Author Topic: [GB]YMD75% Aluminum + Acrylic Light Support (GB production time)  (Read 11554 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
« on: Wed, 09 December 2020, 20:43:29 »
Group buy A: Kit 1 or only case
Group buying start time: UTC+8 2020/12/12
End time:UTC+8 2020/12/26
Production time: About 2 months
Shipping way: FedEx or DHL
    Ymdkey will use shopify to launch group buy for the new diy kit,this case is made by CNC anodized,design in professional team.
257586-0257588-1257590-2257592-3257594-4
Order links and detail
Contactable Email: david.chen@ymdkey.com
Service
  Assembly Service(need to be added)
  FAQ and after-sales Service
Kit 1($145)
Case (plate integrated): CNC Anodized Alu top+Acrylic Base+Plate(color is same with case)
PCB: YMD75v3 QMK Hotswap PCB with RGB underglow
Stabilizers: Gold-plated clear screw-in stabilizers or OEM Clip pcb stabilizers for options
Screws: M2*6 flat
Rubber feet
Only Case($95)
Case (plate embedded-in)+screws+rubber feet (Compatible with Type C YMD75 V2 V3 PCB,KBD75 Type C PCB)
« Last Edit: Sun, 27 December 2020, 22:17:42 by vincent88928 »
Have Fun Everywhere
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB]YMD75% 84 Aluminum top + acrylic base
« Reply #1 on: Mon, 14 December 2020, 08:16:50 »
approved
Offline Oni74
« Reply #2 on: Mon, 14 December 2020, 23:33:14 »
I see various colors listed, but not shown. Can you share the color sample pictures? It would be great if "blue" is a darker tone closer to navy.
    • YMDK
« Reply #3 on: Tue, 15 December 2020, 00:47:14 »
Color close to this links.Thanks for help.
Have Fun Everywhere
Offline Oni74
« Reply #4 on: Tue, 15 December 2020, 13:48:00 »
Thanks! I'll go with either black or gray then. For next time, it would be great if you can offer a navy option.
Offline The Equals D
« Reply #5 on: Tue, 15 December 2020, 14:39:35 »
What mount is this?, I'd assume top like the melody96 but didn't see anything about this on the product page.
Edit - Nvm it says integrated ignore me
« Last Edit: Tue, 15 December 2020, 14:56:54 by The Equals D »
Offline Oni74
« Reply #6 on: Tue, 15 December 2020, 16:47:00 »
How is the PCB secured to the top piece/plate? is it screwed in or does it depend on the switches to hold the PCB in place?
Also, does the PCB have ESD protection?
    • YMDK
« Reply #7 on: Tue, 15 December 2020, 19:28:28 »
Top only have one part(case integrated with plate),PCB have the ESD protection,and need to screw it in top. :)
« Last Edit: Tue, 15 December 2020, 19:32:07 by vincent88928 »
Have Fun Everywhere
Offline Oni74
« Reply #8 on: Tue, 15 December 2020, 20:59:06 »
Awesome - thank you for the quick response!
Sent from my ONEPLUS A6013 using Tapatalk
Offline tommyamoszhao
« Reply #9 on: Tue, 15 December 2020, 22:14:19 »
looks nice!
Offline phoenixrage
« Reply #10 on: Tue, 15 December 2020, 22:41:32 »
How long is this GB going to run for?
    • YMDK
« Reply #11 on: Tue, 15 December 2020, 22:53:10 »
 Group buy will end in 2020/12/26 UTC+8
Have Fun Everywhere
Offline pinkman
  • Learn and share
    • ymdkey.com
« Reply #12 on: Tue, 22 December 2020, 21:48:15 »
so,will there have “melody” letter are engraved in cover bottom that like Melody 96?:llama:
A nobody who works at the YMDK    XD
    • YMDK
« Reply #13 on: Wed, 23 December 2020, 23:09:26 »
  No,sorry.
Have Fun Everywhere
    • YMDK
Re: [GB]YMD75% Aluminum + Acrylic Light Support (GB production time)
« Reply #14 on: Thu, 14 January 2021, 20:52:13 »
    It is likely that the shine through influence is good,just firstly test customized 84 kit in myself, it is official first product to be test by YMDKey.
    I use gold black clear stabilizers in left shift/backspace/ enter,use cherry black stabilizers in 6.25 u spacebar,there will make all stable than before.Will consider add foam in future in this 84 kit,
           David from ymdkey,
           Regards.
 259870-0
Have Fun Everywhere
Offline F1ipflops
« Reply #15 on: Sat, 16 January 2021, 13:28:45 »
Just ordered 2. It's my First Group Buy and I'm Excited to see how it goes.
I'm also curious if this PCB will work with the KBDFans 75v2 case.
Offline Oni74
« Reply #16 on: Mon, 12 April 2021, 20:13:18 »
My YMD75 PCB began failing with less than 2 months of light use, with input being modified as if shift key is stuck. Even after a full reset, PCB is all but useless. Pretty disappointed at the poor quality of the PCB.
Offline nvh2092
« Reply #17 on: Wed, 14 April 2021, 09:15:25 »
I've been using Ymd75 hotswap iso pcb since October 2020 at work and there's no problem at the moment (I'm a developer). I don't use rgb tho. You may have got a defective product?
