Author Topic: [IC] Tsukuyomi - 65 + macro column (GB Thread is up)  (Read 78373 times)
Offline persocom
« on: Thu, 22 October 2020, 09:31:47 »
GB Thread is now live!
Hi, I'm persocom.  Here is a keyboard.
TSUKUYOMI - A 65% With Left Macro Column
Fill out the GOOGLE FORM here
HISTORY
I started on this a full year ago and posted the initial prototypes on Reddit in January.  (this post)
This was originally made to be a one off for myself since it was the perfect layout for me to use at work.
I had some interest from a handful of people that saw it so I was going to run it privately at first.  After ordering 3 different prototypes during Q1 of 2020,
I decided to not risk handling any kind of group buy on my own and let someone with more experience and resources take it over for me.
Cannon Keys expressed support for the project shortly after I shared the original photos, and I have been working closely with them since May to make this a public group buy.
In regards to the name:
There really isn't much of a grand meaning or reasoning here.  I grew up watching anime in the late 90s - early 2000s.
There was an abundance of soft colors, fine lines, and crescent moon/night sky imagery that gives me heaps of nostalgia when looking back at it.
The name "Tsukuyomi" exists in different contexts between media and religion, but the name of the board was pulled directly from the manga Tsukuyomi: Moon Phase.
It was the first thought in my head.  That's it.
SPECS
7 degree typing angle
~19mm front height
Top-mounted plate (includes o-rings for optional burger mounting)
Choice of WK and WKL top pieces
Internally mounted pass-through style sandblasted brass weight with internal engraving (see Prototype section below)
Aluminum is the only case material that will be offered.
Color options we are currently considering include: Navy, White, Black, Lilac.
Other CannonKeys releases are probably a good reference for Lilac and Navy.
Please see the Google Form above for more information about color options.
Render by snurrebassen.
PCB INFO
The PCB for this kit was designed by Upas
ARM MCU, STM32 based
Per Key LED support
QMK/VIA compatibility
ESD protection
South-facing switches
No hotswap avail
Note: Underglow is not supported as all units will be aluminum
The plate and pcb support ANSI and ISO layouts as well as Standard or 7U bottom row.
See below for all potential layouts.
Current plate materials include:
Anodized Aluminum
Sandblasted Polycarbonate
Sandblasted Brass
Carbon Fiber
FR4
Plate files will be released once the GB is completed for anyone who wants other materials.
PROTOTYPES
The 4th and final run of prototypes are functional with only a few adjustments needed:
- The blockers are a tad bit aggressive. I widened them thinking that smaller gaps would be cleaner, but the spacing inconsistencies bug me, and the reduced space could cause clearance problems for keycaps that might have a larger footprint than GMK.  I already know what size I need them to be so this is an easy fix.
- I want to give the burger mount cutouts a little more room for the o rings to compress.  I'll post some pictures of those cutouts as they are soon, so people who are unfamiliar with burger mount can get an idea. Currently they don't have much space to compress so you can't really "tune" them as much as you should be able to.
- USB hole - It turns out the USB hole was not the problem!  The proto PCB port was hand soldered, and I was able to straighten it out.  I'll post an updated picture when I get a chance.
Note: These will be hex screws in the production run.
Here's a quick sound test I recorded to hold people over until we get a better one:
Lubed H1s
Aluminum half plate (files available after GB)
No sound dampening
Typing test with various keycap profiles by Minterly
TO DO:
Interest Check
Make adjustments from the last prototype
Finalize pricing, quantity, colors, materials, extras, etc.
Proxies, proxies, proxies!
Group Buy - November 28th 11AM EST - December 4th
Production
QC and Shipping
For updates, continue to follow this thread or join the Cannon Keys discord server: https://discord.gg/PWWGEwv
I also have a server now: https://discord.gg/f8XDxEWdf5 (please bear with me, it's a work in progress)
SPECIAL THANKS
Upas for supporting the project, designing the final PCB, and making it possible for me to get this out to public.
Drew Rios for designing the weight engraving and other emblems/branding.
snurrebassen for input and helping me out with renders while I was still getting prototypes made.
Kilgarah for tons of design chat and designing the original prototype PCBs and FR4 plates.
Everyone in the Tsukuyomi private GB server for being into this enough to convince me to run it.
« Last Edit: Wed, 23 December 2020, 14:33:13 by persocom »
Offline Deadlcck
« Reply #1 on: Thu, 22 October 2020, 09:33:56 »
This is a super sick layout and love to see Lilac :) GLWIC
Offline persocom
Re: [IC] Tsukuyomi - 65 + macro column
« Reply #2 on: Thu, 22 October 2020, 09:34:57 »
GB UPDATE
The groupbuy will run from November 28th to December 4th
Extras will be available for the whole duration even if the case units sell out sooner.
There will be 300 units TOTAL.
