Author Topic: USB hub with >=7 ports and high compatibility?  (Read 7509 times)
Offline cheater
« on: Wed, 16 December 2020, 18:45:02 »
Hi all,
between all the input devices that I have (a few keyboards, a few mice, trackpad, ...), I would like to keep them plugged in via USB. I've looked around but all the usb hubs out there with more than 4 ports are internally just one hub plugged into another hub, and every time I read (amazon) reviews, the reviews talk about incompatibilities, half the ports not being recognized by the system, etc. I want to spare myself the trouble by buying a thing that actually works - but there don't seem to be any reviews out there that point to any good products. I was wondering if anyone had any suggestions?
Offline Leslieann
Re: USB hub with >=7 ports and high compatibility?
« Reply #1 on: Wed, 16 December 2020, 21:23:32 »
Anker.
Beware Amazon reviews, they are EXTREMLY full of shills, cons and morons.
Beware, plugging too many things in will create lag and lower transfer speeds.
I recommend plugging the mouse and keyboard direct, or a smaller hub, same for thumbsticks and external drives.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline ErgoMacros
« Reply #2 on: Wed, 16 December 2020, 21:44:13 »
I've been using these for 4+ years:
   https://www.amazon.com/ORICO-Premium-Port-USB-Cable/dp/B00KDECEBQ/ref=sr_1_6
ORICO Powered USB 3.0 Hub, Aluminum 7 Port USB 3.0 Hub, and 3 Fast Charging Ports.
Come in a number of configurations. 4, 7 ans 10 ports at least.
Use it on my MacBook Pro.
Not cheap, but no regrets. I haven't run onto incompatibilities.
Today's quote: '...“but then the customer successfully broke that.”
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« Reply #3 on: Wed, 16 December 2020, 21:49:53 »
I think the reason most hubs with more than 4 ports are just cascaded hubs is that most hub chips only come in 4 port varieties.
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline Willtato
  • I like small Keyboards
« Reply #4 on: Thu, 17 December 2020, 01:59:59 »
Generally, when I looks for USB hubs, if they contain over around 4 out ports, I always looks for a port for external power.
Sent from my HD1913 using Tapatalk
Offline yui
« Reply #5 on: Thu, 17 December 2020, 02:16:27 »
hubs are part of the usb spec, and the spec says a hub has 4 ports and can be cascaded up to 5 times, it is why most hub have 4 ports, and anything above is cascaded.
also in the usb2 spec a device plugged into a host can draw up to 500mA while a device plugged into a hub is only meant to draw up to 100mA, and will have to share the bandwidth of course. i did read the usb spec before USB3 came out so i do not know how all of that evolved with it though.
Offline cheater
« Reply #6 on: Fri, 18 December 2020, 20:16:20 »
Yeah I'm fine with hubs being made up of 4-port chips, i just want a hub that works, and many of them don't seem to
Offline Leslieann
« Reply #7 on: Fri, 18 December 2020, 20:44:34 »
My 7 port Anker has never had issues.
Oriko is probably another good one.
Higher end Belkin is probably fine as well.
« Last Edit: Fri, 18 December 2020, 20:47:07 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline cheater
« Reply #9 on: Sun, 20 December 2020, 03:46:29 »
Why not get two matching 4 port hubs (if they even need to match to look good)?  If you're constantly swapping which keyboard and mouse you're actually using you'll probably tie the cables in knots and two small knots is easier to sort than a big one, not to mention removing all compatibillity and speed concerns.
Offline yqqdrasil
« Reply #10 on: Sun, 20 December 2020, 19:20:31 »
Get a powered hub from Anker/Sabrent etc. I've gone through a couple over the years, they really don't last long when used a lot.
You could run into some issues with input latency with things like peripherals, so I'd plug those devices in directly.
I stopped buying them, they just die on me one port at a time. Maybe I'm just unlucky.
Offline Shapey Fiend
« Reply #11 on: Mon, 21 December 2020, 19:00:55 »
Been looking at charging docks for my HP Envy x360 for a while now. From what I've read It's a bit of a compatibility minefield unless you buy an expensive one and I'm slow to spend 150 euro on one.
