Author Topic: [IC] Voice65% (Scroll+LED Strip+Stock Sale)  (Read 165537 times)
Offline OwLab
Re: [IC] Voice65% (Scroll+LED Strip+Stock Sale)
« Reply #50 on: Fri, 18 December 2020, 17:56:31 »
A neat design so far and the roller switch is a great idea.  Putting more than one roller on the board with some software to match could allow volume controls for separate devices which would be cool, or possibly one for volume and one for scroll.
That is a good idea! We'll def consider putting a few more roller/scroll and even try to place them in different positions next time. As for software, I recently bumped in one called MIDI2LR, which uses the MIDI function that is embedded in the QMK to control the Adobe Lightroom. Feel free to check it out on YouTube.
couldn't this also be done with layers?
Unsure which function are you talking about but MIDI is actually realized using layers, just a different kind of MIDI layers to deal with some functions that aren't controllable with traditional keyboard shortcuts (e.g.: ctrl+shift+e).
Offline OwLab
« Reply #51 on: Fri, 18 December 2020, 17:58:08 »
boards like these make it hesitant to post a board for IC... awesome design my man good luck with the gb
Thanks! We can chat about designs and development later on Discord too.
Offline dkFreeze
« Reply #52 on: Fri, 18 December 2020, 22:15:21 »
Any chance of more plate options, or is this set to only have an alu plate?
Offline OwLab
« Reply #53 on: Fri, 18 December 2020, 22:28:21 »
right on point! we are working on it and hopefully we'll have more options when the sale starts.
Offline Zanhana
« Reply #54 on: Sat, 19 December 2020, 02:30:11 »
oh, I meant, for example having one wheel for volume and one wheel for scroll, you could just program them on different layers instead, so there is no need for two wheels
Offline xanserkx
« Reply #55 on: Sat, 19 December 2020, 04:54:21 »
I like the knob position
Oblotzky AIS65 - Rama Zenith - RME Studio Emery65 - TGR Tomo - Hex 4B - Cablecar Design Angel - Cablecar Design Phoenix - Cablecar Design Cypher - Hand Engineering Haus - TX HJ75 - Parallel Limited Portal -  SingaKBD Kohaku -  and bunch of prototypes that I made :(
Sold: Merisi Ottantaquatro
Offline OwLab
« Reply #56 on: Sat, 19 December 2020, 11:49:07 »
Indeed, with layers. I guess it's down to preference when some other ppl want to have more physical keys/gadgets but we value the balance of the function and aesthetics so this is a good solution for us. Hope you like it. :)
Offline LASERman Projects
  • Soldering is my native language.
« Reply #57 on: Sat, 19 December 2020, 12:35:52 »
This is the way rotary should be, hope this will create a trend.
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #58 on: Sat, 19 December 2020, 13:03:57 »
Finally a cool 65% that supports split spacebar! Also, the knob on this is super cool- for sure in for it!
Eat, Sleep, Resin, Repeat.
Offline OwLab
« Reply #59 on: Sat, 19 December 2020, 15:27:34 »
We are thrilled to have your love. Please come to our Discord and stay tuned!
« Last Edit: Sat, 19 December 2020, 17:38:42 by OwLab »
Offline OwLab
« Reply #60 on: Sat, 19 December 2020, 17:40:52 »
We worried a lot about our development speed, tbh. Glad we got the dibs. We'd love to see more creative designs but we have to admit it takes more than time and effort to make a decision deploying a new gadget.
Offline babybjorn
« Reply #61 on: Sat, 19 December 2020, 19:06:50 »
Same, can't wait for this. Split spacebar, volume knob, 65.
Offline OwLab
« Reply #62 on: Sat, 19 December 2020, 20:00:06 »
You actually reminded me of confirming the layout. I'll post the exact combinations of all supported bottom rows later in the post.
Offline OwLab
« Reply #63 on: Sun, 20 December 2020, 00:35:36 »
Thank you for liking it, jion our discord :https://discord.gg/aN3YYfk2we
Offline 10peaches
« Reply #64 on: Sun, 20 December 2020, 02:20:34 »
Have you ever consider making the scroll wheel on the left... it would be more intuitive if any form of rotary encoder device to be put on the left because most people use their right hand for mouse. I feel like I will smacking my mouse hand to the scroll wheel. If there's I think there's instance I want to use the scroll wheel and the mouse at the same time, I can use my left hand to operate the scroll wheel and right hand for the mouse.
Offline OwLab
« Reply #65 on: Sun, 20 December 2020, 13:00:47 »
We have thought about in the development process. To keep a rectangular shape and keeping the ESC botton as well as a relatively thin bezel are our priorities thus the left side scroll wheel route wasn't taken at the end. We feel you about holding the mouse while using the wheel tho. We will review that path if we have more freedom in the bezel design choices and the technical ability to realize that perhaps on the side (like a camera scroll well, on the side instead of the front)
Offline Owl
« Reply #66 on: Sun, 20 December 2020, 13:34:36 »
Man this looks super cool. Might have to keep my eye out for this.
