Author Topic: [IC] GMK Modern Japanese Desko - GB April 19.  (Read 70279 times)
Offline EnjoyMyInSec
  • 60% or bust
Re: [IC] GMK Modern Japanese Desko
« Reply #50 on: Thu, 01 October 2020, 07:45:20 »
this looks pretty nice, the deskmat in the first render should really be an option though. it looks far cooler than the others. personaly id like text and icon mods. i dont mind about the numpad either way.
We had a dozen of deskmats ideas, they arent set in stone yet :)
Offline Koobaczech
  • Don't forget to smile :)
    • Pearlboards
« Reply #51 on: Thu, 01 October 2020, 10:35:37 »
Looking nice man, great job on the set! Gonna be awesome! :thumb:
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #52 on: Thu, 01 October 2020, 10:39:33 »
this is pretty lit, killer renders too.
2 main things
1. numpad avail?
2. are any of these colors stock, or is it fully custom? i like the tones of the alphas/mods a lot.
Offline Prelim
« Reply #53 on: Thu, 01 October 2020, 10:46:08 »
any chance for a RGB kit only?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline ireverliat
« Reply #54 on: Thu, 01 October 2020, 10:57:45 »
Amazing colour's and idea!
Im in  :cool:
Offline zoo
    • zoo
« Reply #55 on: Thu, 01 October 2020, 11:00:43 »
Can't stop thinking about GMK Minimal 2.
I knew I had seen this colorway from somewhere recent. Yea it reminds me a lot of GMK Minimal 2. Is it same colors but different legends?
Offline jagger27
  • ne 1.5U supers???
« Reply #56 on: Thu, 01 October 2020, 11:57:16 »
Good kitting. Love to see those 1.5U Supers.
  • 60% or bust
« Reply #57 on: Thu, 01 October 2020, 13:01:12 »
2 main things
1. numpad avail?
Thanks for the kind words ! I apprecieate it.
1. Comming from you requesting numpad make sense ahah. As I said before I really don't want to do it, but if people keep asking for it, I guess I may change my mind.
2. white is WS1, black is CR, the rest is full custom (you can see the color codes at the end of the first post).
Also thanks everyone for the kind words, I'm still "brainstorming" to see what I'm keeping/doing.
Offline lolpes
« Reply #58 on: Thu, 01 October 2020, 15:37:44 »
Love the concept and the "desko" inspiration.
My only suggestion, and really my main gripe with the set is the arrow cluster which takes away from the desko feel.
I would suggest the following:
 - Provide only green and blue arrow up
 - Provide all 3 colors for arrow down
This gives you a bit more color pop on the arrow cluster, currently all red bottom row seems too monochromatic and people can play around with the combo and still keep the desko feel?
Offline 2Moons
« Reply #59 on: Thu, 01 October 2020, 17:48:55 »
GMK Paperwork vibes. My only suggestion is to add a numpad kit. Looks nice. I love the deskmats and I want them.
« Last Edit: Thu, 01 October 2020, 18:02:15 by 2Moons »
Offline OtherAndrew
« Reply #60 on: Thu, 01 October 2020, 22:37:54 »
kinda weird to have 7u colored spacebars in the hhkb kit and the spacebars kit
i stand by my position that ¥ should be on pipe
« Last Edit: Thu, 01 October 2020, 22:39:48 by OtherAndrew »
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #61 on: Fri, 02 October 2020, 02:39:00 »
If R3 Control users really want a stepped key, they can use stepped ⇩. In fact, some sets (e.g. GMK Rouge) chose to not include R3 Control at all because the ⇩ is generic-looking enough that it can be used for Control.
First sentence I agree with, but second I'd suggest against. Considering a lot of this kit panders to the HHKB keyboard influence and layout, not having a R3 Control would just seem odd and unnecessary.
No worries, the second sentence wasn't part of the suggestion, I was just using that example to further my point about stepped Control not being necessary. I agree that regular R3 1.75u Control should definitely be in this set.
However, one thing that may be worth considering when it comes to this key, is changing the Control text to a ∧ icon (e.g. like GMK Red Devils). It fits in a bit better aesthetically with the surrounding icon mods. See below for an example:
2) Can't argue with that :) In that case, consider including a separate R4 1.25u Fn key. Although, I wouldn't say that it's a must; the other suggestions I had are more important.
I'd support a 1.25u FN key; my FC750R actually has Alt/Fn/Menu/Ctrl on the right side of the spacebar, so I'm okay with both Menu and FN :p
However, and somewhat ironically, in the render of the dark gray U80, it appears a 1.25u FN key already exists. At this point that seems like an oversight, but hopefully that was a Freudian Slip.
