Author Topic: Is the Compaq RT101 keyboard Mechanical?  (Read 5448 times)
Re: Is the Compaq RT101 keyboard Mechanical?
« Reply #1 on: Fri, 25 September 2020, 15:05:52 »
No, it's a rubber-dome keyboard made for Compaq by NMB. Very dirty also.
A good auction should have a picture of the label on the back side, so that you could look up the model number or at least FCC ID to search for.
« Last Edit: Fri, 25 September 2020, 15:07:24 by Findecanor »
« Reply #2 on: Fri, 25 September 2020, 16:31:52 »
I used to live and work near rawko, depending on what route I took I passed it on the way to the office.
They are keenly aware of the value of old keyboards and you are not likely to find a bargain there like I did about 8 years ago when I bought 4 IBM Model F 122-key terminals (completely trashed, filthy, and incomplete) for $85.
- D Trump 2026-10-24
Offline Leslieann
« Reply #3 on: Fri, 25 September 2020, 22:27:16 »
NMB Rubber Dome,
Without seeing the bottom or with keys removed it's hard to say if it has sliders or not (fccid will say memb if it has sliders). With sliders is actually really good, comparable with many mechanicals. That one even if it has sliders is pretty old and beat.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