Offline bvckcompton
« Reply #67 on: Sun, 20 December 2020, 15:25:49 »
That's what I was thinking when I originally saw it as well. Would be great to have layers change the functionality (volume, horizontal vs vertical scroll)
But yea, definitely interested the board :)
Offline OwLab
« Reply #68 on: Sun, 20 December 2020, 16:05:51 »
Please join our Discord~! We have new materials every other day
Offline OwLab
« Reply #69 on: Sun, 20 December 2020, 17:08:21 »
wait your name's Owl? We are Owlab :)
Offline SOLBA
« Reply #70 on: Tue, 22 December 2020, 10:50:43 »
T T
good author!
Offline kraken_kr
« Reply #71 on: Tue, 22 December 2020, 22:11:37 »
Looks forward to it!
Offline hottrout
  • I'd Hit Dat Key
« Reply #72 on: Wed, 23 December 2020, 10:21:49 »
Really looking forward to this board.  Cool looking.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline OwLab
« Reply #73 on: Wed, 23 December 2020, 15:04:15 »
Please consider joing our Discord if you haven't, thanks!
Offline EdgeOfInfinity
« Reply #74 on: Wed, 23 December 2020, 19:51:40 »
really liking the uniform bezel - very clean!
Offline Rx003
« Reply #75 on: Wed, 23 December 2020, 23:27:41 »
Is there a way to turn of the RGB and just keep the one on the sides?
Offline OwLab
« Reply #76 on: Thu, 24 December 2020, 02:37:17 »
if you are suggesting turning off the per key rgb while keeping the strip on, then yes it's possible. :)
Offline tommyamoszhao
« Reply #77 on: Thu, 24 December 2020, 05:06:11 »
I like the way you design the scrolling wheel!
Offline santela
« Reply #78 on: Thu, 24 December 2020, 08:42:44 »
Got my Voice 65 from the Chinese GB today! I'm typing on it right now. The board feels great and I love the wheel for volume control. I turn the per key rgb off but leave the light strip on just for a little flair. The light strip can be customized to match keycap sets which is great aesthetically. I also like that you can change the saturation of the rgb as well to make the light color white when I just want something very neutral. I'll make a reddit post with a mini review soon.
GLWGB!
Offline OwLab
« Reply #79 on: Thu, 24 December 2020, 14:11:35 »
GLWGB!
Please tag us at u/Owlab_TT! Can't wait to see your review.
Offline OwLab
« Reply #80 on: Thu, 24 December 2020, 22:39:30 »
yeah our middle case adds a nice touch to it as well ;)
Offline OwLab
« Reply #81 on: Fri, 25 December 2020, 22:10:38 »
I like Middle Case, too.  Thank you for liking our design
Offline OwLab
« Reply #82 on: Mon, 28 December 2020, 12:33:17 »
Guys the typing sound is out!
Offline OwLab
« Reply #83 on: Mon, 28 December 2020, 21:29:57 »
Thank you for liking Voice!
Offline samba
« Reply #84 on: Thu, 31 December 2020, 01:01:47 »
This design is so coool :thumb:
Offline SOLBA
« Reply #85 on: Thu, 31 December 2020, 14:40:11 »
Thanks, 2021 let’s go!
Offline littlesmall
« Reply #86 on: Fri, 01 January 2021, 01:59:35 »
That's so cool !How can I buy it?
Offline orangekeeb
« Reply #87 on: Fri, 01 January 2021, 09:07:02 »
Yeah how do you buy it? Looks of talk of GB and some sales that happened already.
Offline OwLab
« Reply #88 on: Fri, 01 January 2021, 17:44:40 »
we will release our own purchase website a few days before the sale - in a formal Group buy post
Please join our discord if you want to know about the latest updates!
Offline OwLab
« Reply #89 on: Fri, 01 January 2021, 22:05:37 »
welcome to our Discord :)
Offline SOLBA
« Reply #90 on: Sat, 02 January 2021, 15:11:35 »
Thanks for the answer
Offline samba
« Reply #91 on: Sun, 03 January 2021, 05:21:59 »
Can i customize the knob function?
Offline OwLab
« Reply #92 on: Tue, 05 January 2021, 15:41:44 »
Yes we have the VIA to support that
Offline Livid
« Reply #93 on: Tue, 05 January 2021, 17:37:47 »
Yup, this is it
Offline Kingjunguhn
« Reply #94 on: Tue, 05 January 2021, 23:38:03 »
Looking forward to this one
url=https://geekhack.org/index.php?topic=107845.0][/url
Offline OwLab
« Reply #95 on: Thu, 07 January 2021, 23:27:55 »
Glad you have your love, Supreme Leader! The sale is set to happen in the week of 18th.
Offline Kingjunguhn
« Reply #96 on: Fri, 08 January 2021, 04:15:41 »
Sold
Offline hypernosleep
« Reply #97 on: Fri, 08 January 2021, 17:01:07 »
This will (hopefully) be my first custom board and am planning on getting the hotswap version. Will I have any issues using this and setting it up with MacOS?
Offline OwLab
« Reply #98 on: Mon, 11 January 2021, 11:50:17 »
You can use it just fine in MacOS! Please check https://discord.com/invite/fBGYurv for help in case you bump into any software problems. :D
Offline made in China
« Reply #99 on: Tue, 12 January 2021, 01:50:33 »
I'm a little confused. Why is it only 1800RMB in China and 320USD for GH?
