Author Topic: Filco fkb104m/eb  (Read 2080 times)
Offline colbabe
Filco fkb104m/eb
« on: Sun, 01 August 2010, 18:54:17 »
Any suggestions on how to minimize the click-clack at the office; the board sits on a keyboard tray (metal) and if I can hear it through headphones I know my peers can; besides that it annoys me - seems the spacebar is clackier with a different tone/sound.
I like it but wish I'd held out for the Topre.
Thanks, all help appreciated.
Offline patrickgeekhack
Filco fkb104m/eb
« Reply #1 on: Sun, 01 August 2010, 19:05:23 »
Quote from: colbabe;208301
One thing I've noticed with us (mechanical keyboard users) is that we tend to be more concerned about disturbing others with our keyboard noise than if others are actually bothered. I used to think that my Dell AT101W with black ALPS was loud. Then one day, someone needed to use my computer for a few minutes. I went on the other side of my cubicle wall to listen to the noise level. It was actually pleasing to the ear and not as loud as I thought.
Lately, I've started to use my G80-3000 with blue Cherry at work. I asked my immediate cubicle neighbours who said that it did not bother them. They only notice it in the morning when I just arrived, but don't as time goes by.
Blue Cherry is louder than brown Cherry. But, the Filco has a metal plate which, as you said, can produce a clac sound. That said, the brown Cherry does not need a lot of force to fire. Try using a very light touch when typing. A  touch-and-go typing style. Once, you have developed such a style, the brown Cherry Filco will be a great keyboard to type on. I'm currently using one to type this message. Sliding a microfibre cloth under the keyboard can also help.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline colbabe
Filco fkb104m/eb
« Reply #2 on: Mon, 02 August 2010, 17:33:46 »
Quote from: patrickgeekhack;208308
Thanks ... I'll check out the touch-and-go typing style .. and the microfibre pad.  I'm still getting used to the keycaps so nows a good time to give it a go!   Thanks again . . .
Offline colbabe
Filco fkb104m/eb
« Reply #3 on: Mon, 02 August 2010, 17:36:12 »
Quote from: ripster;208315
Buy a Xtrac Super XXL mousepad from Cyberguys and cut it to size for your keyboard tray.   It does make a difference.
Hey Ripster, are these guys on this forum?  I've heard the name mentioned.  Sounds great!
Thanks ...
