Author Topic: [IC] Gateron Milk & Tea (Milky inks)  (Read 60607 times)
Offline yoot
    • none
Offline koe
Re: [IC] Gateron Milk & Tea (Milky inks)
« Reply #51 on: Mon, 30 November 2020, 17:19:43 »
can't wait for a sound test
Offline Kajoler
« Reply #52 on: Mon, 30 November 2020, 17:37:06 »
o thats v. cool
>:0
Offline Mistah
« Reply #53 on: Fri, 04 December 2020, 20:39:10 »
Any word on the molds? Are they using some of the degraded v2 tooling? Also love the dark one, but love gat yellow springs more, so the milk would be my pick.
Offline Amuaisi
« Reply #54 on: Fri, 04 December 2020, 23:06:06 »
I'm interested in these switches. I have a couple boards planned that would go with these colors, and I like matchy-matchy.
Offline oathsworn
« Reply #55 on: Mon, 07 December 2020, 19:41:06 »
Mega interested in the purple milk switch. Would cop 90 switches asap whenever you plan to go forward with it ^--^
Offline unknownh
« Reply #56 on: Tue, 08 December 2020, 01:56:29 »
Yes.
TGR-Jane v2
 | TGR X SINGA UNIKORN 60 | Duck TC-V3 | Geonworks F1.69 | EX: GS "GUGA" 60 | yoot Calliope - XTFRLWKLTKL | AEK64 SKCM Browns | unknown60 WKL (x2) | unknown60 WK (x2) | RAMAWORKS M65-A | RAMAWORKS KOYU | RAMAWORKS M60-A |HHKB Pro 2 Type-S | HHKB Pro 2
https://imgur.com/ntJaJ1c.png[/img]
Offline Scriba
« Reply #57 on: Wed, 09 December 2020, 03:18:33 »
I'm in if there are new molds. v2 inks are sometimes scratchy in bad batches.
Offline antx1701
« Reply #58 on: Wed, 09 December 2020, 17:10:50 »
You call it a cult, I call it a system of religious veneration and devotion directed toward a particular figure or object!
110 milk switches, please!
Offline kastymizilian
« Reply #59 on: Thu, 10 December 2020, 10:27:42 »
love the white one
Offline Sicowa
« Reply #60 on: Sat, 26 December 2020, 15:05:29 »
Plz Gib milky tops
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline CookieFlow
« Reply #61 on: Sun, 27 December 2020, 13:24:37 »
Definitely interested in the white ones
Offline despairsray
« Reply #62 on: Sun, 27 December 2020, 17:53:42 »
I'm guessing that the goal is for these to be as smooth as the inks? Either way, I am ready to buy x200.
Offline dRnRcRr
« Reply #63 on: Mon, 28 December 2020, 00:18:16 »
Whoa late to the party but 100% in
Offline dado brat
« Reply #64 on: Mon, 28 December 2020, 01:06:02 »
both look very interesting, definitely have an eye on these
Offline Poesjuh
« Reply #65 on: Mon, 28 December 2020, 01:53:33 »
Obligatory comment. I guess I should say;
reserved
Offline Koniotaur
« Reply #66 on: Mon, 28 December 2020, 01:54:23 »
Milk
Offline yoot
    • none
« Reply #67 on: Mon, 28 December 2020, 21:38:44 »
ne update avail
Offline NoxNoxNox
« Reply #68 on: Mon, 28 December 2020, 22:03:09 »
ne update avail
I have the same question.  Hopefully these do happen.
Offline BapoDonu
Re: [IC] Gateron Milk & Tea (Milky inks) Nylon top???
« Reply #69 on: Wed, 30 December 2020, 02:00:32 »
Update:
So I moved into the proto phase and I'm presented with an option of having nylon milky tops, I have not tried such a top but I thought it might be worth considering, so I would really appreciate if you could share your thoughts on the IC form or here. There isn't any major drawback if let's say I get the protos and I do not like the switch I can just go back to the normal milky top, that would just mean it will take more time to get another round of protos.
Offline Zanhana
« Reply #70 on: Wed, 30 December 2020, 04:11:08 »
if nylon top means the acoustics will have a lower pitch then please do nylon top
Offline GMK83
« Reply #71 on: Wed, 30 December 2020, 06:09:36 »
+1 to nylon top
Offline davisthegreat
    • 3DKeebs
« Reply #72 on: Wed, 30 December 2020, 08:24:29 »
Yes, dees purty. Vendors?
Offline Sicowa
« Reply #73 on: Wed, 30 December 2020, 08:42:40 »
Yes. Please do the nylon top. Give us all the thocc  :thumb:
Offline misswaffle
« Reply #74 on: Thu, 31 December 2020, 12:57:44 »
I love nylon.
