Author Topic: Any high-end, full-size, hotswappable boards for sale?  (Read 2892 times)
Offline zslane
« on: Wed, 23 September 2020, 11:56:31 »
Looking for recommendations for high-end, full-size (104 or 108 keys), hotswap keyboards.
(And by "high-end" I mean something more premium than the GMMK.)
Offline Krelbit
  • Switchmod.net
    • Switchmod
Re: Any high-end, full-size, hotswappable boards for sale?
« Reply #1 on: Wed, 23 September 2020, 12:33:31 »
High end fullsizes are already hard enough to find without hotswap.
Offline Leslieann
« Reply #2 on: Wed, 23 September 2020, 21:27:58 »
And hot swap isn't very reliable.
Kailh hot swaps are rated for 100 insertions (on average), which may sound like a lot but many times just pulling a keycap will yank them out. If you play with switches much, you will go through a lot of those pretty fast, and yes, odds are you will at some point settle on a switch, but by then how many have you wasted? The Kailh are also extremely hard on the pcb, being bottom mounted and SMD*. Unless you view several hundred bucks as disposable I wouldn't get them on anything you plan on keeping long term.
*Note these issues mostly apply to Kailh and there are alternatives but those are the most common you will find on a pcb.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline zslane
« Reply #3 on: Thu, 24 September 2020, 11:04:53 »
I hear you. I had such a keyboard (AoPo 108), and it worked for a while, but installing new switches caused several of the switch transistors to become detached from the PCB, rendering the board useless to me.
All I wanted was a full-size keyboard with Kailh Box silent brown switches, but since nobody sells a full-size with that switch as an option, I decided to try hotswap. I guess MX-compatible switches just aren't my destiny.
Offline Leslieann
« Reply #4 on: Thu, 24 September 2020, 22:22:21 »
Like I usually recommend...
Get a full size GMMK. Look, it's not a $500 board, but throw good stabs on it, bandaid mod, lube, your switches and a magnetic cable and I guarantee you will be surprised at how good it actually is. And when the sockets screw up you will be able to replace it for $70, you can barely buy a good PCB for that. If you do find a good high end full size you're still out little more than a spare pcb.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #5 on: Thu, 24 September 2020, 22:40:45 »
+1 on the GMMK
I was going to go that route, but a $25 e-bay coupon led me astray and I picked up a open box Reddragon K556. I wrote a short review in this thread: https://geekhack.org/index.php?topic=108433.msg2955688#msg2955688
The short answer is, the Reddragon can be made to work, but the GMMK would have been easier.
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
