit: Thu, 24 September 2020, 08:09:50 by LASERman Projects »
Offline dopzy
« Reply #59 on: Thu, 24 September 2020, 07:55:12 »
I just noticed that the plate does not support split backspace. Without there being explicit mention about different plate options, I guess the answer to split backspace support is "no".
Since this is an IC though, I'd like to ask if it's a possible option. I'm too new to this to know if it's possible to do a universal plate that supports both options. It should be possible to support the option of split backspace with one PCB though.
EDIT: I guess, worst case, open sourcing the plate file, and supporting split backspace on the PCB would allow owners to make their own plates with split backspace support.
« Last Edit: Thu, 24 September 2020, 07:57:01 by dopzy »
Offline dibstern
« Reply #60 on: Thu, 24 September 2020, 09:24:50 »
A gasket mount in my favourite layout at that price point? Damn, okay I’m in
Offline Degree04
« Reply #61 on: Thu, 24 September 2020, 23:09:52 »
Yes! Been craving a Bluetooth board recently
Offline neutralstate
« Reply #62 on: Tue, 29 September 2020, 09:14:12 »
will a badgeless version be available?
« Reply #63 on: Tue, 29 September 2020, 09:28:36 »
Same question was on Discord and they replied "no", although there is chance for "blocker badge".
Offline IBMweMissU
« Reply #64 on: Wed, 30 September 2020, 09:51:10 »
+1. Its been requested before on the OG Ikki too, would be great to have.
Offline lush_bunny
« Reply #65 on: Wed, 30 September 2020, 09:56:46 »
I am very interested in this. I will be filling up the IC form later when I get home, but may I ask:
HOW ARE YOU ABLE TO CHARGE THAT LOW A PRICE? FOR POLYCARB??
Offline nataliekill
  • if it's pink i'll probably buy it
« Reply #66 on: Wed, 30 September 2020, 13:56:52 »
Will buy for sure if there is a pink color!!
Offline ..//dexx
« Reply #67 on: Wed, 30 September 2020, 15:06:20 »
Wasn't able to join the original Ikki68 GB. Definitely in for this. Voted for Frosted Blue. I'm also interested if Atomic Purple becomes available. :cool:
Offline Rebral
« Reply #68 on: Wed, 30 September 2020, 15:32:15 »
Definitely in for either a frosted or clear blue as well! Will go great with OAyyy switches.
Offline Learis
« Reply #69 on: Fri, 02 October 2020, 15:30:04 »
Hi, I just wanted to ask if the hotswap also includes the split-spacebar, or if the split-spacebar is solder only?
Mend and Defend
« Reply #70 on: Mon, 05 October 2020, 09:06:12 »
sounds good man
Offline flyinggbuddha
« Reply #71 on: Mon, 05 October 2020, 09:21:13 »
Very interested. At that price point will probably grab the black and blue.
Offline yui
« Reply #72 on: Wed, 07 October 2020, 00:44:07 »
tbh i like pretty much all the colors, i just need iso... so if it will not be supported would it be possible to buy just the case with no pcb or plate?
Thanks
Offline kera13th
« Reply #73 on: Tue, 13 October 2020, 00:01:37 »
I really like the layout and bluetooth feature. I hope there will be a purple version.
Offline itsslim
« Reply #74 on: Tue, 13 October 2020, 07:04:36 »
Is there a reason why only PCB mount stabilizers and not the option for screw in?
Offline stein3
« Reply #75 on: Tue, 13 October 2020, 10:43:08 »
Screw-in is a type of pcb-mount stabilizer.
Offline xungc
« Reply #76 on: Thu, 15 October 2020, 01:39:01 »
Love the layout of the board. I would pick color mint or clear frosted. Got to say the mint look very nice. :)
Kind of wish the bluetooth PCB support VIA. :(
Would this be limited GB? I hope it unlimited, really like to get the board. Looking forward to more update.
