Author Topic: 3D printed gaming mouse  (Read 11707 times)
Offline piranhamousemods
« on: Mon, 16 November 2020, 19:27:48 »
I 3D printed a new shell for my Logitech G305. The shape is copied from the Endgame Xm1
Offline jamster
Re: 3D printed gaming mouse
« Reply #1 on: Tue, 17 November 2020, 01:02:22 »
Hah, that is great! Is it hard to get a smooth finish with 3D printing?
Offline vvp
« Reply #2 on: Tue, 17 November 2020, 05:37:08 »
That shell actually looks like it may be a good idea. Less sweating and one possibly can clean the dirt accumulated inside with vacuum cleaner or compressed air. Well, there may be problem with accumulating of a sticky mixture of sweat, dust and dead skin fragments from the inside near the hole openings. So occasional disassembly for cleaning may still be needed.
Anyway I like it.
Offline Crabby
« Reply #3 on: Fri, 04 December 2020, 04:39:39 »
Anyway I like it.
The idea I believe is to reduce weight I believe.
Offline cheater
« Reply #4 on: Wed, 16 December 2020, 18:03:51 »
have you considered a new controller for it? I wonder if QMK could do the job.
Offline moosekeyboards
« Reply #5 on: Sat, 19 December 2020, 09:21:26 »
that looks like it let's you breathe super nice
Offline jsnow77
« Reply #6 on: Tue, 29 December 2020, 12:22:11 »
This is very cool idea and would be a great way to get a customized mouse for your hand/grip. I am wondering about would different materials in the printer promote different textures and finishes for the shell? I prefer glossy mice and I might have to try printing a shell at my university's printer because this seems like a great idea.
Offline Leslieann
« Reply #7 on: Wed, 30 December 2020, 06:40:08 »
Not just different materials.
Layer height, type of printer, temp, print speed or even the filament brand can alter the surface finish of a 3d printed object and that assumes the same type of plastic. There's many types of plastic, a few adatives like carbon fiber, wood and metals and then you get blends like Polycarbonate/ABS mix.
PLA can feel smooth line shined ABS caps or rough PBT but very hard, Nylon tends to feel softer, PETG feels waxy.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
