Author Topic: [IC] Fuji65, meet you by the mountain  (Read 177364 times)
Offline freather
    • Keyspensory
« on: Sat, 19 September 2020, 18:21:07 »
Final Update b4 GB:
PCB: Fixed standard ansi solder and hotswap layout
GB Date: Mar.8th
Vendor:
AS: iLumKB
EU: mykeyboard.eu
NA: Deskhero
Pricing: SE Starting from $285 USD, FE starting from $359 USD
Badge selection: pick one from sakura or character
Color: Ewhite, black, grey blue, pink
Configuration: (every color has fixed accessory colors, check discord for detail)
SE: alu case, alu weight, alu backplate, alu badge
FE: alu case, brass weight, stainless steel backplate, brass badge
all brass are pvd gold, stainless steel will be pvded with mirror finish
Extra Option:
alu badges in 4 colors in both pattern, carbon fiber backplate, foam, pcbs
Proto Stream: twitch.tv/freatherlee, Apiary and Hamaji Neo will also doing a stream/video on Fuji
update: international gb will be unlimited within limited time. specific options are still figuring out. It will likely happen around Feb ish. Confirmed vendor is iLumKB and Deskhero only at this moment
Fuji Proto Pics are here! More Pics you can find through this link: https://imgur.com/a/ZIQmQ7u
Note that since this is a fake build, the gap between keycaps and gaps between top and bottom case are not accurate
Note: Progress on the proto is in our discord mod channel! Make sure you add the roles to get updates!
Shoutout to JTk for teasing the keyboard! JTK Nightsakura by Rifen can be found here: https://geekhack.org/index.php?topic=107748.0
TL, DR:
Name: Fuji65 by NightSakura
Designed by CMM.Studio Mellperbia and Rifen
Kudos to TGR!
Price: low spec: around 280 USD, high spec: around 350 USD
Case Material: 6063 Aluminum/PC
Case Color: Ano color: greyish blue, red, deep green, black, silver, pink, e-white (extra charge), PC
Plate Color: same color from the case color
Weight Material: Alu/Brass, alu color choose from case color (not e-white or pc colors)
Backplate Material: Mirror Carbon Fiber/Aluminum/ Mirror Stainless Steel, Aluminum color is same as case color (not e-white or pc colors)
Badge material: Aluminum/Brass, choose one badge from character/flower, can purchase extra badge
Badge Color: Alu badge color same as case color (not e-white or pc colors)
Mount type: Top Mount
Layout: 65% ansi fixed
Typing degree: 6.5
PCB: QMK+VIA
Confirmed Proxy: iLumkb
Anticipated GB method: limited
GB format? Unsure.
Current progress: proto near to finish. China only GB starts soon. Intl GB IC stage
Anticipated GB time: somewhere around CNY
Low Spec: Alu case, alu plate, alu badge, alu/carbon fiber backplate, alu weight, PCB
High Spec: Alu case, alu plate, Brass badge, mirror stainless steel backplate, brass weight, PCB
Designed by Mellperbia and Rifen, Renders done by Mellperbia and Rifen.
Links:
Imgur:  https://imgur.com/a/q9XCdoc
Discord: https://discord.gg/jbcaaTy
Instagram: https://www.instagram.com/cmm.studio.social/
IC form:  https://docs.google.com/forms/d/1GafyOYM1LWOjU0Wdzl-23NcCWeH99jfuA6fPDHpQXjo/edit
Hi guys, this is CMM.Studio Freather again. It is the third time greeting you guys this week, and we are dropping one last IC for the week.
As many of the community member wondered, what is the keyboard on the Rifen JTK NightSakura’s IC renders, and how to get it.  Well, after a long wait, we are happy to release the official IC for Fuji65 for international GB.
But hold on a second first, let me introduce NightSakura. NightSakura is one of our studio members, and he is active under same name in Chinese Keyboard community. He owns the right for this kit. It is not included in our studio’s line up.
The original concept behind the kit is pretty simple. Nightsakura has always love the Japanese element, and felt perhaps putting it on the keyboard would look lit. Therefore, a Japanese themed Fuji65 was born.
On the design side, the general theme is simplicity, with sakura flower badge changeable in character and flower. (Cuz his name is sakura!)
The backside consists of inert method weight. Kudos to TGR! To accompany the name of the kit, we designed a Mountain Fuji shaped back plate to fit the keyboard scheme.