That's a good point, some TKLs do indeed use both Menu + Fn instead of Super + Fn/Menu. A few off the top of my head are: Drop CTRL and ENTR, Leopold FC750R, GMMK ТKL, Durgod K320. And I guess some people may prefer to have it this way on their customs, but I'm not sure how common that is.
I think the bigger argument in favor of also having Fn as an option is that, on its own, it trumps Menu in terms of popularity across a wide variety of boards and layouts (all the way from 40s up to full-size).
Agreed on all points.
On the topic of numpads, consider this chart konstantin posted above. Looking at those numbers, you see the top 3 most popular layouts (that do not have/utilize numpads) above full-size outnumber full-size layouts at a combined 1,237 to 223; can bump that number up by 18 if you include 1800 and 96% layouts. Now I'm not personally aware of where that data came from, and would note how this probably only reveals super high-level trends in the community.
If leaving numpad keys off the base kit not only follows the designer's vision but also lowers the cost, then I certainly support it. An alternative could be adding a separate kit for those keys, but again that's up to the designer.
« Reply #62 on: Fri, 02 October 2020, 22:10:50 »
this is neither desko nor "modern" but it's japanese, so you can have 1/3
just change the name and we gucci
this is not at all what i pictured when i first opened the thread
also no numpad?? bro
numpad kit has like 35% adoption on most GMK sets, just run it
Offline 50ATE
« Reply #63 on: Fri, 02 October 2020, 22:30:34 »
Love this! Any chance of getting a Canadian vendor?
  • 60% or bust
« Reply #64 on: Sat, 03 October 2020, 04:35:32 »
Yes, I just don't know which one to chose lol.
Offline Sshimosawa
« Reply #65 on: Sat, 03 October 2020, 09:44:32 »
This is sublime.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #66 on: Sat, 03 October 2020, 09:49:50 »
This is great I love it!!
  • 60% or bust
« Reply #67 on: Sat, 03 October 2020, 16:49:41 »
Thanks for the kind words everyone.
I'm redoing some kits reguarding what you guys suggested.
I'll post an update soon, have a nice week end :)
Offline Vadurr
  • Valar Morghulis
« Reply #68 on: Sat, 03 October 2020, 19:28:25 »
Pastel accent kit? O.O
Offline yui_
« Reply #69 on: Sun, 04 October 2020, 06:31:42 »
was in until no numpad. as far as i can see, you chose not to include it for ****s and giggles?
add a numpad and i might be interested.
Offline Ja3_420
« Reply #70 on: Sun, 04 October 2020, 10:21:29 »
pls add numpad
  • 60% or bust
« Reply #71 on: Sun, 04 October 2020, 15:15:51 »
DW guys I'm doing some changes, I think you'll be happy about them :)
  • 60% or bust
Re: [IC] GMK Modern Japanese Desko - Numpad added/kit changes
« Reply #72 on: Mon, 05 October 2020, 12:14:56 »
Hi there,
First I want to thank all of you for your feedback, this was really important to make such decisions for the future of the set, here are the new changes :
Yes I made a very simple numpad kit, a separate one, I hope you guys are now happy with that :thumb:
For the latin kit I added an extra tab and enter so you can fit 2 keyboards with base + latin
For the base kit, I added R3 Pg R4 PgDn. Didn't do more modification to it, since imho it's perfect like that
I hope that now the set fits your needs and that you're happy about the changes, and if not, please tell me why  ;D
Offline kumori
    • polartype
« Reply #73 on: Mon, 05 October 2020, 12:17:19 »
interesting! glws :)
Offline soloplayer
« Reply #74 on: Mon, 05 October 2020, 20:10:50 »
Hi there,
i think this is more than enough for me. pls proceed to GB now!!  ;D
Offline HungHingDaiLo
  • 無間道
« Reply #75 on: Tue, 06 October 2020, 05:19:57 »
Maybe this is not important at all, but..
Numpad kit's naming should be uniform like others.
Namu paddo kitto or something.
IG: @rayhhdailo
  • 60% or bust
« Reply #76 on: Tue, 06 October 2020, 06:18:04 »
Yeah I thought about that too will be fixed ;)
Offline SenseiJia
  • Hey you.
