Author Topic: [IC] VANQUISH65 by Geon - The Tray mount (20-10-23 update  (Read 166394 times)
Offline peaceperfection
Re: [IC] VANQUISH65 by Geon - The Tray mount
« Reply #50 on: Thu, 22 October 2020, 22:19:06 »
Can’t wait for it! I’m so getting my first ever tray mount keyboard for custom scene. Any idea how will the GB work? If I’m not able to get it this round, will there be a round 2?
Offline lush_bunny
« Reply #51 on: Fri, 23 October 2020, 00:11:09 »
I am very curious about the dampener. Typing feel is all up there, and I can only go by what Geon says (and perhaps the people to whom he gives protoypes as well). But I want to know the audio profile vs using a sheet of EVA foam / neoprene / sorbothane. I'm trying to create a classy quiet mech, so I'm watching this thread.
Offline geonworks
    • GEONWORKS
Re: [IC] VANQUISH65 by Geon - The Tray mount (20-10-23 update
« Reply #52 on: Fri, 23 October 2020, 08:37:35 »
I added it because there was an opinion to add ISO first. And because of the structure, the left SHIFT key cannot be divided into two.
In order to reduce the unit price from the previous method of using iron core, the bracket was changed to a single body and because it may be too flexible, the plan is to place a reinforcement plate on top of PCB.
Offline Sck
  • oof
« Reply #53 on: Sun, 25 October 2020, 15:20:12 »
Big interest in this one for sure!
Offline dibstern
« Reply #54 on: Sun, 25 October 2020, 17:58:52 »
Keen to see how this goes! Nice work!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #55 on: Sun, 25 October 2020, 18:06:38 »
intrigued to see the prototype and torsion beams in action.
Offline Raptor_N60
« Reply #56 on: Mon, 26 October 2020, 23:53:59 »
Would there be plate options as well? Otherwise hotswap would not be possible :confused:
Offline DoctorZuluMD
« Reply #57 on: Fri, 06 November 2020, 23:14:21 »
I'm in.
Offline BapoDonu
« Reply #58 on: Fri, 06 November 2020, 23:28:48 »
geon so lit
Offline Mechkeeb
« Reply #59 on: Sun, 08 November 2020, 03:01:26 »
Whats the price and when is the GB so hype for this
Sent from my SM-G985F using Tapatalk
Offline dmatx1
« Reply #60 on: Sun, 08 November 2020, 03:06:22 »
Estimated price in first post:
Price : Under $300 without Ship,VAT,White color
No GB date yet.
Offline santela
« Reply #61 on: Sun, 08 November 2020, 08:31:00 »
Looks very interesting, and I'm always looking to try new mounting methods or structures. But I wish someone could offer a bit more explanation about this structure, how it works, what are the (theoretical) advantages or disadvantages.
Offline Zeelobby
« Reply #62 on: Sun, 08 November 2020, 09:06:49 »
Cons of tray mount: tends to be stiff and inconsistent in both sound and feel. This is because of the posts the pcb/plate is screwed onto.
Pros: Most standardized PCBs come with tray mount holes (mostly just 60s tho). Allows for easier pcb replacement. Also tray mount boards tend to cost significantly less as they can usually be machined in a single main piece.
This board: attempts to resolve the cons by implementing torsion beams for those mounting points, allowing for some flex and maybe better acoustics.
Offline santela
« Reply #63 on: Sun, 08 November 2020, 09:34:37 »
I'm curious if it will be able to compare with some of the more "superior" mounting systems out there? Obviously I guess we'll have to see the board to know, but I wonder if it will simply improve on tray mount, or will it give us a unique typing experience all together.
Offline geonworks
    • GEONWORKS
« Reply #64 on: Tue, 17 November 2020, 03:29:28 »
Silicone foam and plate are also prepared.
Offline geonworks
    • GEONWORKS
« Reply #65 on: Tue, 17 November 2020, 03:31:57 »
Nothing can be said to be superior. You'd better say it's pleasantly used by someone.
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #66 on: Tue, 17 November 2020, 08:52:16 »
this is really interesting.. totally in!
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline LucaLo_
  • CK Stan
« Reply #67 on: Tue, 17 November 2020, 08:57:26 »
Really cool concept here, know Geon's gonna nail it.
Offline d4vid4f
« Reply #68 on: Tue, 17 November 2020, 09:33:21 »
Very intrigued! great work!
Offline hiddensong
  • this too shall pass
« Reply #69 on: Tue, 17 November 2020, 19:14:48 »
Ooooooooh. Now this here.
Offline m1raz
« Reply #70 on: Tue, 17 November 2020, 20:31:26 »
Interested, want to try this one out!  :thumb:
Offline pixelpusher
« Reply #71 on: Wed, 25 November 2020, 02:02:26 »
Will you post an update here when the Group Buy starts or do we just have to watch the vendor discord servers?
Also, the image shows "switch interference."  Is this a problem needing to be solved or is there a solution?
