Author Topic: [IC] NORU TKL  (Read 12055 times)
Offline jmSur
[IC] NORU TKL
« on: Tue, 17 November 2020, 11:51:14 »
[ NORU TKL ]
A TKL with 88 layout
[Specification]
•  Typing angle: 7 degrees
•  Material
    - Upper case: Alu 6061
    - Bottom case: Alu 6061
    - Weight: Coated brass with hairline finish or ALBC Grade 3 with Sandblasted finish or Gold plated brass
• TKL Layout with F13
• WK and WKL
• Weight: 3.38 Kg
•  Aluminum plate. Will support stepped caps, ANSI/ISO, Screw-In-Stabs
•  Mounting style TBD -> am going to apply quite different mount
•  PCB - H88C
•  Colour: NOT fixed yet. The top case and plate will be same colour. Bottom case will be silver, black or gray.
•  Either anodizing or paint coating(have developed new kind of special paints)
•  GB: Feb or March 2021
•  Max Quantity: TBD, depends on the IC
•  Estimated Price: TBD (will try to make it low as possible without degrading the quality)
•  Ships worldwide
Detailed info can be found on below discord server.
•  Discord : https://discord.gg/7gDtxzNq4g
[Other Information]
My other GB, Nyaong75 is currently on-going without any problem.
No delay to schedule so far.
The prototype of Nyaong75 will be manufactured soon.
The manufacturer is preparing for the prototype and mass production.
Packaging design is on-going too.
I have ordered to PCB designer for Nyaong75 PCB.
The Brick65, I have got quotes from the manufacturer, but as the cost for cnc machining is high
(many curves and rounds here and there, lot of parts and too long machining time),
I and the manufacturer are pondering to lower the manufacturing cost.
With current quotes, the final price will be 600USD with moq of 500.
Am not sure if this price is reasonable or not. So, give me some more time.
Thank you for reading my thread.
Hope many of you are interested on my keyboard.
« Last Edit: Sat, 21 November 2020, 04:00:07 by jmSur »
Offline Kinesiologist
Re: [IC] NORU TKL
« Reply #1 on: Tue, 17 November 2020, 11:57:05 »
Looks great, is it possible to choose the same color for the top and bottom case?
Offline IOVERCALLHISTIOCYTES
Re: [IC] NORU TKL
« Reply #2 on: Tue, 17 November 2020, 12:14:14 »
Like that navy blue
Offline kohalified
Re: [IC] NORU TKL
« Reply #3 on: Tue, 17 November 2020, 12:24:18 »
interesting.
Offline jmSur
Re: [IC] NORU TKL
« Reply #4 on: Tue, 17 November 2020, 12:41:26 »
Will consider that + will make a poll on my discord.
Offline Jefff
    • jlabs.co
Re: [IC] NORU TKL
« Reply #5 on: Tue, 17 November 2020, 13:28:26 »
Will the gold plated brass be actual gold? If so, any estimate on how much that will cost?
Offline ubmit
Re: [IC] NORU TKL
« Reply #6 on: Tue, 17 November 2020, 15:34:18 »
Looks good! GLWIC! Being able to match top and bottom colors would be nice
Lyn Whale | KFE CE | Frog | Singa | Dolice | Haus | Kei | Polaris | Prophet | Bongoneko
Offline The Cat Whisperer
  • meowdy
Re: [IC] NORU TKL
« Reply #7 on: Tue, 17 November 2020, 16:12:41 »
Love that side curve and the small cat motif.
Offline marshskitow
Re: [IC] NORU TKL
« Reply #8 on: Tue, 17 November 2020, 16:19:04 »
You are "the cat man" now on.  ;D
Look really cool, and i think different color bottom/top is really nice. I'll keep a eye on this and hope its not too expensive.
Thanks cat man
Offline jmSur
Re: [IC] NORU TKL
« Reply #9 on: Tue, 17 November 2020, 17:08:30 »
Gold plating is the most expensive option and have requested for the quotes. But this is not decided yet. Am still looking for other options.
Offline jmSur
Re: [IC] NORU TKL
« Reply #10 on: Tue, 17 November 2020, 17:11:06 »
Yeah will consider that!
Offline EdgeOfInfinity
Re: [IC] NORU TKL
« Reply #11 on: Fri, 20 November 2020, 15:07:29 »
the first render looks very clean - would love to see it w/ keycaps now.
Offline jmSur
Re: [IC] NORU TKL
« Reply #12 on: Fri, 20 November 2020, 15:38:26 »
Planned to make the sample next(or next next) week.
I will show you the real one with keycaps, not the render.
Offline pixelpusher
Re: [IC] NORU TKL
« Reply #13 on: Fri, 20 November 2020, 23:36:09 »
Love the engraved border and the side view.  Wondering what you have in mind for mounting.  I'm looking forward to learning more.
Offline q83n87
Re: [IC] NORU TKL
« Reply #14 on: Sat, 21 November 2020, 01:12:07 »
Deleted
« Last Edit: Sat, 03 April 2021, 04:56:10 by q83n87 »
Offline jmSur
Re: [IC] NORU TKL
« Reply #15 on: Sat, 21 November 2020, 04:00:54 »
Is it made in Korea?
The discord invite link is not working.
Sorry for the inconvenience. Have modified the link.
And, yes, it is made in Korea.
Offline jmSur
Re: [IC] NORU TKL
« Reply #16 on: Sat, 21 November 2020, 04:02:03 »
Am going to make the sample next week, and if the new method works well I will tell you guys about it. Visot my Discord server
