Author Topic: Hlep  (Read 2431 times)
Offline Error213
Hlep
« on: Thu, 03 December 2020, 11:07:45 »
I need to find a custom keeb 65% and It can’t be from kbd fans
Only cuz there’s nothing there that I would like (preferably gasket mount and under 200$)
Offline Leslieann
Re: Hlep
« Reply #1 on: Thu, 03 December 2020, 21:04:45 »
And I want an goose that lays golden eggs, I don't think either have much of a chance of getting what we want any time soon.
Warehouses are empty and the supply chain is broken and not getting better.
By the way, gasket mount is almost exclusively going to be a group buy, and that means waiting one one to start, finish and then ship, so even if one started tomorrow odds are it's going to be over 6 months before you have something in hand.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Sup
Re: Hlep
« Reply #2 on: Fri, 04 December 2020, 04:27:21 »
Vega65 maybe its in the GB stage at the moment but its way out of your budget though.
current
Coming soon
Offline 3CLYPS3
Re: Hlep
« Reply #3 on: Wed, 16 December 2020, 23:55:13 »
Damn did you really have to go in on him like that? Also I don't think there are going to be many gasket mounted 65% keyboards that are under $200. The closest thing that I can think of that can fit ur budget is the GMMK Pro which is a 75%. Plus the only reason that is under $200 is because it is mass produced. Most keyboards that are gasket mounted, 65%, and artisan (ie an individual created them like ai03's Vega) are going to run you 300-350 minimum. Some can even cost closer to $1000. It is a slightly different story if you are looking for a tray mount, sandwich mount, or sometimes even a top mount. The Saka is a keyboard in IC rn which is a 65% sandwich mount that is around your budget so I would go check that out! Good luck finding what you are looking for,
