Author Topic: [IC] the Night Walker collection  (Read 19085 times)
Offline Ulliam
  • Formerly Papithered
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« on: Tue, 29 September 2020, 04:28:52 »
Get updates on discord: https://discord.gg/dXJmt67
Designed by Ulliam & Protozoa Studios to perfectly compliment KAT Cyberspace & every other reason to have have more glow in the dark, come and relive more of the 90's with me,
I'd like to indroduce you all the the Night Walker collection a complimenting pair of switches and stabilizer set made by Durock & enhanced by Glow in the Dark
The Details:
Solaris:MX
Pantone Black 6c POM T1 Tactile Stem
GiD Nylon Upper & Lower Housing
66g Fast Stainless Steel Springs
Nightcall:MX
GiD POM Silent Linear Stem
Smokey Black Tranlucent Nylon Housing
Lumen:ST
Screw in stabilizers with GID Housing
Black Stainless Steel bars
Pack of: 4x 2u, 1x 6.25 + 1x 7u bar
Vendors and Pricing to be announced but you can expect them to be priced around the same as other Durock recolours, I'd love to know what you guys think
Links & Thanks
Thanks to Dave & Cam of KIIIN for your daily support! Thank you to Chris & Alex from Protozoa for being amazing humans* to work with It's such a blessing to collaborate with amazing like minded creatives with as much passion as you guys!, and Specifically thanks to Alex for his Amazing renders, I struggled for 4 months trying to work out glow in the dark plastic and didnt come anywhere near as close haha.
Ulliam & Fam Discord: https://discord.gg/dXJmt67
Protozoa Studios Discord: https://discord.gg/YJRjWxP
Protozoa Studios IG : https://www.instagram.com/protozoa.studio/
« Last Edit: Tue, 29 September 2020, 04:31:14 by Ulliam »
Offline ectoplasmatic
Re: [IC] the Night Walker collection
« Reply #1 on: Tue, 29 September 2020, 04:33:00 »
let's go let's go!
Offline Bregoli
« Reply #2 on: Tue, 29 September 2020, 04:39:27 »
Seems very interesting
Offline VagueOrigin
« Reply #3 on: Tue, 29 September 2020, 04:45:47 »
Gimme... gimme neowwwwww
Sent from my SM-G975U using Tapatalk
Offline Oddstag
« Reply #4 on: Tue, 29 September 2020, 05:54:17 »
Ugh, Christ. Yes---obviously yes, I'm in.
Offline pupper125
« Reply #5 on: Tue, 29 September 2020, 06:42:09 »
yes
Offline Nonnegaard
« Reply #6 on: Tue, 29 September 2020, 06:59:49 »
yes. why. where would they get light from and when would you even see it.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #7 on: Tue, 29 September 2020, 08:08:51 »
+1
Glow-in-the-dark works by taking in UV light energising the phosphur, but if it's covered from light by your keycaps, you won't see the effect even if you take the caps off and it's dark.
« Last Edit: Tue, 29 September 2020, 08:17:25 by Agilr »
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #8 on: Tue, 29 September 2020, 08:12:42 »
Are they a novelty that you won't even be able to see once they're hidden by keycaps - Yes.
Will I be buying both sets of switches and the stabs - Also yes ;D
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #9 on: Tue, 29 September 2020, 08:31:05 »
+1
On board LEDS would charge them, and Strontium Aluminate produces a strong enough glow it should be visible as backlighting
Offline Shiro
« Reply #10 on: Tue, 29 September 2020, 09:02:07 »
the forbidden candy's
Offline Prelim
« Reply #11 on: Tue, 29 September 2020, 09:42:48 »
this is by far the dumbest idea I've ever seen... do you expect people take all the caps out the keyboard and put a lamp over it for a few minutes, just to see it glowing a bit? Cause if you have leds, why the hell do you ever need these switches?
« Last Edit: Tue, 29 September 2020, 09:45:12 by Prelim »
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Prelim
« Reply #12 on: Tue, 29 September 2020, 09:44:33 »
double post
Offline emerrin
« Reply #13 on: Tue, 29 September 2020, 09:46:08 »
GLOW IN THE DARK CIA -- switches
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #14 on: Tue, 29 September 2020, 09:54:09 »
yeah..... orrrrrrrrrrr use in switch and on board leds to charge them.
