Author Topic: [GB] NEO Palette G67 - Gasket, Acrylic, customize color, 65% - 100% shipped  (Read 17288 times)
Offline Patrickwu
Original IC Post Link: https://geekhack.org/index.php?topic=108630.0
NEO Palette G67 keyboard kit Groupbuy is LIVE now!
Place your orders at: https://www.neokeys.net/products/neo-palette-g67-keyboard-kit-1
Minimum Order Quantity:100, Maximum Order Quantiy: 330.
Starting on Oct 23rd, at 11:00am of Hongkong Time (UTC+8) (https://www.timeanddate.com/worldclock/converter.html).
Ending on Oct 30th, or when order quantity hits 330.
Lead time 60-90 days.
Join Discord for more updates and renders by request(https://discord.gg/2MCKpQQ)
First 50 orders will be shipped with a free acrylic lube station in random colors They're gone, we're way beyond 50 units.
Features
-   Acrylic sandwich structure, with fully isolated, gasket mounted switch plate. Switch plate is supported by 6 silicone and 6 EVA gaskets and completely hidden from sides of the case.
-   Laser cut acrylic case plates
-   Switch plate options: Carbon Fiber, Brass
-   5.3 or 6.9 degree typing angle, adjustable via using 3 or 4 layers of feet
-   18 pre-set case color schemes and more to come..
-   Fully customizable case color. 20 colors for each of 11 acrylic layers, total over 409,600,000,000,000 possible combinations. And more to come..
-   Countersink holes only. All mounting screws will be flush with case surface
Hotswap PCB
-   QMK programmable
-   North facing switch mount
-   Per-switch SMD RGB light
-   RGB blacklight
-   Center mounted USB-C port
Soldered PCB
-   ISO, 7U spacebar, split BS compatible
-   South facing switch mount
-   Extra backlight LEDs
Content:
Acrylic Plates x11
Switch Plate x1
NEO67 PCB x1
2mm silicone gaskets x8 (x2 spare)
3mm EVA gaksets x8 (x2 spare)
1.2mm silicone feet x8 (x3 spare)
PCB/Switch Plate dampening foam x1
M2*8mm Ti coated flat head screws x24
M2*4mm Ti coated flat head screws x3
M2*5mm Ti coated round head screws x3
M2*13mm brass posts x12
M2*4mm brass posts x3 (3 layer feet - 5.3 dgree)
M2*7mm brass posts x3 (4 layer feet - 6.9 dgree)
M2*3mm flat head screws x6
M2*3mm round head screws x6
M2*3.5mm aluminum posts x6
1.27mm allen wrench x2
Microfabric cloth x1
USB-C Cable x1
Price:
Pre-set color scheme with carbon fiber plate - $140
Full custom color scheme +$10
Brass plate +$10
Pre-set color schemes and recipes:
All layers - Clear
All layers - Frosted Clear
1 - Red; 2 - Flo Orange; 3 - Flo Yellow; 4 - Flo Green; 5 - Cyan; 6 - Flo Blue; 7-11 - Purple
All Layers - Frosted Black
Abyss: 1 - Cyan; 2 - Flo Blue; 3 - Flo Blue; 4 - Light Blue; 5 - Dark Blue; 6 - Dark Blue; 7-11 - Frosted Black
1 - Frosted Cyan; 2 - Frosted Clear; 3 - Frosted Orange; 4 - Flo Orange; 5 - Flo Orange; 6-11 - Red
1 - Purple; 2 - Frosted Pink; 3 - Flo Blue; 4 - Cyan; 5-11 - Flo Green
1 - Clear; 2 - Frosted Pink; 3-6 - Purple; 7-11 - Frosted Black
All Layers - Flo Orange
1-3 - Yellow; 4-11 - Flo Yellow
1 - Clear; 2-4 - Flo Green; 5-11 - Green
1-3 - Frosted Clear; 4-11 - Frosted Yellow
1-3 - Cyan; 4 - Frosted Cyan; 5-11 - Flo Blue
1 - Frosted Clear; 2-5 - Frosted Cyan; 6-11 - Frosted Clear
1-3 - Frosted Clear; 4-11 - Frosted Pink
All Layers - Flo Green
1-3 - Frosted Black; 4 - Flo Green; 5-11 - Frosted Black
All layers - Flo Pink
Some awesome custom build and renders:
https://cdn.shopify.com/s/files/1/0478/0418/6773/files/NEOKey_Palette_G67_-_19.png?v=1603430625
Some sample pics:
UPDATES
2020.10.28 All 330 units sold out. Let the production begin.
2021.1.6 Too busy to update production, packing and shipping progress. Anyway, 96% of the orders have been shipped.
2021.2.2 Too busy to update again...anyway, all orders shipped.
« Last Edit: Tue, 02 February 2021, 03:49:30 by Patrickwu »
NEO Element G67 Kit Groupbuy
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
approved
Offline Wonderfool
Hi, I'm dying to place an order but it appears that you have an SSL cert configuration issue at https://www.neokeys.net :
Code: [Select]
$ curl https://www.neokeys.net/products/neo-palette-g67-keyboard-kit-1
curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to www.neokeys.net:443
Please let me give you my money.
