Author Topic: [IC] ookey60 - Original Thread  (Read 12499 times)
Offline ookey
« on: Mon, 05 October 2020, 11:43:36 »
Hi everyone!
Thanks for all of your feedback on the project so far. Since posting this IC, I've made some design changes that I think are substantial enough to warrant a new topic altogether, so I'll be locking this topic now.
I've got a prototype of this new design arriving early next week, and I'll be posting a new IC in the weeks following.
If you want to keep up with the project, please feel free to join the Discord server.
Thanks! ;D
Original Post
Seamless / Screwless / Top Mount / 60% / WKL
Hello Geekhack, thanks for taking a look at my first IC. I'm Lucas, or ookey in most places, and I'm based in the UK.
It's certainly nothing fancy, just a clean and minimal top mount 60%.
Renders
Here's how the top piece and base will be screwed together once assembled, before putting on the keycaps.
Details
  -  7° Angle
  -  Uniform Bezels
  -  No Externally Visible Screws
  -  Seamless
  -  ~18mm Front Height
  -  1mm Neoprene Case Foam Included / Potentially 3.5mm Neoprene Plate Foam Included
  -  6061 6063 Aluminium Top and Base / Anodised Black or Potentially E-White
  -  Top Mount 1.5mm Plate / Anodised Black Aluminium / Potentially Polycarbonate
PCB and Layout
  -  Soldered-only
  -  ESD Protection
  -  QMK and VIA Compatibility
  -  Centred USB-C Port
  -  No In-switch LED Support
Only ANSI plates will be available in the GB, with both ANSI and ISO plates files available for those wanting to get their own plates made. Keys in blue are supported by the available ANSI plate, while keys in red will only be supported by the PCB.
For round one there will be 25 group buy slots open plus extras, with the price still being TBD. If the first run is successful and there is still demand, I'm happy to do a larger round two in the future.
I've set up a Discord server if you'd like to join and keep up with any updates - https://discord.gg/7PrkJcZ
Please reply with any feedback or questions, or leave them in the Discord server. Thanks for reading :)
Status
  -  PCB prototypes arrived
  -  Close to ordering case prototype
  -  Neoprene case foam arriving soon
  -  Waiting for silicone feet samples
« Last Edit: Thu, 26 November 2020, 06:15:43 by ookey »
Offline ookey
Re: [IC] ookey60 - Seamless / Screwless / Top Mount / 60% / WKL
« Reply #1 on: Mon, 05 October 2020, 11:44:12 »
Reserved
Offline Bawsky
  • Give Deathcaps pls
« Reply #2 on: Mon, 05 October 2020, 11:49:56 »
I like it. Clean and simple design. You list your price as TBD but do you have any idea about the ballpark cost, or target cost?
Offline MilkTea_QAQ
« Reply #3 on: Mon, 05 October 2020, 11:50:44 »
Cool looking keyboard! What price point will this around? Same 60% keyboard S58 also came nearly, looking forward to see which one has more value!
Offline ookey
« Reply #4 on: Mon, 05 October 2020, 11:55:04 »
Cheers! It's hard to say right now, but I reckon it will be more in the $275 - $375 range. I'm not sure how many S58s are being made, but as I'm making so few for now, the price will most likely be higher I'm afraid.
« Last Edit: Mon, 05 October 2020, 11:59:19 by ookey »
Offline dado brat
« Reply #5 on: Mon, 05 October 2020, 12:13:25 »
This looks really clean. the thick bezels are not my thing but beauty is in the eye of the beholder right? I hope this one goes well, I really like the trend toward seamless rectangles
Offline lamp
« Reply #6 on: Mon, 05 October 2020, 12:21:43 »
very clean and minimal look which is perfect
Offline Blastoise
« Reply #7 on: Mon, 05 October 2020, 12:22:33 »
Love the minimal design! Ready for it!
Offline minokeys
« Reply #8 on: Mon, 05 October 2020, 12:31:54 »
"nothing fancy" usually tickles my fancy
Offline jjoejimmy
« Reply #9 on: Mon, 05 October 2020, 12:32:22 »
Looks clean and slick! That 25 unit limit is gonna drive the price way up though. Maybe I'll be there for a bigger R2!!
Offline rsvnh
  • Sem van Nieuwenhuizen
« Reply #10 on: Mon, 05 October 2020, 12:35:28 »
This design looks really clean, I dig it! I like that there is the potential of a PC plate.
Offline pnw-g
  • i have a dog
« Reply #11 on: Mon, 05 October 2020, 12:47:17 »
Looks great. Good luck!
Offline Baka Bot
« Reply #12 on: Mon, 05 October 2020, 12:47:56 »
A Simple design for a simple person. I want it
Offline treeleaf64
    • treeleaf64
« Reply #13 on: Mon, 05 October 2020, 15:42:17 »
Yay good job
Everyone must pay the cat tax
Offline zoo
    • zoo
« Reply #14 on: Mon, 05 October 2020, 15:52:21 »
oooooo, simple is great :)
Offline Paragon
« Reply #15 on: Mon, 05 October 2020, 15:57:38 »
Usually not a fan of WKL but this is sleek! Good luck with the IC, I am sure you wont have a problem selling off 50 units.
Offline paperassgasket
« Reply #16 on: Mon, 05 October 2020, 23:45:59 »
You had me at 60% WKL, but I'm def in for VIA support.
Offline delvix
« Reply #17 on: Tue, 06 October 2020, 04:09:08 »
This looks awesome! Hopefully I can afford it, might have to wait for R2 haha
Offline ookey
« Reply #18 on: Thu, 08 October 2020, 12:21:34 »
Thanks :D Still looking at increasing the number of boards in R1 at the moment
Offline whitemamba
« Reply #19 on: Thu, 08 October 2020, 23:38:06 »
Board is really interesting, the discord invite link is not working, saying the invite is invalid? can you please check that
Offline ookey
« Reply #20 on: Fri, 09 October 2020, 06:32:03 »
Ah sorry about that, it's fixed now
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #21 on: Mon, 12 October 2020, 10:09:36 »
beautiful and discreet design!
Offline Blvck.-
« Reply #22 on: Wed, 14 October 2020, 15:37:37 »
This is a Need not a want.
Offline ookey
« Reply #23 on: Wed, 14 October 2020, 16:59:59 »
Cheers everyone! Can't wait to get a proto to show you ;D
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #24 on: Thu, 15 October 2020, 18:19:50 »
GLWIC. Love the sharp minimal angles.
Offline Mcnos
    • GMK Fuyu
« Reply #25 on: Thu, 15 October 2020, 21:21:15 »
yep,
that's a rectangle
Offline treeleaf64
    • treeleaf64
« Reply #26 on: Thu, 15 October 2020, 21:22:39 »
