Author Topic: [IC] Southpaw75v2 - Seamless, Southpaw, Gasket  (Read 29329 times)
Offline HolySwitch
    • HolySwitch
« on: Sat, 26 September 2020, 19:06:04 »
Southpaw75v2
A Collaboration between Bitmap Studios and HolySwitch - A Seamless, Southpaw, Gasket-Mounted 75%.
Join the discord for the most up-to-date information!
Make sure to join Bitmap Designs' discord as well for more the Southpaw75v2, Alpine65 and more to come.
You can also find HolySwitch's instagram here and Bitmap Studios' here.
The Southpaw75 is back for its second version, boasting a fresh aluminum case, multiple layouts, and a sleek brass weight. (please note 0 key on numpad is incorrectly located on KLE and renders, it has since been moved to the right)
Colors
Navy may not be accurate - we have protos OTW for accurate colors.
Plate/Weight Options
- Brass Plate
- FR4 Plate
- Limited (25 units) First Edition stainless steel polished weights - Please see update in 1st comment.
Internal Features
The Southpaw75v2 offers a 3.5mm pcb-plate PORON foam to allow for the ultimate sound, with gaskets elevating it further.
The PCB
- Multiple layouts (pictured below)
- ESD Protection
- USB-C
- QMK & VIA Support
More Renders
Special Thanks
Bitmap: For doing this collab with me, the speed, beautiful design, and elegance of your work.
DrewKeys: For doing the PCB work, helping with the PCB questions and ordering.
KelvinHall05: For allowing me to vendor the USA first sp75 and obviously for you creating the first sp75, and allowing us to continue the board into its future.
Current Timeline
Ordering case, weight, PCB, prototypes today.
We will be ordering screws, foam, gasket and packaging prototypes in the upcoming days / weeks
Streamers
AndyV & MechMerlin have confirmed build streams!
Please check the 1st comment for updates / edits.
« Last Edit: Sat, 10 October 2020, 02:14:19 by HolySwitch »
Offline HolySwitch
    • HolySwitch
Re: [IC] Southpaw75v2 - Seamless, Southpaw, Gasket
« Reply #1 on: Sat, 26 September 2020, 19:06:37 »
Edit: 10/5/20
We plan on removing the brass weight and baking the paw engraving into the aluminum backing.
Two main reasons for this - 1. board will already be heavy due to it's size,
2. We really want this to be as cheap as possible - that is what the southpaw75v1 was all about, and we want to keep that trend for this board as well.
Let us know your thoughts!
« Last Edit: Sat, 10 October 2020, 02:14:40 by HolySwitch »
Offline NuNuDuck
« Reply #2 on: Sat, 26 September 2020, 19:09:10 »
yes plz...first hehe
Code: [Select]
Offline sartori24
  • hello
« Reply #3 on: Sat, 26 September 2020, 19:09:27 »
looks really good! any chance for half plate?
yikes
Offline OXY-Gen
« Reply #4 on: Sat, 26 September 2020, 19:10:07 »
Nice
Offline Bitmxp
  • I’ll take 12
    • Bitmap Studios
« Reply #5 on: Sat, 26 September 2020, 19:12:39 »
wooot  :thumb:
Offline bigern302
« Reply #6 on: Sat, 26 September 2020, 19:13:03 »
Where are we supposed to get 1.75u question mark?
Offline headphone_jack
« Reply #7 on: Sat, 26 September 2020, 19:13:38 »
Reserved! Any idea about a price, considering this seems to be much more high quality than v1?
Offline ngud
« Reply #8 on: Sat, 26 September 2020, 19:29:16 »
per the Discord, it's TBD $300-500, but with a budget FR4 version like rev1 as an option that'll be under $75.
Offline Bitmxp
  • I’ll take 12
    • Bitmap Studios
« Reply #9 on: Sat, 26 September 2020, 21:02:05 »
We're still working on the price :). More details coming soon!
