Author Topic: Why Cherry, Why???  (Read 2799 times)
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
Why Cherry, Why???
« on: Fri, 18 September 2020, 11:00:39 »
[Rant]
As I start to go deeper down the keyboard rabbit hole, I find myself wishing that Cherry had made one very important design decision years ago. Instead of the stupid 2U stabilizer, why didn't they just use two switches under the 2U keycap and only wire up one? That would make it so much simpler to have flexible layouts under the numpad for instance. That is pretty much what IBM did with the Model M barrel plate and it seems like a much better way to get the medium length keys stabilized. And then we could have all sorts of fun trying to figure out which linear switch makes the best stabilizer.....
[/Rant]
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Re: Why Cherry, Why???
« Reply #1 on: Fri, 18 September 2020, 11:18:05 »
what IBM did with the Model F and M barrel plate
IBM got pretty much everything right back in the day, notable exceptions were the brittle plastic in the F cases and melted rivets in M assembly.
- D Trump 2026-10-24
« Reply #2 on: Fri, 18 September 2020, 11:37:34 »
I'm not sure Cherry MX switches are stable enough for using a dummy switch though. Most designs that use a dummy switch under a key have it bind on some key presses.
I think the best way is to do like Ericsson switches: with a real and a dummy switch and a stabilising rod between them. https://deskthority.net/wiki/File:Ericsson_RMD_973_series_stabilizers.jpg
I think some older Model Ms actually did have a stabilising wire as well, but that it got removed after IBM had noticed that it worked remarkably well without one.
« Last Edit: Fri, 18 September 2020, 11:39:47 by Findecanor »
Offline mcmaxmcmc
« Reply #3 on: Fri, 18 September 2020, 11:48:49 »
Imagine bolt/screw-modding an M122 because you want to add an extra key on the numpad or whatever...
You gotta put that flipper in somehow.
Imagine having to cut plastic to add compatibility for keys sized between integer units.
I'd rather just desolder, thank you.
The Cherry stabilizers also allow for more equal stabilization because the switch and stabs are centered, so they got that going for them.
Putting in a dummy switch is what Signature Plastics did for some of their POS caps, so it's not like it hadn't bern done before.  I believe the very early custom numpads also require these POS-2u keycaps (or, you know, 2x 1u's).  Cherry BAEs also use this type of stabilization, and it works okay... not great though.
« Reply #4 on: Fri, 18 September 2020, 11:59:48 »
I have immediately dismantled every 122-key IBM terminal that I have ever gotten in order to put it into ANSI layout.
It is not even anything that I think about, it is just a given.
Cutting 2 metal half-circles to make room for Alt keys on an F AT, now that is a bit more advanced. But it goes to show, yet again, how forward-thinking IBM used to be.
Offline treeleaf64
    • treeleaf64
« Reply #5 on: Fri, 18 September 2020, 15:53:48 »
2u stabilizer good
What's the problem with it. It looks good and it works good too. More layouts are supported and it's easier to change them out
Everyone must pay the cat tax
Offline Lanrefni
« Reply #6 on: Sat, 19 September 2020, 19:01:32 »
I use 2u POS keycaps on my BFO-9000,clipped the pins and cut the springs in half on 4 MX blacks and now they make a great dummy switch.
Offline lakeboredom
« Reply #7 on: Sun, 20 September 2020, 04:39:36 »
You'd have to use half-weight springs in each switch for them to feel right, and then certain tactiles wouldn't even function hah.
Offline Leslieann
« Reply #8 on: Sun, 20 September 2020, 07:27:17 »
why didn't they just use two switches under the 2U keycap and only wire up one? That would make it so much simpler to have flexible layouts under the numpad for instance. /quote]
Nothing stopping it from being done, however I do agree with Findecanor in that they may not really be strong enough.
Considering how long so many have lasted I'd still say they got it right.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
