Author Topic: [IC] SA Ramses | GB 16 April - 14 May HAPPENING NOW!  (Read 73268 times)
Offline Lizcuits
  • KAT PBJ
    • KAT PBJ
Re: [IC] SA Ramses | 29 Jan: NEW WEBSITE UP! + 40s/Ortho updates
« Reply #100 on: Thu, 28 January 2021, 22:11:04 »
Ahhh! The new website is so clean, I am so excited for this set. You've put in so much work for this and it shows! I am so happy to see it coming to life.
Proud of u homegirl <3
Offline HungHingDaiLo
  • 無間道
« Reply #101 on: Thu, 28 January 2021, 22:14:51 »
Super nice & clean website!
IG: @rayhhdailo
Offline harlekein
« Reply #102 on: Fri, 29 January 2021, 03:44:09 »
Alright, I really don't need another SA keyset, but this is beautiful. With the ortho kit separated from 40s, it has become even more attractive to me, so this is the first time I'm asking it here: Any chance for a Colevrak kit?
And to complete the ortho kit for supporting split ergo boards, please consider adding two 1.5u space keys.
Offline Friendship
« Reply #103 on: Fri, 29 January 2021, 08:53:48 »
new website looks awesome! thank you for addressing the F row colors! very stoked for this set great job!!!!!
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline xlSantos
« Reply #104 on: Fri, 29 January 2021, 10:42:42 »
I though I had posted on this but I saw this a while back and thought it was a really good looking set! I am looking forward to seeing the deskmats. I hope to get in on the when it drops on GB. GLWIC
Offline Surefoot
Re: [IC] SA Ramses (29 Oct: NOVELTIES, all vendors announced!)
« Reply #105 on: Fri, 29 January 2021, 10:49:09 »
If there's any RAMA caps, the eye of RA would probably look cool
I second that. Golden RAMA with the eye of RA seems appropriate.
Offline DeMechanica
« Reply #106 on: Tue, 02 February 2021, 06:54:29 »
Yes! I love the new split 40s and ortho sets. Niceeeeee
No 2u spacebar in it is odd to me though, isn’t it more common in ortho boards than two 1u space keys?
« Last Edit: Tue, 02 February 2021, 06:56:20 by DeMechanica »
Offline andromache
« Reply #107 on: Tue, 02 February 2021, 07:34:57 »
The website looks amazing! Totally captures the vibe of your set.
Offline bloodparticle
  • A through hole keyboard fan!
« Reply #108 on: Tue, 02 February 2021, 08:25:41 »
Truly gorgeous and the color choises are so funcional and related, i'm hyped  ;)
Offline thicthock
« Reply #109 on: Sun, 07 February 2021, 05:30:02 »
this set looks so promising!
Offline rottencat
« Reply #110 on: Sun, 07 February 2021, 08:38:09 »
Anyone else hear "The Bangles - Walk Like an Egyptian" playing their heads while looking at these?
Offline shcott
« Reply #111 on: Sun, 07 February 2021, 23:55:22 »
Really liking the look of this! The color scheme matches the SA style really well :)
Would definitely be getting the Alt Alphas and Mods if I were to buy it. I just like lighter alphas more.
Offline Arcoril
« Reply #112 on: Tue, 09 February 2021, 00:17:07 »
I'm really glad I discovered this set! I just picked up a dark green KBD8x MKII and I think sand alphas/nile mods would complement it perfectly. Definitely jumping on this when the GB hits.
« Last Edit: Tue, 09 February 2021, 16:25:37 by Arcoril »
Offline narzoideo
« Reply #113 on: Thu, 11 February 2021, 12:59:31 »
Any hope for an international south kit?
Offline Rx003
« Reply #114 on: Fri, 19 February 2021, 05:50:23 »
This looks neat, love the renders! Glwic and wish you all the best for this project!
Offline DrHigsby
  • The doctor is in.
« Reply #115 on: Fri, 19 February 2021, 12:40:41 »
For the Ortho Kit:
https://i.imgur.com/pLkgLEy.png
-I recommend including at least 1x 2u spacebar.
-R3 enter is decently popular to be worth including. If you decide to make this change, I recommend dropping the enter accent and leaving just the Esc accent
-R2 Esc is decently popular to be worth including. Not all ortho users swap Tab and Esc
If the goal is to ONLY include support for the "default" layout of Planck/Preonic, then you've achieved that as is.
For the 40's add-on kit:
https://i.imgur.com/XFLifDD.png
I'm really conflicted with this kitting decision.
For example, If I wanted to kit out a minivan, I'd have to purchase FOUR kits; base mods (for 1.75u shift, bottom row mods, and arrows) +alphas +40s (for 1.75u backspace, 1.5u enter, 1.25u tab, and would have to use 1u Super/Fn from base instead of legend accurate 1u Shift) +spacebars (for 2.25u/2u).
Is there a world where you consider running this as a full-on 40s mods kit that does not require the purchase of a base kit? Doing so would require a big change up and would require you to drop one of the color supports to make its pricing reasonable.
http://www.keyboard-layout-editor.com/#/gists/ff85d60c119d342b63a24802d546e08a here is a mock-up of what an accent-less, single color 40's staggered mod kit could look like.