 Without further speaking, here are some confirmed info:
Kudos to TGR!
Typing degree: 6.5
PCB: QMK+VIA with the help from iLumKB
GB format? Unsure.
Anticipated time: 1-2 month after China GB ends.
Links:
Discord: https://discord.gg/ugYpvPNr74
Feel free to leave a comment on your thought or join our discord discussion
Hope you all have a great day!
« Last Edit: Sat, 02 October 2021, 12:25:30 by freather »
Offline purryoverlord
Re: [IC] Fuji65, meet you by the moutain
« Reply #1 on: Sat, 19 September 2020, 18:21:28 »
Here for it
Offline IMZO
  • Matrix shill, and TKL WKL Lover
Re: [IC] Fuji65, meet you by the mountain
« Reply #2 on: Sat, 19 September 2020, 18:22:05 »
yes!
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Ireojimayo
  • Yo dayo
« Reply #3 on: Sat, 19 September 2020, 18:22:32 »
Super Excited for this, hopefully it gets a Canadian vendor!!!!
Offline powwu
    • Discord
« Reply #4 on: Sat, 19 September 2020, 18:24:03 »
I like the weight design, it's quite clean. GLWIC
Offline IOVERCALLHISTIOCYTES
« Reply #5 on: Sat, 19 September 2020, 18:24:24 »
How limited is limited? Raffle or FCFS?
Offline Coloured
« Reply #6 on: Sat, 19 September 2020, 18:27:06 »
So glad to see this with international availability! Count me in on this! I wish the light blue was still in the cards :(
« Last Edit: Sat, 19 September 2020, 18:46:53 by Coloured »
Offline jiggyboybrian
  • Darling!
« Reply #7 on: Sat, 19 September 2020, 18:29:01 »
Im getting one forsure!
Offline OtherAndrew
« Reply #8 on: Sat, 19 September 2020, 18:35:35 »
what's that pink/grey keyset tho
Offline JoltFX
« Reply #9 on: Sat, 19 September 2020, 18:36:17 »
Absolutely in for this! Looks beautiful! Love the polished metal back with the logo
Offline freather
    • Keyspensory
« Reply #10 on: Sat, 19 September 2020, 18:40:13 »
JTK nightsakura designed by Rifen
Offline Deadlcck
« Reply #11 on: Sat, 19 September 2020, 18:41:16 »
Drippy board. GLWIC :)
Offline finalarcadia
« Reply #12 on: Sat, 19 September 2020, 18:42:15 »
This is it chief
Sent from my Pixel 3 using Tapatalk
Offline slightlyinjured
« Reply #13 on: Sat, 19 September 2020, 18:43:48 »
Amazing!
Offline JoltFX
« Reply #14 on: Sat, 19 September 2020, 18:45:01 »
Looked at Imgur link and saw no Red color that’s listed. Any chance to get pics of all color options?
Offline shoteve
« Reply #15 on: Sat, 19 September 2020, 18:45:09 »
Any images of low spec backplate? (also what options of badges do we have?)
Offline chaoticgood
« Reply #16 on: Sat, 19 September 2020, 18:46:59 »
Low spec backplate is the carbon fibre and the badges are between the kanji or the cherry blossom
Offline freather
    • Keyspensory
« Reply #17 on: Sat, 19 September 2020, 18:49:19 »
will see if we will get any red render or red proto if possible
Offline Tamaki
    • @pump_upp - best crypto pumps on telegram !
« Reply #18 on: Sat, 19 September 2020, 18:50:39 »
Here for that weight design. It's so clean uwu.
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #19 on: Sat, 19 September 2020, 19:01:25 »
What will be the format and units for the gb?
Offline Kinesiologist
« Reply #20 on: Sat, 19 September 2020, 19:40:00 »
beautiful, been following this board for a while now, looking forward to hearing more :D
Offline The.Ryan.Gamer
« Reply #21 on: Sat, 19 September 2020, 20:45:12 »
Thanks Freather for posting here, Appreciate your updates on Discord too man.  :thumb:
Rifen, you may not be here in GH, but i hope this reaches you.
Please make this unlimited (and 1 time deal if you want) so more people in this hobby will enjoy this beautiful work.
I mean FCFS, Raffles and Limited Board release = Flippers Screaming in Joy. Though this seems to be the thing right now if you wanted to make a quick name for yourself quick.