Offline Patrickwu
Code: [Select]
It will be open for order on 23rd.
But I will look into the issue a bit later
Offline Patrickwu
Just a few more sample pics before launch
254250-0254252-1254254-2
254256-3254258-4254260-5
254262-6254264-7254266-8
254268-9
Offline norb
the top right one, is that flo green for all layers?
Offline Patrickwu
Yes that's all layer flo green, which is preset Jade.
Offline norb
Re: [GB] NEO Palette G67 - Gasket, Acrylic, customize color, 65% - Live Now!
« Reply #7 on: Thu, 22 October 2020, 22:13:53 »
thank you! i just joined!  :thumb:
Offline xMx_Miller
« Reply #8 on: Thu, 22 October 2020, 22:17:24 »
Should I get an email to confirm my order? Cause I did not get one.
Offline biscut
« Reply #9 on: Thu, 22 October 2020, 22:53:25 »
yes you should have gotten a confirmation email with your order number and other details
Offline GotamaHuy
« Reply #10 on: Thu, 22 October 2020, 23:32:41 »
How do we know if we are getting the lube station?
Offline rohitsc
« Reply #11 on: Fri, 23 October 2020, 00:13:09 »
Orders started at 1012 so if you are under 1062 you get a lube station
Offline RangerXML
« Reply #12 on: Fri, 23 October 2020, 01:33:24 »
Cool, besides getting a cool looking board I also got a lube station XD
I picked up the Thunder, though it was a tough choice, what you guys go for?
Offline forestar
« Reply #13 on: Fri, 23 October 2020, 01:39:20 »
My order number is 1070 and I didnt receive any confirmation mail. Will there be a problem with it?
Offline supermunny
« Reply #14 on: Fri, 23 October 2020, 01:42:26 »
I contemplated between Thunder and Abyss for matching with GMK Hammerhead, decided to go with the darker Abyss in the end. Now I'm wondering if the bottom frosted black layer lets the underglow shine through or not though...
Offline GotamaHuy
« Reply #15 on: Fri, 23 October 2020, 02:25:24 »
No!!! I barely missed it lol. Oh well, I went with abyss. Can’t wait to see the board in person!
Offline Patrickwu
« Reply #16 on: Fri, 23 October 2020, 03:02:29 »
DM me at discord.
I checked your order status everything looks normal though.
Offline wakeboarder1090
« Reply #17 on: Fri, 23 October 2020, 04:43:06 »
Super excited I was able to get in on this board purchase. Hardest part was choosing from all the color combination. Can't wait for this to arrive!
Offline mlacabrera
« Reply #18 on: Fri, 23 October 2020, 04:55:16 »
Excited! hardest part was choosing a preset or make a custom.
Offline forsee
« Reply #19 on: Fri, 23 October 2020, 05:51:38 »
YES! Got in to the GB :D
Just curious if in the future we'll be able to buy individual layers to change the color of our board?
Offline Patrickwu
« Reply #20 on: Fri, 23 October 2020, 06:59:42 »
yes, eventually yes.
Offline marshskitow
« Reply #21 on: Fri, 23 October 2020, 09:38:31 »
Same deal for me ahah. What did you choose ?
Envoyé de mon iPhone en utilisant Tapatalk
Offline CobraLi
« Reply #22 on: Fri, 23 October 2020, 22:49:28 »
It was hard to choose between abyss and Thunder but I went with the latter, so excited! Can't wait for it to arrive!
Offline MP2972
« Reply #23 on: Tue, 27 October 2020, 11:09:34 »
I ordered mine 3 days ago, haven't received anything. I wrote my phone number for contact information
« Last Edit: Wed, 28 October 2020, 13:27:58 by MP2972 »
Offline shima
  • keeb weeb
« Reply #24 on: Tue, 27 October 2020, 12:56:22 »
pretty excited on getting mine for a first custom keyboard
boards: anura
Offline Patrickwu
« Reply #25 on: Thu, 29 October 2020, 03:19:18 »
DM me your email address and name please.
Offline hottrout
  • I'd Hit Dat Key
Re: [GB] NEO Palette G67 - Gasket, Acrylic, customize color, 65% - Sold Out
« Reply #26 on: Thu, 29 October 2020, 04:22:09 »
I so missed out.  Well done to everyone that got in. :(
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Patrickwu
Re: [GB] NEO Palette G67 - Gasket, Acrylic, customize color, 65% - 96% shipped
« Reply #27 on: Wed, 06 January 2021, 09:50:09 »
96% of all orders have been shipped.
Some orders are delayed due to missing or damaged components from manufacturer. Replacement arriving in a couple more days and all orders will be fullfilled by the end of this week.
Next project to start soon. Palette Carbon G67 https://geekhack.org/index.php?topic=110383.msg2997681#msg2997681
« Last Edit: Wed, 06 January 2021, 09:55:19 by Patrickwu »
