Author Topic: [IC] GMK Tako  (Read 230949 times)
Offline Izeri
Re: [IC] GMK Tako | Added UK Vendor
« Reply #100 on: Sat, 15 May 2021, 12:46:35 »
Quick bump to properly announce Prototypist as UK vendor
Offline ThatCometGuy
Re: [IC] GMK Tako | RAMA Added!
« Reply #101 on: Sat, 15 May 2021, 14:24:08 »
Loving the RAMA, will definitely grab one. Also it seems like Ina is aware of this kit since via her comments in a recentish stream.
Really? Which stream is it? or what did she say?
Offline Izeri
« Reply #102 on: Sat, 29 May 2021, 03:49:41 »
Currently still waiting on quotes, the GB will probably happen on the second half of June. Also more updates about collabs soontm
Offline Lunamorte
« Reply #103 on: Mon, 31 May 2021, 00:00:44 »
This will be my first group buy and for my first build and mechanical keyboard. Rather excited since this is hitting so many of my firsts. I will probably have to find a cheap placeholder set of keycaps while I wait for these because these Group Buys tend to take some months before they ship right? Like around half a year, give or take a couple months, right?
« Last Edit: Mon, 31 May 2021, 00:03:35 by Lunamorte »
Offline Sax_______
« Reply #104 on: Mon, 31 May 2021, 03:23:49 »
With current GMK fulfillment times you can expect 1 year+
Offline Zeroblade
    • Twitter
« Reply #105 on: Mon, 31 May 2021, 22:26:22 »
More like 1-1.5 years given the current situation LOL.
Definitely recommend getting a temporary set like epbt or something.
Offline Yumelon
« Reply #106 on: Tue, 01 June 2021, 17:15:59 »
Its going to be an expensive month...
Offline rmendis
  • Artisan addict
« Reply #107 on: Wed, 02 June 2021, 19:47:36 »
Man, I wish this had a dark alphas set like the mods.
Offline Izeri
Re: [IC] GMK Tako | Added Second RAMA
« Reply #108 on: Mon, 07 June 2021, 08:51:19 »
Added a second RAMA in E-White!
As for the GB date, we're currently still waiting for quotes to come, so there will be no GB till then, hopefully it will be on the second half of this month but I can't promise anything. if you wanna be notified when it goes live you can fill out the Email Form!
« Last Edit: Mon, 07 June 2021, 08:55:23 by Izeri »
Offline Izeri
« Reply #109 on: Mon, 07 June 2021, 08:52:22 »
Seeking other GBs, GMK is currently quoting ~43w. Sadly it is a lot of time and you'd be better with something as placeholder
Offline e1c0s4
« Reply #110 on: Tue, 08 June 2021, 04:33:26 »
i dont usually purchase the rama caps but that e-white is too good to miss out on.
Offline Zeroblade
    • Twitter
« Reply #111 on: Wed, 09 June 2021, 21:22:13 »
YAAAAAAAAAAAS takodachi with filled e-white is EXACTLY what i wanted thank you cannot wait to blow more money on this than superchats
Offline hiddensong
  • this too shall pass
« Reply #112 on: Sat, 12 June 2021, 14:08:34 »
I know its a bit late but.....where's the F13?
Offline Izeri
« Reply #113 on: Sat, 12 June 2021, 14:21:34 »
On Base, right next to |\
Offline Izeri
Re: [IC] GMK Tako | Asero Foundry Artisan
« Reply #114 on: Tue, 15 June 2021, 11:44:29 »
Added Asero Foundry collab
Offline Keeblet_257
« Reply #115 on: Thu, 24 June 2021, 06:22:52 »
next few 2-3 months are crazy first the magnet 039, space 80, gmk stargaze and this set here o_o
Offline Azernith
  • board enjoyer
« Reply #116 on: Thu, 24 June 2021, 23:44:28 »
Now its perfect, need to secure one
good job bro
Offline Izeri
Re: [IC] GMK Tako | New Collabs | Discord Server
« Reply #117 on: Sun, 27 June 2021, 09:34:13 »
Well, we still have no quotes from GMK and I found myself in having to revisit the novelties. I'm removing couple of them and adding other ones. The deskmat will also change.
