Author Topic: [IC] VANQUISH65 by Geon - The Tray mount (20-10-23 update  (Read 166394 times)
Offline tactilesbad
Re: [IC] VANQUISH65 by Geon - The Tray mount (20-10-23 update
« Reply #150 on: Tue, 06 June 2023, 09:46:26 »
Thank you Geon! We appreciate everything you've done and continue to do. You are really a fantastic part of this hobby.
I personally want to express the exact same feeling
Offline Gondolindrim
    • My GitHub
« Reply #151 on: Tue, 06 June 2023, 12:39:21 »
Vanish when
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline hackr
  • clack n hack
    • hackrlabs
« Reply #152 on: Tue, 06 June 2023, 15:56:14 »
Out of curiosity and completely unrelated, what keycaps are those 👀
Sometimes it's an UwU, sometimes it's an OwO, most times it's a T_T ykwim?
Offline Fraaaan
« Reply #153 on: Wed, 07 June 2023, 11:53:03 »
Geekark Triangle
Offline nessMINI
« Reply #154 on: Thu, 22 August 2024, 07:28:56 »
Geon never made a 65 percent board? It's too bad... its my favorite layout. Everything that come out of geonworks is either a TKL or a 60 percent.
A TRUELY untapped market that isnt being served by GEON....
 so sad.....  :confused:
Offline CONIN
« Reply #155 on: Fri, 23 August 2024, 21:00:01 »
Geon never made a 65 percent board?...
There's a Glare 65 if that counts, really neat and hefty. But I'd also love to see this Vanquish come to life.
