Author Topic: [GB]SP SA Silent Assassin GB Live! | [ Now - Jan 30th]  (Read 26484 times)
Offline Triple Tension
« on: Fri, 06 November 2020, 09:59:46 »
Venders
US:Kono
CA:Deskhero
EU:Candykeys
OCE: Daily Clack
Asia: Yutop
For non-Asian regions, group buying will start on December 15. Until mid-January 2021.
[/b]
[/b]
[/b]
Hello, everyone.
This time, Triple Agency brings you a dark theme keycap design.
Inspired by Agent 47.
47 is a human clone made by Dr. Ort-Meyer, benefiting from the extraordinary physical stamina brought by genetic engineering and the rigorous training he has received since childhood. He is good at assassination and is currently the world's top assassin.
255450-0
Silent Assassin is one of the level evaluations, which can be completed under the premise of "only kill the target without being discovered".
Signature Plastic is the manufacturer this time, and the keycap height is set to the classic SA height.
First of all, I put a rendering as a display.
255452-1
255547-2
255549-3
Base Kit
255454-4
Alpha
255456-5
Numpad
255458-6
Extension
255460-7
Novelties
255462-8
7x Spacebars
255464-9
There are more keys involved in the new mold opening this time, so the cost will inevitably increase, which will lead to a slightly higher final price.
We are still communicating with manufacturers, and prices have to wait for their latest news.
The final Kit may be changed, subject to the actual final version.
Google Sheets will be released later.
Contact Us
QQ Groups: 1140462315
Thx.
« Last Edit: Sun, 24 January 2021, 11:47:16 by Triple Tension »
Banjitino.
Offline yoot
    • none
Re: 123123
« Reply #1 on: Fri, 06 November 2020, 10:00:58 »
Interesting....
Offline powwu
    • Discord
Re: [IC]SP SA Silent Assassin
« Reply #2 on: Fri, 06 November 2020, 10:02:11 »
Not sure what 123123 is, but this set looks pretty cool. GLWIC
Offline JoltFX
« Reply #3 on: Fri, 06 November 2020, 10:03:18 »
I really like the aesthetic here just don’t like SA, GLWIC
“𝙁𝙖𝙞𝙩𝙝 𝙞𝙨 𝙩𝙝𝙚 𝙗𝙞𝙧𝙙 𝙩𝙝𝙖𝙩 𝙛𝙚𝙚𝙡𝙨 𝙩𝙝𝙚 𝙡𝙞𝙜𝙝𝙩 𝙬𝙝𝙚𝙣 𝙩𝙝𝙚 𝙨𝙠𝙮 𝙞𝙨 𝙨𝙩𝙞𝙡𝙡 𝙙𝙞𝙢.”
Offline Hydroxide
« Reply #4 on: Fri, 06 November 2020, 10:15:33 »
Came here to say exactly this lmao
Sent from my SM-G973U using Tapatalk
Re: 123123
« Reply #5 on: Fri, 06 November 2020, 10:21:14 »
Banjitino.
Offline nasp
« Reply #6 on: Fri, 06 November 2020, 14:38:37 »
Mini bars or 40's kits would be nice, esp with SP's low MOQs
Edit: what's the other new mold in the mod kit? Obviously the novelty enter text is one and the other?
« Last Edit: Fri, 06 November 2020, 14:40:28 by nasp »
Offline IOVERCALLHISTIOCYTES
« Reply #7 on: Fri, 06 November 2020, 15:41:12 »
Is ‘exit’ the other mold? Maybe that exists.
Speaking of molds...didn’t Oblotzky make ASCII for SP SA Oblivion II? If he’s ok with you using ASCII, perhaps ask if you can use the molds?
Offline kajahtaa
« Reply #8 on: Fri, 06 November 2020, 16:25:40 »
Would love R3 uniform RAS & NN
Offline konstantin
  • Formerly constexpr
« Reply #9 on: Fri, 06 November 2020, 17:33:49 »
Consider shifting some of the keys around between the alpha, mods and extension kits; specifically, the 1.5u bottom row mods, 1.75u Shift, spacebars etc. See how SA Espresso did it:
There is a very good reason for why you'd want to do it like this, which I explain in this post (and, in particular, the image linked therein).
As far as the spacebars go, since most users are going to need both 6.25c and 7c, I suggest putting the default alpha-colored (black) 6.25c in alphas and 7c in mods (like in the above images), rather than how you currently have it set up with separate kits. You can then put the mod and accent-colored spacebars together with small spacekeys (2u, 2.25u, 2.75u etc.) in a separate spacebars kit.