« Last Edit: Sat, 19 September 2020, 21:31:39 by The.Ryan.Gamer »
Offline SpinningHook
  • "I can't know how to hear anymore about tables!."
« Reply #22 on: Sat, 19 September 2020, 20:48:57 »
Really digging the carbon fiber back plate.
"Brevity is the soul of wit."
Offline meiosis
  • Time
« Reply #23 on: Sat, 19 September 2020, 20:50:15 »
i want in..
Keyboards:
Aripeko TKL
Offline JoltFX
« Reply #24 on: Sat, 19 September 2020, 20:51:22 »
Thanks Freather for posting here. Fuji65
Night Sakura, you may not be here in GH, but i hope this reaches you.
I mean FCFS, Raffles and Limited Board release = Flippers Screaming in Joy. Thought this seems to be the thing right now if you wanted to make a quick name for yourself quick.  :))
Agree
Offline sirieous
  • help
« Reply #25 on: Sat, 19 September 2020, 21:05:11 »
This pricepoint looks really tempting. Will be keeping my eye out
Offline aeham
« Reply #26 on: Sat, 19 September 2020, 21:25:37 »
i'm READY 😩
Offline Vinchenzol
  • I'm new please don't hurt me
« Reply #27 on: Sat, 19 September 2020, 21:35:52 »
Been in Discord since day 1  ;D
Offline idolindisguise
« Reply #28 on: Sat, 19 September 2020, 21:37:10 »
Raffle please ! lol
Offline zoo
    • zoo
« Reply #29 on: Sat, 19 September 2020, 23:18:13 »
Curious if this and Saka 68 are going to be running at the same time. Seems like you're an established keyboard maker, but still...
Offline kulaan
« Reply #30 on: Sat, 19 September 2020, 23:21:21 »
Ohhh. This looks really good. What’s the front height?
Offline aaronlau
« Reply #31 on: Sat, 19 September 2020, 23:23:54 »
I'm so hyped for this. So in.
Offline TechTale
« Reply #32 on: Sat, 19 September 2020, 23:27:35 »
hot swap?
Offline jubei
« Reply #33 on: Sun, 20 September 2020, 01:30:45 »
Offline blank++
« Reply #34 on: Sun, 20 September 2020, 02:53:44 »
in for this one :>
Offline Ponizu
« Reply #35 on: Sun, 20 September 2020, 03:08:05 »
Count me in!
Offline binepad
« Reply #36 on: Sun, 20 September 2020, 03:32:22 »
Nice
Offline PotatoTM
« Reply #37 on: Sun, 20 September 2020, 05:28:52 »
Glad to see an intl GB after all :), looking forward to it!
Offline VagueOrigin
« Reply #38 on: Sun, 20 September 2020, 06:30:34 »
Very interested, i thought I was done
Sent from my SM-G975U using Tapatalk
Offline CookieFlow
« Reply #39 on: Sun, 20 September 2020, 07:21:28 »
Looking forward to it !
Offline peaceperfection
« Reply #40 on: Sun, 20 September 2020, 08:54:22 »
Oh man, limited GB again. I was hoping for an unlimited GB.
Offline Draxion
« Reply #41 on: Sun, 20 September 2020, 12:27:15 »
I'm in.
Offline JoltFX
« Reply #42 on: Sun, 20 September 2020, 12:28:18 »
Check the Discord there’s a vote going potentially deciding for unlimited vs limited. Get in there and vote
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #43 on: Sun, 20 September 2020, 19:19:24 »
100% in!
Offline bball2
« Reply #44 on: Sun, 20 September 2020, 19:49:04 »
Voted! Also lots more information in the discord / pictures and videos of the prototype for anyone interested.
Offline Rickyygee
« Reply #45 on: Sun, 20 September 2020, 20:44:37 »
I'm so excited to see this come international. So keen to buy from Aussie!
Offline atlanticise
« Reply #46 on: Sun, 20 September 2020, 21:40:53 »
mmmm this looks so good!
Offline whitemamba
« Reply #47 on: Sun, 20 September 2020, 23:31:32 »
Please consider unlimited international gb
Offline JoltFX
« Reply #48 on: Sun, 20 September 2020, 23:32:06 »
Make sure you vote for it in the discord mod channel then ;)
Offline Auxo
  • Formerly CJD_Anthony
« Reply #49 on: Mon, 21 September 2020, 00:01:31 »
Woot in