Offline treeleaf64
    • treeleaf64
« Reply #75 on: Thu, 31 December 2020, 15:59:20 »
Update:
Yes yes yes yes yes YES YES YES YES yes Yes and Yes and Yes. ANd yes
tldr Yes
Everyone must pay the cat tax
Offline Emasterbro
« Reply #76 on: Thu, 31 December 2020, 16:48:52 »
Church of the Milky Top
Offline eaiCCZ
« Reply #77 on: Thu, 31 December 2020, 16:52:43 »
Update:
In summary, if I understood correctly, it would be nylon top and bottom and POM stem ?
Offline Lu1scr
« Reply #78 on: Sat, 02 January 2021, 13:02:11 »
Church of the milky top
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #79 on: Sat, 02 January 2021, 13:06:50 »
Update:
So regular milky tops are PC then? I was wondering about this since I got some all black KS-3 yellows, all milky KS-3 yellows, milk top/black bottom KS-3 yellows, & KS-8 (clear top/black bottom) yellows which all sound identical. I was thinking the milky & black tops would be made from a different material compared to the clear tops, but guess I was wrong. Also I agree with most others, go for the nylon variant!
Offline antx1701
« Reply #80 on: Sun, 03 January 2021, 00:03:06 »
Gimme those milky nylons.
Offline BapoDonu
« Reply #81 on: Sun, 03 January 2021, 00:40:01 »
Update:
Milky tops are a blend pretty sure no one knows what exact materials are used but I found out that FEI switches supposedly have nylon milky tops so I'm trying to get my hands on those so I can compare them to the normal milky tops.
Offline Rob27shred
« Reply #82 on: Sun, 03 January 2021, 08:23:31 »
Update:
Thanks for the response! I don't have any of the FEI Gats or I'd send some your way. Anyways let us know what you find out after you do get some!
Offline rt_es
« Reply #83 on: Wed, 06 January 2021, 06:18:12 »
Interested. Looking forward to a sound test and comparison(s).
Offline i luv chuletas
« Reply #84 on: Wed, 06 January 2021, 09:24:16 »
OOOh gotta love those colors man.
Def in for both, love the fact that you chose 'milky' inks!
Offline BapoDonu
« Reply #85 on: Thu, 21 January 2021, 01:30:09 »
Small update:
Managed to get some FEI switches that have nylon milky tops and tried them on the inks, compared to the normal milky top (black bottom milky top gaterons) its disappointing... On the other hand normal milky tops are very nice so I will be ordering protos with those. Still working on the comparison video will most likely wait until I get the protos.
Offline Sicowa
« Reply #86 on: Thu, 21 January 2021, 10:15:20 »
Small update:
 :thumb:
Offline CookieFlow
« Reply #87 on: Thu, 21 January 2021, 10:28:58 »
Thanks for the update.
I will probably just grab both colors in the end
Offline candravamsa
« Reply #88 on: Thu, 21 January 2021, 10:58:42 »
If nylon tops, then yes!
Offline despairsray
« Reply #89 on: Thu, 21 January 2021, 13:31:37 »
Small update:
I trust your judgement. Still buying x200
Offline MediocreTurtle
« Reply #90 on: Mon, 25 January 2021, 16:46:30 »
OP just said nylon tops are bad compared to normal milkies like two comments above
Offline CaptRiskyBiscuits
« Reply #91 on: Mon, 25 January 2021, 19:00:17 »
Oooh yes please
Offline Leo Yoco
« Reply #92 on: Mon, 25 January 2021, 19:39:26 »
double  cute  color ,mix they haha
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #93 on: Mon, 25 January 2021, 23:44:19 »
Definitely interested in seeing where this goes. Is 50g/60g springs set in stone? I'd be interested in 65g if possible
Offline BapoDonu
« Reply #94 on: Tue, 26 January 2021, 01:26:48 »
No not really, the 50/60g springs are just yellow/black springs just thought those would be the most familiar to people.
Offline CookieFlow
« Reply #95 on: Tue, 26 January 2021, 08:56:32 »
Personally I think those are good choices, especially yellow springs that are generally very well appreciated.
People can always just spring swap anyways.
« Reply #96 on: Wed, 27 January 2021, 12:21:45 »
Please do go with Gat yellow springs. Those are widely liked as stated above and it was a huge point of interest for me.
Offline prettydouchebag
« Reply #97 on: Wed, 27 January 2021, 18:52:08 »
This post convinced me to desolder my Ink V2 build, buy some full milky yellows, and disassemble/reassemble enough switches for a 60% JUST so see what all the fuss was about.
Absolutely worth it. I'll be in for a few hundred
Offline BapoDonu
« Reply #98 on: Wed, 27 January 2021, 21:53:41 »
My thoughts exactly.
a <3
Offline Zidnex
« Reply #99 on: Thu, 04 February 2021, 20:26:10 »
Count me in!