« Last Edit: Fri, 06 November 2020, 17:36:45 by konstantin »
Offline krzank
« Reply #10 on: Fri, 06 November 2020, 18:32:02 »
Is ISO possible?
With R4:Pipe/Backslash & R3:Tilde/GraveAccent ?
Offline pool
« Reply #11 on: Fri, 06 November 2020, 21:08:55 »
Good luck with the set! But I am a little concerned with IP in that you literally have Hitman in the novelty. There's an IP gray area, but this one seems to have stepped a little far. But I'm not an IP lawyer.
Offline Swishy
« Reply #12 on: Fri, 06 November 2020, 21:09:56 »
So I noticed you said this set was inspired but I can't help but notice the "Hitman" novelty which makes me worried about it being C&D. Might wanna rethink that one but I do like this set. GLWIC! Also I don't know you have read the art instruction they give out but some of these novelties look like they will need to be tweaked. If you don't have the art instructions I would be happy to share with you just DM me.
« Reply #13 on: Sun, 08 November 2020, 08:34:13 »
40% is not involved this time. ASCII legends uses a new mold. :)
Banjitino.
« Reply #14 on: Sun, 08 November 2020, 08:36:30 »
The ordinary ESC is included in the Numpad Kit.
How can I contact Oblotzky? Do you have his contact information? Such as mailbox?
Thx.
Banjitino.
« Reply #15 on: Sun, 08 November 2020, 08:45:49 »
What is "R3 uniform"? ;)
Banjitino.
« Reply #16 on: Sun, 08 November 2020, 08:51:43 »
Thanks for your advice.
Because I don’t know whether the purchase amount can meet the minimum requirement, I combined ASCII and Modifer into Base Kit, which contains 6.25x spacebars of all colors. 7x spacebars became a separate Kit.
Banjitino.
« Reply #17 on: Sun, 08 November 2020, 08:57:21 »
Is ISO possible?
I have updated the Extension kit. But it may not be exactly the same as what you described.
Banjitino.
« Reply #18 on: Sun, 08 November 2020, 08:59:55 »
Thanks for your advice. I have cancelled the Enter Key with the "Hitman" style. :)
Banjitino.
« Reply #19 on: Sun, 08 November 2020, 09:08:14 »
Thanks for your advice. I still have some questions.
What does "C&D" mean? I have cancelled the Enter Key with the "Hitman" style. Do other keys in the Novelties Kit also need to be adjusted? :)
Banjitino.
« Reply #20 on: Mon, 09 November 2020, 07:35:09 »
Hello, everyone.
Base Kit
Alpha
Numpad
Extension
Novelties
7x Spacebars
Contact Us
Thx.
Rendering images have been updated.
Banjitino.
Offline ddrfraser1
  • RIP Neil
« Reply #21 on: Mon, 09 November 2020, 07:48:43 »
pass
Offline krzank
« Reply #22 on: Mon, 09 November 2020, 14:47:19 »
Is ISO possible?
I can live (barely) with R3:Tilde/Hash as a replacement for R3:Tilde/GraveAccent but can't live without R4:Pipe/Backslash :-(
Pretty set anyway.
Offline PandamanPete
« Reply #23 on: Tue, 10 November 2020, 00:55:16 »
Looks great, the kits aren't my favorite though. A more standard set of Alphas, Alt Alphas, modifiers, numpad, novelties, ISO, spacebars, and 40s/ortho or something would be nice. Good luck with the IC, I'll be watching for sure.
« Reply #24 on: Tue, 10 November 2020, 01:07:11 »
Thx.
Here’s Oblotzky’s interest check for SA Oblivion R2 where the ASCII molds were made for SP SA. You can DM him here on Geekhack.
Offline Tyson
« Reply #25 on: Mon, 23 November 2020, 22:25:05 »
Nice
Offline pol139
« Reply #26 on: Tue, 24 November 2020, 02:49:22 »
Awesome I like it :-*
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #27 on: Tue, 24 November 2020, 04:38:49 »
I don't understand the context of those ASCII legends and its relationship with Agent 47.
Reserved.
Offline nathanchere
« Reply #28 on: Tue, 24 November 2020, 05:32:53 »
Putting forced sublegends on the base kit is a frankly stupid idea. Especially when:
a) they have a very specific theme which has nothing to do with the very specific theme of the overall set
b) the contrast between base and legend colours is so low as to make it a mess to all but the most eagle-eyed
c) there's no option to get the mods/etc without getting the base kit
Comparisons to other similarly red/black kits like Sanctuary are also inevitable. Brace yourself.