As a 40s user, I would be super into this + alphas. As it stands right now, the 4 kit ask of 40s users is a bit tough.
GLWIC!  :cool: :cool: :cool:
« Last Edit: Fri, 19 February 2021, 12:42:18 by DrHigsby »
Offline atlanticise
« Reply #116 on: Sun, 21 February 2021, 23:18:11 »
For the Ortho Kit:
Thanks so much again for your advice! We already had this discussion on Discord but I felt weird leaving this hanging on the thread, so I'll post a summarised response.
Due to very low interest in the IC form, this set will have the bare minimum Plank/Preonic support for the Ortho kit, and we have decided on a 40s extension kit to follow in the footsteps of other notable SA sets. I understand that it's quite costly to always buy a base alpha/mod kit and then top up with 40s and spacebar kits, but as a customer it's what I would prefer because then I would have the flexibility to use the set for all kinds of layouts in future, without the gripe of having lots of repeated keys.
Offline darthcapn
Re: [IC] SA Ramses | 25 Feb: More collabs, GB Q2 2021!
« Reply #117 on: Sun, 28 February 2021, 04:22:46 »
Iron165 teal with this. Yum!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline flyingpanda
« Reply #118 on: Fri, 05 March 2021, 20:05:05 »
oh man! this would look so good on my green sat75 (:
can't wait for the GB!!!
Offline deag
    • insta
« Reply #119 on: Sat, 06 March 2021, 23:49:44 »
happy to be in collaboration with 2021's top 1 keyset designers to keep an eye on.  :cool:
Offline ab042896
« Reply #120 on: Wed, 10 March 2021, 12:08:54 »
Somehow missed this until now, love the green.
A few things I noticed, Caps Lock and Num Lock appear to be the only non-single line mods, what are your thoughts on changing these to simply Caps and Num respectively?
Also F13 possibility?
Offline atlanticise
Re: [IC] SA Ramses | GB 16 April - 14 May, pricing & deskmat reveal SOON
« Reply #121 on: Tue, 06 April 2021, 05:32:39 »
Hellooo sorry I missed these questions! For the mods the moulds are pretty standard, so we're just going with the two lines like most SP sets. F13 not in the works I'm afraid. I'm glad you like the green though!! Thanks for your support!
Offline ben56k
« Reply #122 on: Tue, 06 April 2021, 06:00:41 »
My wallet is nearly ready.
Do you have a better signature pic than half of a board and the profile of the set to share?
« Last Edit: Tue, 06 April 2021, 06:06:54 by ben56k »
Offline andromache
« Reply #123 on: Tue, 06 April 2021, 09:17:11 »
Oh no. RIP my wallet. Can't wait for GB!!!
Offline Pandamom98
« Reply #124 on: Tue, 06 April 2021, 19:21:36 »
Im so excited for this GB but my wallet isnt lol
Offline hottrout
  • I'd Hit Dat Key
« Reply #125 on: Thu, 08 April 2021, 05:31:27 »
I have prepared and my wallet is ready.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline ManoliVisuals
« Reply #126 on: Thu, 08 April 2021, 12:19:43 »
Cant wait to spend money I dont have on this  :))
Offline matrixzj
Re: [IC] SA Ramses | GB 16 April - 14 May, Deskmat is HERE!
« Reply #127 on: Sat, 10 April 2021, 12:57:43 »
Manufacture will be SP or Maxkey ?
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline Bobatype
  • formerly bobasweatandtears
    • discord: bobatype
« Reply #128 on: Sat, 10 April 2021, 23:08:47 »
Not OP, but pretty sure SP (Signature Plastic).
Been waiting for an SA keycap set since SA Bliss to catch my eye. Happy to see this get to GB, but man my wallet is hurting this year
Offline phxrbn
  • tech. design. real estate.
« Reply #129 on: Fri, 16 April 2021, 03:33:17 »
Was a sand numpad ever added to this or is it just available in Nile?
Offline Jebus
« Reply #130 on: Fri, 16 April 2021, 06:07:18 »
Damn, how could I have slept on this for so long...Although I'm a bit sad that it's SA profile, but that's purely preference :) You did a really great job!
Offline hottrout
  • I'd Hit Dat Key
« Reply #131 on: Fri, 16 April 2021, 06:37:29 »
All kits and the Thock ordered.  Great set.  Thank you.
Systems -
  Keyboards -
Offline atlanticise
« Reply #132 on: Fri, 16 April 2021, 07:49:24 »
Yup, manufacturer will be Signature Plastic (SP)
Offline atlanticise
« Reply #133 on: Fri, 16 April 2021, 07:51:48 »
Hey there, the numpad is only available in one version - numbers in Nile with mods in Sand.
Offline atlanticise
« Reply #134 on: Fri, 16 April 2021, 07:53:40 »
Thank you for your kind words!!!
Thank you for your support on Day 1! greatly appreciated :)
Offline Fredington
    • Instagram
« Reply #135 on: Fri, 16 April 2021, 08:55:11 »
Just want to confirm if you've cleared those novelties with SP. Some have very fine details that I'm not sure they can execute.
Offline Friendship
« Reply #136 on: Fri, 16 April 2021, 10:07:36 »
Is the THOK novelty not going to be offered via Omnitype?