Offline reminbee
« Reply #10 on: Sat, 26 September 2020, 21:09:39 »
interested!
Offline wawa
« Reply #11 on: Sat, 26 September 2020, 21:16:31 »
Man, I’m still waiting for v1 to ship and you go and drop this on me?
Offline SekaiJutsu
    • GeekHack
« Reply #12 on: Sat, 26 September 2020, 21:22:48 »
Another Southpaw has joined the fray! Love that you guys are doing this board! Best Layout!!!
Offline Deadlcck
« Reply #13 on: Sat, 26 September 2020, 21:28:40 »
Looks good. The engrave on the weight is super cute. GLWIC!
Offline Suavity
  • Smile more! 🙂
« Reply #14 on: Sat, 26 September 2020, 21:54:16 »
If this were to ever come with a split space bar design, this would be the most end game southpaw board!! Nevertheless, great job on the design  :thumb:
Offline KeebOnMe
« Reply #15 on: Sat, 26 September 2020, 22:02:23 »
Looks great!
Will the pcb from V1 be compatible with V2? https://holyswitch.co/products/southpaw75
If so, I would be down for an option just for the case and internal gasket system!
Offline Deadlcck
« Reply #16 on: Sat, 26 September 2020, 22:04:28 »
Looks great!
No, the v1 PCB won’t be compatible, unfortunately.
Offline wawa
« Reply #17 on: Sat, 26 September 2020, 23:01:43 »
Looks great!
That’s super disappointing. I can only hope that v2 is relatively cheap to justify buying it after already buying v1
Offline HolySwitch
    • HolySwitch
« Reply #18 on: Sat, 26 September 2020, 23:21:41 »
The reason this is, is just for a better board.. It supports multiple layouts, has an added blocker, a daughter board, and different dimensions to fit.
The v2 is supposed to be different, having the same PCB limits us. However, the v1 is open source and people are already making 3d printable cases for it in the southpaw75 discord.
Looks great!
Offline Dubsadan
« Reply #19 on: Sun, 27 September 2020, 19:01:29 »
Was a pleasure to be in the southpaw75v1 GB - good team behind this.
Offline R4UDO
« Reply #20 on: Mon, 28 September 2020, 10:21:21 »
Wow nice surely interested and following this!
Offline Bitmxp
  • I’ll take 12
    • Bitmap Studios
« Reply #21 on: Tue, 29 September 2020, 16:02:33 »
Be sure to join our discord :)
Offline soombody
« Reply #22 on: Wed, 30 September 2020, 18:14:43 »
Great to be able to catch this one
Offline Wyant93
« Reply #23 on: Sat, 03 October 2020, 21:21:18 »
Can't wait, been drooling for a southpaw. Getting in on my first gb for this one.
Offline badabingbadaboop
« Reply #24 on: Mon, 12 October 2020, 22:53:13 »
100% interested! This is quite literally my dream keeb.
Offline nihonjam
« Reply #25 on: Fri, 16 October 2020, 20:39:20 »
Love my V1 and in for this V2.
Great that you are trying to keep the price low and have also added some angle. Looking forward to it.
Offline Donosir
« Reply #26 on: Fri, 23 October 2020, 10:47:16 »
I had no idea this was even possible. But as someone who has never used their numpad due to lack of dexterity I am super excited to get this set.
Offline oilpapers
« Reply #27 on: Fri, 22 January 2021, 19:37:24 »
Would love to see an F-row on something like this.
Offline genevatypes
« Reply #28 on: Fri, 26 February 2021, 23:12:07 »
Really interested in this. Any updates?
Offline rowie
« Reply #29 on: Sat, 27 February 2021, 12:54:53 »
Love this. Would love to see a Winkeyless with blocker version. I’ve yet to see one for southpaw boards.
Offline theomaniacal
« Reply #30 on: Wed, 10 March 2021, 10:02:57 »
Per the HolySwitch Discord, there was a delay on this project but it's apparently very much alive! Really excited.  :D
