Author Topic: milky vs normal Gateron  (Read 41880 times)
Offline yui
« on: Thu, 24 September 2020, 01:59:03 »
Browsing switches i found that there existed milky Gateron and normal Gateron switches, is there any advantages to going with milky other than more light diffusion?
Thanks in advance.
Offline Sup
Re: milky vs normal Gateron
« Reply #1 on: Thu, 24 September 2020, 02:50:36 »
This is from my experience but Milky Gateron seems better then your normal with clear top in sound. But you should get the ones with black bottom and milky tops. The black bottom is better then the milky bottoms in smoothness.
current
Coming soon
Offline hpetrovski
  • Osum
« Reply #2 on: Mon, 12 October 2020, 13:48:27 »
Thanks in advance.
Generally you want to avoid milky bottom housings as they're very scratchy. Best you can get stock is a black bottom + milky top, or if you can't get hold of those, black bottom + clear top.
Offline yui
« Reply #3 on: Tue, 13 October 2020, 00:50:25 »
i was wondering because the price delta is pretty small and the plan was to build a mechanical keyboard as a gift for a friend, so if milky was better might as well but it seems that given that the one i saw were the full milky i should avoid them?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Tue, 13 October 2020, 02:43:22 »
this dude is trippin, milky housings are v smooth
Offline Darthbaggins
  • PC Cannibal
« Reply #5 on: Tue, 13 October 2020, 09:43:54 »
So far using the Gat Yellows I have in one of my boards (Milk top and black bottom), have been smooth as hell and compete w/ my Gat Ink Black v1's (both sets are lubed 205g0/105 on the springs).  I've noticed it's a mixed bag on which is better and I'm sure some batches are better than others.
Offline hong@RebultKeyboards
  • Rebult Keyboards
    • Rebult Keyboards
« Reply #6 on: Tue, 13 October 2020, 11:19:08 »
Smoothness and scratchiness negligible once u lube it, although it is true that milky bottoms are bit more scratchy than black bottoms. Slightly different upstroke sound tho due to the top housing. Clear top sounds higher pitch than milky top. Milky top sounds just slightly deeper
  • Rebult Keyboards
    • Rebult Keyboards
« Reply #7 on: Tue, 13 October 2020, 11:21:29 »
Once u put it on a board typing on it the difference is really negligible.
Offline treeleaf64
    • treeleaf64
« Reply #8 on: Wed, 14 October 2020, 10:33:45 »
I use the black top black bottom. and it is good
Everyone must pay the cat tax
Offline yui
« Reply #9 on: Thu, 15 October 2020, 07:04:34 »
where did you find a black top gateron?
  • PC Cannibal
« Reply #10 on: Thu, 15 October 2020, 08:43:34 »
A mystery appears:
Offline wholypantalones
  • text and icon mods plz.
« Reply #11 on: Thu, 15 October 2020, 09:43:12 »
Also Gateron silents.
Offline treeleaf64
    • treeleaf64
« Reply #12 on: Thu, 15 October 2020, 09:44:38 »
Offline yui
« Reply #13 on: Thu, 15 October 2020, 09:51:41 »
I knew they existed but did not saw them on sales at any vendors i am used to, being in europe novelkey is not the one i am not used to shop at, and i am not yet used to shopping on taobao either, as i do not understand chinese, and google translator does its best but is not quite good enough yet often
Offline treeleaf64
    • treeleaf64
« Reply #14 on: Thu, 15 October 2020, 11:48:26 »
My friend yui
It's fine if you use full milk shell if that's available. just lube it well and you should not have to worry about the scratch feeling. You can always just cherry pick the ones that are not scratchy.