« Last Edit: Wed, 25 November 2020, 02:04:42 by pixelpusher »
Offline jm8080
« Reply #72 on: Wed, 25 November 2020, 02:36:18 »
This is super interesting, never really had a plateless board before
Offline lush_bunny
« Reply #73 on: Wed, 25 November 2020, 07:00:47 »
My first custom is plateless. Pretty easy on the fingers, and the sound profile sounds a little bit more pleasing.
This looks like an entirely different beast though.
Offline hottrout
  • I'd Hit Dat Key
« Reply #74 on: Sat, 28 November 2020, 04:29:49 »
Very interested in your leaf spring design and what that would bring to the feeling from this board.  I don't really want anymore 65% keyboards and would much prefer a 75% or TKL but I could be tempted into buying this to see what the design works like.
Great to see original thinking and design.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline fluidin
« Reply #75 on: Sun, 29 November 2020, 01:32:42 »
hoping for a hotswap option
Offline dmatx1
« Reply #76 on: Sun, 29 November 2020, 02:52:22 »
Offline SmoothFaces
« Reply #77 on: Sun, 29 November 2020, 19:25:04 »
this is so clean. amazing keeb
Offline LordOwen
« Reply #78 on: Sun, 29 November 2020, 22:24:58 »
I haven't gone with a tray mount before, so I'm very intrigued by this concept and design! I hope that I can build one for myself.
Offline SherlockBunny
« Reply #79 on: Mon, 30 November 2020, 15:16:01 »
I hope this keyboard restores my faith in tray mounts! Can't wait to try it out!
Quick question: does the PCB support split-backspace and, if it doesn't, would you consider changing the PCB to accommodate split-backspace?
Offline futurekatsu
« Reply #80 on: Tue, 01 December 2020, 01:15:57 »
This looks great! Excited to see prototypes.
Will the pcb work with VIA?
Offline kk73715
  • Why are you even reading
« Reply #81 on: Tue, 01 December 2020, 01:43:13 »
innovative mounting method with a good price point, really hoping I can join this
good luck with your first international run, Geon!
Offline paulgali
    • SKME
« Reply #82 on: Thu, 10 December 2020, 06:03:50 »
Hi Geon, its treeleaf
Offline acaban
« Reply #83 on: Thu, 10 December 2020, 07:15:41 »
I can't tell if the flex toward the center is as much as the flex at the angles (inclination) and if the latter could cause issue with SA key caps, also: is the kind of flex and movement, that seems pivoting the center, useful for the typing experince aside of isolating maybe the sound of the caps from the case?
Offline CommonDandy
« Reply #84 on: Thu, 10 December 2020, 21:33:29 »
count me in this looks so good
Offline BeachFan69
« Reply #85 on: Thu, 10 December 2020, 22:29:58 »
So in for this.
Offline grundlemere
« Reply #86 on: Fri, 11 December 2020, 09:42:17 »
This is a very cool idea at a very attractive price point. And, your reputation seems to precede you. Really nice to see something different that isn't a bizarre cash grab considering the week we've had here!
Offline donny_pete
« Reply #87 on: Fri, 11 December 2020, 11:29:19 »
Incredibly excited to see the first INTL board by you!  :thumb:
Offline actress
« Reply #88 on: Fri, 11 December 2020, 11:43:28 »
Thank you for allowing international buyers!
I'm hoping there will be multiple rounds so people can actually get it  :(
Offline Dunne
    • Dunne
« Reply #89 on: Fri, 11 December 2020, 13:40:57 »
Geon makes keyboards and this makes me smile  ^-^
Offline -janitor-
« Reply #90 on: Fri, 11 December 2020, 15:06:03 »
Beautiful!
Offline Ensaum
« Reply #91 on: Fri, 11 December 2020, 16:47:05 »
This is such an interesting design, and I feel like the price point makes it a no brainer. Looking forward to this project.
Offline Afresh
« Reply #92 on: Sun, 13 December 2020, 08:36:10 »
Interested for sure  :p
Offline chewtooloud
« Reply #93 on: Sun, 13 December 2020, 13:26:39 »
Great work Geon! Looking forward to the GB and F2-84 of course!
Offline treeleaf64
    • treeleaf64
« Reply #94 on: Sun, 13 December 2020, 15:56:32 »
;D
Everyone must pay the cat tax
Offline dibstern
« Reply #95 on: Sun, 13 December 2020, 17:21:49 »
ETA on a few sound tests? Planning on getting some streamers on board to test it out?
« Reply #96 on: Sun, 13 December 2020, 17:38:43 »
I'm a simple woman. I see a baller 65%, I save it so I can buy it later.
Offline mawli
« Reply #97 on: Sat, 19 December 2020, 05:42:36 »
Interesting mounting design. I'm really looking forward to this!
Offline ltnick
« Reply #98 on: Sat, 19 December 2020, 07:09:47 »
Came across this on YouTube:
Offline hkhawk
« Reply #99 on: Sat, 19 December 2020, 14:17:05 »
Hot 🔥