PRICING
Base kit - $440 + shipping
The base kit includes:
-Case top (Choice of WKL or WK) and bottom (Aluminum - Black, e-White, Lilac, Navy)
-Weight with internal engraving and badge insert (Sandblasted brass with protective coat)
-Plate (Sandblasted aluminum - Black)
-PCB
-All screws needed to assemble the keyboard
-O-rings for optional burger mounting style
-Custom case feet (these will not be the bumpons shown in the prototypes)
-CannonKeys carrying case with custom foam to fit Tsukuyomi
(for reference, see the small variant of these)
EXTRA PARTS
PCB - $45
Aluminum Plate (Black) - $45
Polycarbonate (Sandblasted) - $45
Carbon Fiber Plate - $40
FR4 Plate - $25
Brass Plate (Sandblasted) - $50
PROXIES
CannonKeys - North America
protoTypist - UK/Europe
ILUMKB - AP/China
DailyClack - Australia
Another reminder that we do have a discord server now.
I'm a bit more active there if you have questions.
ONGOING PHOTO UPDATE POST
I straightened out the USB port with a little heat and this looks much better than the rear photo in the main post.
This shouldn't be an issue with production PCBs.
It's also worth noting that I have the burger mount o rings installed currently, so that will contribute to the port not sitting at dead center.
Navy Tsukuyomi
Lilac Tsukuyomi
« Last Edit: Fri, 27 November 2020, 10:02:38 by persocom »
Offline persocom
« Reply #3 on: Thu, 22 October 2020, 09:36:06 »
Thanks so much!
Offline ilikerustoo
« Reply #4 on: Thu, 22 October 2020, 09:37:29 »
Was waiting for this. I'll take it
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #5 on: Thu, 22 October 2020, 09:37:39 »
Following  ;D Finally!
Offline ddrfraser1
  • RIP Neil
« Reply #6 on: Thu, 22 October 2020, 09:38:00 »
Very attractive. Me likey. left f-rows are the bomb. Would you consider 10u sb compatibility?
Offline yoniwolf1202
« Reply #7 on: Thu, 22 October 2020, 09:48:50 »
I would like one. Kthxbye
Offline SleepIsAllINeed
« Reply #8 on: Thu, 22 October 2020, 09:56:00 »
Been following since the prototype photos. Happy to see it reach IC. :thumb: Definitely in.
Offline Kasterborous
    • HEX Keyboards
« Reply #9 on: Thu, 22 October 2020, 11:38:34 »
Nice, clean design, love it. Hope i can snag one for myself :) GL with everything!
Offline Penguindropings
« Reply #10 on: Thu, 22 October 2020, 11:40:50 »
I'm in.
Offline Insanecamo
« Reply #11 on: Thu, 22 October 2020, 11:41:11 »
Very nice  :)
Offline zoo
    • zoo
« Reply #12 on: Thu, 22 October 2020, 11:41:38 »
Solid layout. Wantttttt :D
Offline spedywin
  • Formerly spedywin
« Reply #13 on: Thu, 22 October 2020, 11:45:01 »
damn this layout is nice, but the money is nowhere to be found  :thumb:
Offline wholean
« Reply #14 on: Thu, 22 October 2020, 11:45:56 »
Polycarb plate!  ;D
Offline FaIIen
« Reply #15 on: Thu, 22 October 2020, 11:46:06 »
NARTUOOOO
Offline the1q
« Reply #16 on: Thu, 22 October 2020, 11:46:21 »
Nice board. No hotswap is a bummer.
Offline NathanCVII
  • Weeb I am
« Reply #17 on: Thu, 22 October 2020, 11:47:16 »
Reserved?
Oooof, someone beat you to it.
Offline self
« Reply #18 on: Thu, 22 October 2020, 11:52:01 »
Looks interesting, filled the form.
Are you planning to have proxies in EU?
What type of sale you want to do? (FCFS/Raffle/Unlimited/etc)
Sent from my ONEPLUS A5010 using Tapatalk
Offline mrpetrov
« Reply #19 on: Thu, 22 October 2020, 11:53:25 »
So pleased this is going forward! You know I’m in man.
Offline VXQN
« Reply #20 on: Thu, 22 October 2020, 11:58:59 »
Lovely board! Great proportions, cute blocker, and a macro column, what more could you want?
Offline Pach
« Reply #21 on: Thu, 22 October 2020, 12:00:06 »
very clean I like it
Offline f1
« Reply #22 on: Thu, 22 October 2020, 12:03:20 »
Loving the layout. Count me in!
Sent from my smartphone, which I have. Case, charger, everything.
Offline o3okevin
« Reply #23 on: Thu, 22 October 2020, 12:09:24 »
cool stuff, i like
Offline kim.on.coffee
« Reply #24 on: Thu, 22 October 2020, 12:10:36 »
omg this is amazing and would go so well with DSA magic girl keycaps.
I legit just signed up to geekhack just so I could express interest in getting this board.
I'd be over the moon if you could make a dark purple, mint, or subtle pink color somehow.
Offline sirieous
  • help
« Reply #25 on: Thu, 22 October 2020, 12:11:18 »
Definitely going to keep an eye on this. Good luck with the sale!