Offline iaman
« Reply #15 on: Tue, 29 September 2020, 09:57:07 »
So these are marketed as having "fast springs", thought I'd ask for a clarification there: is "fast" being used here to describe the opposite effect we'd ascribe to "slow" springs? e.g. the 68g fast spring would have a lighter initial force than a 68g spring might "normally" have (so the linear progression of the force is "faster" than a "normal" spring)
If not: any clarification you could provide about these springs would be very kind and helpful for me.
Offline mytommy
« Reply #16 on: Tue, 29 September 2020, 09:59:10 »
lets gooo
Offline CaptainVinceO2
    • ApexKeyboards
« Reply #17 on: Tue, 29 September 2020, 10:15:23 »
Looks cool! Interested to see how they come out!
Offline Prelim
« Reply #18 on: Tue, 29 September 2020, 10:59:09 »
"do you use leds on your keyboard?"
"-yes I do"
"do you like led backlight keyboards?"
"-no I don't"
"then why the hell do you use leds?"
"-just to charge my GID tops, and repeat this process over and over again"
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #19 on: Tue, 29 September 2020, 23:51:16 »
Definitely going in on these. I was blown away by the presentation! You guys have such a unique aesthetic, super refreshing to see that level of creativity brought to the community.
Offline Pyk_
« Reply #20 on: Wed, 30 September 2020, 09:58:26 »
I was planning on putting some uv LEDs in a build for Cyberspace anyway so I’d definitely be interested in trying these. I wonder how much light they would receive from an upward facing 3mm LED? Looks like they would benefit from SMD LEDs... more reason for me to design a PCB I guess!
Offline CastleKeyboards
  • UK Vendor
    • Castle Keyboards Website
« Reply #21 on: Wed, 30 September 2020, 11:07:20 »
Beautiful aesthetic! Also I'm totally down to re-live the 90s with the glow in the dark stuff! Love it!
Offline Sundowning
  • Slime Scholar Caps
« Reply #22 on: Sat, 03 October 2020, 00:25:50 »
gonna need 100 of both of those bad boys..
Offline WHAT!?
  • WHAT!?
« Reply #23 on: Sat, 03 October 2020, 10:03:01 »
I can put everything on this website firmly under the category of "no I don't need that".
I'm gonna buy a set of the tactile switches though. I'd probably go for at least 70 of 'em.
Offline lubekpl
« Reply #24 on: Sat, 03 October 2020, 13:37:21 »
Can we get to the GB stage already?
Wysłane z mojego COR-L29 przy użyciu Tapatalka
Offline BirgusLatro
« Reply #25 on: Fri, 09 October 2020, 12:34:56 »
Yeah I'm in.
Offline Baka Bot
« Reply #26 on: Fri, 09 October 2020, 13:03:31 »
This is really interesting to see this on an all black build. I really like these
Offline opaxxity
« Reply #27 on: Wed, 11 November 2020, 18:22:08 »
im in.
to the poster questioning their genius.
same could be said for every single KEYCAP gb: why buy a keycap group buy, when there are plenty others ready made (but not custom color)?
answer: its custom, and it fits an aesthetic the consumer is going for.
but to be more specific, im actually in the middle of a see thru case build where im integrating uv led's.  so this is right up  my ally.
« Last Edit: Wed, 11 November 2020, 18:24:34 by opaxxity »
Offline gak1234
« Reply #28 on: Sun, 29 December 2024, 01:37:09 »
Probably no chance of these coming back is there?
Offline An Angry Swan
  • Careful, I could break your arm
« Reply #29 on: Sun, 29 December 2024, 04:40:18 »
Best bet would be to ask in the Protozoa discord. Ulliam ghosted the hobby, leaving people out of pocket, ages ago.
I'd be very surprised if there is ever an R2. (From personal experience R1's weren't great)
Offline gak1234
« Reply #30 on: Mon, 30 December 2024, 01:57:28 »
I heard they were mediocre at best. I just want 'em for a display build, UV LEDs and the like.
Offline boku
  • 東プレ株式会社
« Reply #31 on: Mon, 30 December 2024, 19:13:44 »
There have been tons of better GID switch options since these came out. If you want these specific ones there are still some in stock on Kono
Pro2 Ivory | Pro2 Charcoal | RF 101 | Martingale Ver.SUS | Ogre | KFE CE