At this point I'm hoping for a July GB, I made a Discord Server for the ones interested.
I'm also pleased to announce there will be a collaboration with Amusing Atelier and Melonkeys for resin artisans! More info on those quite soon.
Offline Izeri
Re: [IC] GMK Tako | Novelties Update
« Reply #118 on: Thu, 08 July 2021, 08:36:00 »
Updated Base, Novelties and Spacebars kit
Offline Yumelon
« Reply #119 on: Sat, 10 July 2021, 03:59:08 »
aww no more lv lol
Offline Frayne
  • For deskmat inquiries: illu_zn
« Reply #120 on: Wed, 14 July 2021, 03:10:14 »
bonkspac
Offline Brioric
« Reply #121 on: Wed, 14 July 2021, 18:25:41 »
The new novelties are a nice addition, I need those backspaces lol
Offline sapisoi
« Reply #122 on: Thu, 15 July 2021, 12:05:41 »
Takoyaki  :p
Offline dudewth
« Reply #123 on: Fri, 23 July 2021, 17:39:17 »
Liking the colors!
Offline GAM
« Reply #124 on: Mon, 26 July 2021, 14:06:57 »
Lit. Ill take all of the kits pls.  :thumb:
Offline Xufuja
« Reply #125 on: Wed, 28 July 2021, 10:53:35 »
I really like the novelties, will definitely get a full set when the GB starts.
Offline Cylent
  • Formerly cylentshadows
« Reply #126 on: Wed, 28 July 2021, 11:23:50 »
With the full macro column on novelties, that kit is going to be pricey! Best of luck with your quotes  :thumb:
Offline Izeri
Re: [IC] GMK Tako | New Deskmats
« Reply #127 on: Fri, 06 August 2021, 09:22:57 »
  • We finally received quotes, the GB should happen at the beginning of september. No precise date yet.
  • Two new deskmats have been added!
  • RAMA sadly has to be reworked :(
Offline LittleAad
  • Hello
« Reply #128 on: Fri, 06 August 2021, 11:15:17 »
ne pricing avail. Cool deskmats!
Offline Zobeid Zuma
« Reply #129 on: Tue, 31 August 2021, 09:23:36 »
Hope this isn't a dumb question, but. . .   Are GMK mini-spacebars the real thing with a rounded spacebar profile, or are they just. . .  blank Shift keys?  I've tried those before, but the sharp edge is not comfortable to bash with the side of my thumb.
I am pretty dedicated to my split spacebar layouts, and if GMK are now turning out "real" 2.25u and 2.75u spacebars, I'll jump on that.
Offline Izeri
« Reply #130 on: Tue, 31 August 2021, 09:27:39 »
GB scheduled to start on September 13
Offline Izeri
« Reply #131 on: Tue, 31 August 2021, 09:43:45 »
Not sure on when, but GMK definitely created convex mini-bars molds at one point, so yes they're convex
Offline Dinerenblanc
Re: [IC] GMK Tako | GB Starts September 13th
« Reply #132 on: Wed, 01 September 2021, 19:38:21 »
Love the colorway, though the novelties are kinda icky. Will probably opt for the base kit.
Offline Ryamatronic
« Reply #133 on: Mon, 06 September 2021, 04:25:49 »
My wallet is going to suffer, but it's totally worth it. So excited that it's only a week away from the GB!
Offline ina
« Reply #134 on: Wed, 08 September 2021, 21:34:17 »
love the set good job definitely going all in!
Offline kameron
« Reply #135 on: Thu, 09 September 2021, 16:02:19 »
very nice job glwgb
Offline Izeri
Re: [IC] GMK Tako | Now Live
« Reply #136 on: Thu, 16 September 2021, 07:48:01 »
Locking this thread. GB is now live: https://geekhack.org/index.php?topic=114584.0