« Last Edit: Fri, 16 October 2020, 11:59:49 by xungc »
Offline dstaar
« Reply #77 on: Sun, 18 October 2020, 22:21:27 »
wondering the same, will this be unlimited GB?
and, any idea about GB time? before Thanksgiving?
thx
Offline Rebral
« Reply #78 on: Sun, 18 October 2020, 23:38:12 »
thx
From their discord:
Offline dstaar
« Reply #79 on: Mon, 19 October 2020, 00:33:16 »
From their discord:
Thanks! Do you know if the gold badge will be optional or not?
Offline bronnn
« Reply #80 on: Mon, 19 October 2020, 01:50:20 »
Absolutely interested in this! Been looking for more 65% that are hotswap and bluetooth!
Offline Schmack
« Reply #81 on: Mon, 19 October 2020, 16:09:53 »
Definitely looking forward to ordering a couple in differing colors if that price estimate is accurate! This is gonna be neat
Offline crash822
« Reply #82 on: Tue, 20 October 2020, 19:47:55 »
Definitely getting this.
Offline Datastream
« Reply #83 on: Wed, 21 October 2020, 02:27:38 »
Looks really cool!
Offline ArashiNishi
« Reply #84 on: Wed, 21 October 2020, 23:47:13 »
Really nice and great pricing point!!
I have some questions:
Typing angle?
The PCB has RGB support and ESD protection?
Can be provided a video of the software used to configure the bluetooth PCB?
Offline IorekByrnson
« Reply #85 on: Fri, 23 October 2020, 19:41:03 »
Will definitely be buying this. Will it be an unlimited GB?
Offline Rebral
« Reply #86 on: Fri, 23 October 2020, 19:56:30 »
From their discord they said it'll be soft capped, but they've yet to decide how many.
Offline ..//dexx
« Reply #87 on: Sun, 25 October 2020, 06:53:53 »
I hope you guys have a limit to how many kits one individual can buy. Because it looks like there will be a soft cap for orders and people are voicing their desire to buy multiples.
Offline treeleaf64
    • treeleaf64
« Reply #88 on: Sun, 25 October 2020, 09:23:18 »
I mean this is injection molded right? So a lot cheaper than CNC
expect a lot of units or multiple runs
Offline dankravioli
« Reply #89 on: Tue, 03 November 2020, 08:44:39 »
Would take this over the NK65 EE any day
Offline resetLetki
« Reply #90 on: Wed, 11 November 2020, 14:06:09 »
Definitely in for the Bluetooth Version!
Offline MrBIGEURO
« Reply #91 on: Wed, 18 November 2020, 10:43:40 »
Yes. Interested. I'm so happy to see more price friendly boards  :thumb:
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« Reply #92 on: Wed, 18 November 2020, 10:46:52 »
Updated details!!!
Offline Learis
Re: [IC] IKKI68 AURORA | A Gasket Mount Polycarbonate Kit - Update Nov. 19th
« Reply #93 on: Wed, 18 November 2020, 15:24:50 »
Super impressed with all the options you guys are offering and at such a low price point, especially for gasket mounting! Even a pauper can type like a prince!
Mend and Defend
Offline Ckeeb
    • MELETRIX
« Reply #94 on: Mon, 23 November 2020, 08:37:08 »
Yes, we can have multiple runs of different colors in the future. But this time, we will have another surprise to announce :)
Offline kk73715
  • Why are you even reading
« Reply #95 on: Mon, 23 November 2020, 10:52:24 »
Hope the price point can be maintained
Glwic
Offline TopreMoon
« Reply #96 on: Mon, 23 November 2020, 19:42:41 »
Is Bluetooth limited to the fixed layout PCB only? I'm mainly interested in the split backspace layout, but would be sad if there is no BT support.
Offline IBMweMissU
« Reply #97 on: Tue, 24 November 2020, 08:18:35 »
^ this
Offline SirKhamenman
« Reply #98 on: Fri, 27 November 2020, 08:41:39 »
Im interested especially due to the pricing. Will keep an eye on this IC :)
Offline Ckeeb
    • MELETRIX
« Reply #99 on: Mon, 30 November 2020, 03:43:56 »
Yup, only QMK version will have multiple layouts, sorry about this.