« Reply #26 on: Thu, 22 October 2020, 12:28:39 »
looks great, cant wait!
Offline MOON
« Reply #27 on: Thu, 22 October 2020, 12:33:02 »
My name is MOON, and I shall buy this.
Offline TacoSausje
« Reply #28 on: Thu, 22 October 2020, 12:47:35 »
Moon = Yes
Offline ligongduck
« Reply #29 on: Thu, 22 October 2020, 12:48:34 »
Lilac would be fire on this board.
Offline El_Jackador
« Reply #30 on: Thu, 22 October 2020, 12:51:26 »
WKL TOO!? Ekkkkkk
Offline japanesehorrorwriter
« Reply #31 on: Thu, 22 October 2020, 13:03:00 »
So good.
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #32 on: Thu, 22 October 2020, 13:11:05 »
Oh wow! Good job! nice amount of proots, awesome design!
Maybe a sound test and color cards for lilac and red. With the gb in Nov it would be nice to see that that is straightened out.
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline oxygenplug
« Reply #33 on: Thu, 22 October 2020, 13:13:30 »
dear god please I need this
Offline Casserole
« Reply #34 on: Thu, 22 October 2020, 13:18:29 »
Gah, this is too beautiful! Absolutely in! Would love to see this in yellow!!
Offline Casserole
« Reply #35 on: Thu, 22 October 2020, 13:20:09 »
Not even gonna try for the Iron now, saving my money for this freaking masterpiece
Offline persocom
« Reply #36 on: Thu, 22 October 2020, 13:50:33 »
Thank you all for the kind words so far!  My day job has been especially demanding lately so I'm trying to pop in when I can to address any questions!
Proxies are highly likely! Upas and I are actually discussing that currently so I'll update with a list as soon as I know who will be involved
Sale type will be FCFS, and I can probably give better details once the proxy situation is sorted
Thank you! Good news actually, Upas has Lilac and Navy Tsukuyomi protos on hand, as well as a different board from the same manu that should give a good idea of a potential Red option.
Those should be getting assembled once we get another order of PCBs done.  I don't have a great setup for typing tests at the moment (plus I built with silent switches), but expect a sound test before the GB is live.  I'll post those color references as soon as he sends me pictures (probably later today)
Offline Kinesiologist
« Reply #37 on: Thu, 22 October 2020, 13:58:55 »
this is beautiful, looking forward to hearing more :D
Offline ljyel
  • gamecube
« Reply #38 on: Thu, 22 October 2020, 14:03:21 »
me: A man of culture reading the name for first time.
Madara/Obito: Infinite Tsukuyomi
Love the macro on the left! GL
« Last Edit: Thu, 22 October 2020, 14:11:34 by ljyel »
Keyboards: Think6.5v2 | Plume65 | Aurora Input Series 65 | Vega | Vertigo
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #39 on: Thu, 22 October 2020, 14:05:29 »
Stunning layout.  Traditional 65% always looked too "right-side" heavy, but this macro column balances things out so nicely.
Offline YoRHannya
« Reply #40 on: Thu, 22 October 2020, 14:15:41 »
Love the left macro and just a great design all around. I'm all in for this
Offline paperassgasket
« Reply #41 on: Thu, 22 October 2020, 14:28:38 »
love the edges, love the badges, love the acoustic cutouts on the plate, and love the VIA support.
This one ticks a lot of boxes.
Do you have / Can you share PCB pics?
Offline persocom
« Reply #42 on: Thu, 22 October 2020, 14:59:16 »
Really glad to hear it!
The current proto PCBs are super plain, but we're ordering some more since we only have 2 right now.  The next set will actually have all of the production art on it, so once we get those I'll drop some photos!
Offline jiggyboybrian
  • Darling!
« Reply #43 on: Thu, 22 October 2020, 15:09:21 »
I really like it, hopefully the lilac colorway stays for the groupbuy!
Offline NaviUy
« Reply #44 on: Thu, 22 October 2020, 15:44:01 »
What a beautiful board! ME and my friend saw a render on it a few days ago and was wondering what it was! WE FOUND IT! Highly interested!
Offline TopreMoon
« Reply #45 on: Thu, 22 October 2020, 16:05:44 »
Ah - I love it!
Offline hkhawk
« Reply #46 on: Thu, 22 October 2020, 17:58:07 »
I remember seeing your protos on r/mk and saying how good they looked. Excited to see this reaching IC, congrats!
Offline mikeyboyy
« Reply #47 on: Thu, 22 October 2020, 18:00:44 »
the images of the black and white board look so good
Offline skrunk
« Reply #48 on: Thu, 22 October 2020, 18:34:02 »
remember seeing this when it was first posted
glad to see you moving on with an ic
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline jpg2401
« Reply #49 on: Thu, 22 October 2020, 19:48:25 »
Definitely interested!
Savage 65 | GSKT-00 || Valhalla | X60 V2