« Reply #77 on: Tue, 06 October 2020, 11:31:57 »
we got the numpad bois.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #78 on: Tue, 06 October 2020, 11:39:19 »
aight cool now nobody can ever think to make another ic without a numpad
straight goofin'
Offline 002_GT
  • KR Boards OP
« Reply #79 on: Tue, 06 October 2020, 16:36:58 »
very nicely done  :thumb:
  • 🕸 developer
    • Discord
« Reply #80 on: Wed, 07 October 2020, 00:59:28 »
straight goofin'
Surprised the numpad mob didn't attack Hedgey for not including a numpad in DSA Vegas Nights…
Offline Prelim
« Reply #81 on: Wed, 07 October 2020, 04:53:13 »
will a Norde kit be included as addon?
  • 60% or bust
« Reply #82 on: Thu, 08 October 2020, 07:51:23 »
Not planned sry  :thumb:
Offline konstantin
  • Formerly constexpr
« Reply #83 on: Thu, 08 October 2020, 18:30:20 »
Hi there,
Very nice changes!
You may also want to consider moving the R1 1u Pg Dn, End keys from base to the numpad kit. There are no drawbacks to doing this, as these keys are only used on boards that also use numpads (1800, CP, 96-key layouts). In fact, if you take a closer look, you'll see that most sets that offer split numpad kits place these keys in the numpad kits. Some recent examples are: GMK Minimal R2, GMK Red Devils, EPBT Skadi, SA Dualshot.
Edit: Oh, and don't forget the ー sublegend for the -_ほー key; I believe I've already mentioned that somewhere ;)
« Last Edit: Thu, 08 October 2020, 18:34:55 by konstantin »
  • 60% or bust
« Reply #84 on: Fri, 09 October 2020, 14:10:29 »
I guess most people are happy with the changes.
Im contacting gmk and the vendors to speed up the process, thanks again  :thumb:
Offline killerkowalski
« Reply #85 on: Fri, 09 October 2020, 15:09:24 »
Will follow this and interested!
Offline martensson
« Reply #86 on: Wed, 14 October 2020, 05:46:51 »
Very interested, but there are no colored/accent 1.25u mods? This render seems to show it at least:
  • 60% or bust
« Reply #87 on: Thu, 15 October 2020, 11:58:39 »
That’s a mistake, This set is meant for wkl/tsangan bottom row.
Sorry for the false hope
Offline Makish
  • hi
« Reply #88 on: Thu, 15 October 2020, 15:08:17 »
holy **** this right after gmk beta
I'm so ready for my endgame topre MX board
Offline Little4Real
« Reply #89 on: Thu, 15 October 2020, 16:24:59 »
If this was PBT, I'd be all for it.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #90 on: Thu, 15 October 2020, 18:01:34 »
This pleases my eyeballs and neuron firings
Offline martensson
« Reply #91 on: Thu, 15 October 2020, 20:21:27 »
Thanks for clearing that up! I mostly stick to a "standard" bottom row so had my hopes :)
Offline falzm
« Reply #92 on: Wed, 28 October 2020, 04:37:02 »
Yes please!
  • 60% or bust
« Reply #93 on: Fri, 30 October 2020, 09:28:14 »
Still waiting on the quote from GMK.
Proxy should be decided, I'll update everything asap :)
Offline ullr
« Reply #94 on: Mon, 09 November 2020, 07:02:55 »
How about red HHKB control 🤔
Offline senencito
« Reply #95 on: Mon, 09 November 2020, 11:09:14 »
It's a bummer the green is not a match for GMK Wavez.
I've been looking for a replacement spacebar.
Great set though!
Offline noorejji
« Reply #96 on: Sun, 03 January 2021, 02:38:55 »
If this is inspired by a Realforce board, how about a compatible 7u spacebar (6u spacing on the stems)? :p
  • 60% or bust
Re: [IC] GMK Modern Japanese Desko - GB April 10.
« Reply #97 on: Fri, 22 January 2021, 12:14:09 »
Update : GB will happen the 10th of April 2021.
Kits are fixed.
Will collab with artisan makers and cable makers
Answers to older comments :
1) Green dosent match wavez because Wavez R2 will run this year  :thumb:
2) Red HHKB control is something I hesitated but Im not so sure considering this is an icon mod keycap sets, and adding a control text key won’t be that good looking.
As usual, thanks for your insane support !
Offline synthtastic
« Reply #98 on: Fri, 22 January 2021, 17:43:14 »
Very hyped for this set. Looks fantastic.
Expensive plastic makes me sigh.
Offline soloplayer
« Reply #99 on: Fri, 22 January 2021, 18:15:11 »
is there any price yet?
and will you request gmk to produce this set with their newest machine?
« Last Edit: Sat, 23 January 2021, 00:39:33 by soloplayer »
