Author Topic: New member, quick question  (Read 1795 times)
Offline badtypist
« on: Sun, 22 November 2020, 20:40:20 »
Hi everyone, just got in mech kb as a hobby. Recently just design a 60% case and would like to start a GB, really appreciate any tips on how to start one.  :'(
Offline yui
Re: New member, quick question
« Reply #1 on: Tue, 24 November 2020, 10:04:53 »
to be able to start a GB you need to be active for a bit longer, and also to have made quite a few other posts so by the time you get there you will have learnt quite a bit more, go and look at ICs and GBs currently running and ask questions to the runners (not all may answer or they may answer later as running a GB is quite a bit of work), you could also ask questions on the making stuff together for prototyping if you are not scared of sharing and maybe loosing a sale or two to guys with big 3d printers.