The only As much as I like Hitman I couldn't be any less interested in this. I would possibly consider buying just the novelties but that's it.
Offline donny_pete
« Reply #29 on: Tue, 24 November 2020, 10:29:46 »
I'm right there with you. In my personal opinion, I can't see the aesthetic nor appeal towards SA
Offline walletburner
  • Formerly wokechill
« Reply #30 on: Tue, 24 November 2020, 12:53:25 »
would love to see Extension have proper 40% coverage; right now it's most of the way there but lack of split spacebars, R2 esc, 1.75u enters, etc have me out. would love to put this on a bushido red Cajal. help me obi wan kenobi, youre my only hope at a (good) Hitman set.
Re: [GB]SP SA Silent Assassin
« Reply #31 on: Thu, 17 December 2020, 22:50:26 »
Venders
US:Kono
CA:Deskhero
EU:Candykeys
OCE: Daily Clack
Asia: Yutop
[/b]
[/b]
[/b]
Hello, everyone.
Base Kit
Alpha
Numpad
Extension
Novelties
7x Spacebars
Contact Us
Thx.
Group buying is in progress.
Banjitino.
Offline Havattack
« Reply #32 on: Fri, 18 December 2020, 11:41:43 »
This made me want a Metal Gear Solid/ Fox Hound theme set..
Edit: I found one (just do google search) but i was kind of meh, meh.
« Last Edit: Fri, 18 December 2020, 11:43:34 by Havattack »
Offline Buffo
« Reply #33 on: Sun, 03 January 2021, 21:28:09 »
Hi, i want to buy From the EU, but candykeys does not List this Set?
Offline SoTh
« Reply #34 on: Mon, 11 January 2021, 13:41:10 »
Hello, i want to buy from the EU at candykeys is possible to make a preorder at the beginning of February, or pre-order closes at the end of January?
Thanks
Offline Buffo
« Reply #35 on: Wed, 20 January 2021, 11:47:12 »
Better ask candykeys directly. They just posted here because of range, i think. But aren't looking anymore.
Offline SoTh
Re: [GB]SP SA Silent Assassin GB Live! | [ Now - Jan 30th]
« Reply #36 on: Sun, 24 January 2021, 15:41:33 »
Thanks Buffo, The Candykeys have put a countdown clock in the purchase group, I will order the alphas that are the ones I like the most, red and black, my favorite color, and I will look for some modifiers that go together.
Offline pixelpusher
« Reply #37 on: Sun, 14 January 2024, 17:41:06 »
Necro.
Does anyone actually own this set? I cannot find a real image of the keycaps anywhere.
Offline gaustin
« Reply #38 on: Mon, 15 January 2024, 00:34:41 »
It does exist! It's a neat little set.
Offline pixelpusher
« Reply #39 on: Mon, 15 January 2024, 13:40:20 »
TYSM!  It looks great!
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #40 on: Tue, 12 March 2024, 05:14:17 »
Apparently Kono still has this set in stock https://kono.store/collections/in-stock/products/sp-sa-silent-assassin
To cop or not to cop?  :p
Offline pixelpusher
« Reply #41 on: Tue, 12 March 2024, 08:09:36 »
I picked up a set a while back from Apos.  They sell some of Kono’s stuff with free shipping.  It’s nice but it’s not a favorite set by any means.   The red is hard to describe.  It’s not bright, it’s not blood red… it’s almost like ketchup.  The alphas have more swirling on them than most of my other SA sets.  I don’t mind it, but some may.  The one thing I don’t like is how the thinner font of the dual alphas kinda gets lost on the black.  I’m using the single alphas because of it.
If you love to collect SA keycaps, this is a fine choice.  But I really feel like the single alpha set looks best, making the set more costly than it deserves to be.
306546-0306548-1306550-2
« Last Edit: Tue, 12 March 2024, 08:11:17 by pixelpusher »
« Reply #42 on: Tue, 12 March 2024, 22:47:13 »
thank you for the detailed impression/review. There's a 'Checkout with Apos' button on the listing on Kono as well so that's why I'm somewhat tempted. The 3rd/angled photo makes the set looks really good though, probably the light hitting it just right? But yeah I agree on the red legends being lost out in the NN black, not enough contrast IMO. I bet it would pop a lot more if the legend were white (WFK/WCK)
