Author Topic: [IC] JP-02 Arisu Custom Keyboard Kit  (Read 31813 times)
Offline Jefff
    • jlabs.co
« on: Thu, 31 December 2020, 13:43:31 »
Hello there everybody! This the interest check for the JP-02 Arisu kit. The Arisu is an Alice-like layout, with the only difference being that Arisu layout boards have arrow keys.
Port Prototype Album
Brass Bottom Prototype Album
PCB Prototype Album
Render Gallery
Current Status
  • The Port prototype top case, POM plate, prototype PCBs, and screws have arrived
  • The Navy top and stainless steel sample are arriving in the next week
  • Alexotos will be building a JP-02 on stream! It will be Navy top, brass bottom, with a POM plate. It will be built with Gateron Milky Yellows, lubed with 205g0 and filmed with Deskeys films.
Schedule:
  • Build Stream with Alexotos on Tuesday, January 12 at 4 PM PST
  • Navy Top, Brass Bottom, POM Plate, Durock stabilizers, Holy Boba switches (lubed with Tribosys 3203 and filmed with Deskeys films)
  • Groupbuy within 2 weeks of the build stream
Details of the JP-02
  • Arisu Layout (Alice, but with arrow keys)
  • Seamless design
  • Top/Burger Mounted
  • Typing angle of 5 degrees
  • Silicone gasket between plate and top case
  • 3mm Felt Accoustic Dampener between plate and PCB
  • Uses a modified Arisu PCB by u/FateNozomi: The PCBs that will be sold with the JP-02 will have USB Type-C ports, full backspace compatibility, and stepped capslock compatibility
PCB Specs:
  • 2 layers
  • FR4
  • Red Solder Mask
  • White Silkscreen
  • HASL finish
  • 1 oz copper
  • Full Backspace and Stepped Capslock support
  • QMK and VIA support!
The color options are...
  • Silver Top with Brass Bottom
  • Port Top with Brass Bottom
  • Navy Top with Brass Bottom
  • Gray Top with Stainless Bottom
  • Black Top with Stainless Bottom
The bottom case will be beadblasted stainless steel/brass
  • Neither part will have a PVD coating, to allow natural maturation of the brass.
  • If you're not one of those who enjoys tarnish, you can easily remove the tarnish using either a combination of lemon juice + baking soda or a commercial metal cleaner such as Brasso.
  • Bottom cases will also be available seperately in both material options
Confirmed plate materials are brass and POM, and plate files will be open sourced following the groupbuy.
Groupbuy Information
  • Estimated MoQ: 100
  • Format will be FCFS on JLabs.co, my upcoming storefront
  • PCBs, Plates, and bottom cases are available as unlimited extras
  • Each JP-02 will include a custom carrying case, as pictured in the prototype album
  • Estimated Price: < $425 USD (I'm still sorting out a possible increase to the MOQ to get a better price)
  • International Shipping may be available depending on interest
To-Do List:
  • Build stream
  • Groupbuy
IC FORM
Link to JLabs Discord Server (updates will be available here as we approach the GB)
Thank you for reading!
« Last Edit: Thu, 31 December 2020, 15:07:41 by Jefff »
Offline halocantkb
  • Formerly 'shota_irl'
Re: [IC] JP-02 Arisu Custom Keyboard Kit
« Reply #1 on: Thu, 31 December 2020, 13:44:56 »
will that port be fixed?
Offline Jefff
    • jlabs.co
« Reply #2 on: Thu, 31 December 2020, 13:46:06 »
Yes, it has been fixed.
Offline Macmutant
« Reply #3 on: Thu, 31 December 2020, 14:08:19 »
Looks great. I'm interested. Will the PCB include electrostatic discharge (ESD) protection?
Offline Fe
« Reply #4 on: Thu, 31 December 2020, 14:22:14 »
The Arisu layout also doesn't have a 2nd B, with the NM,. row shifted by 0.25u
Offline Jefff
    • jlabs.co
« Reply #5 on: Thu, 31 December 2020, 14:28:42 »
Correct, I'll add that to the post. Thanks!
Offline Jefff
    • jlabs.co
« Reply #6 on: Thu, 31 December 2020, 14:52:07 »
Yup, it uses the USBLC6-2SC6 for protection! You can read more about it here.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #7 on: Thu, 31 December 2020, 16:31:13 »
gib arisu
Offline Jefff
    • jlabs.co
« Reply #8 on: Thu, 31 December 2020, 16:52:20 »
gib arisu
but not design by 5 year old
  • Formerly 'esclab'
    • esc lab
« Reply #9 on: Thu, 31 December 2020, 20:03:34 »
Offline kk73715
  • Why are you even reading
« Reply #10 on: Thu, 31 December 2020, 20:05:23 »
100 MoQ, <$425? For brass or ss bottom?
How thin is the bottom piece? How much does the bottom piece weigh? What is the fully assembled mass?
This is very fair pricing, my concern is whether it will be maintained.
Offline num
« Reply #11 on: Thu, 31 December 2020, 20:20:10 »
gib arisu
Hah, yeah a bit older than that...
Offline num
« Reply #12 on: Thu, 31 December 2020, 20:33:02 »
Awesome to see this getting ever closer to a GB!
There's a little more history of the case design on the Making Stuff Together thread: https://geekhack.org/index.php?topic=106268.0 the JP-02 was derived from.
Offline Jefff
    • jlabs.co
« Reply #13 on: Thu, 31 December 2020, 23:33:42 »
The bottom piece is 3.5mm thick, and the mass of an alu top + brass bottom is 2kg. An alu top + stainless bottom is slightly lighter than that. The total built mass will be closer to 2.5kg. The current plan is for the groupbuy to have a Minimum Order Quantity of 100 and a Maximum Order Quantity of 150. I also plan to offer incremental discounts as the number of units sold increases (maybe at 125 and 150). $425 would be the pricing at 100 units, the minimum.
  • Formerly 'esclab'
    • esc lab
« Reply #14 on: Thu, 31 December 2020, 23:41:05 »
gib arisu
Just a bit. We all know Jeff's like 12
Offline kk73715
« Reply #15 on: Thu, 31 December 2020, 23:46:36 »
Ah that gives a lot of perspective, thank you.
Offline thestrayed
« Reply #16 on: Fri, 01 January 2021, 07:45:18 »
International shipping + wrist rest plis
Offline hottrout
  • I'd Hit Dat Key
« Reply #17 on: Fri, 01 January 2021, 10:39:30 »
Very interested.  Please consider providing a tailored wrist rest at the same time as the GB.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline oulongwen
« Reply #18 on: Fri, 01 January 2021, 11:04:36 »
Hotswap?
Offline Jefff
    • jlabs.co
« Reply #19 on: Fri, 01 January 2021, 18:12:26 »
Hotswap?
Unfortunately not, however, the PCB is compatible with MillMax hotswap sockets, which will not be included.
I may end up running the wrist rest shortly after the groupbuy for the board goes live. Further updates will be posted here (on Geekhack), Reddit, and my Discord server.
International shipping will be available! See my earlier response regarding wrist rests. Have a good day, and Happy New Year!
Offline holer
« Reply #20 on: Mon, 04 January 2021, 04:47:05 »
Great looking keyboard. Any chance that you would add the option of a split left shift (2.25 to 1.25 + 1)?
Offline Jefff
    • jlabs.co
« Reply #21 on: Thu, 07 January 2021, 20:26:12 »
No, split left shift will not be an option.
Offline CookieFlow
« Reply #22 on: Thu, 07 January 2021, 20:44:00 »
This looks awesome.
I have always been curious about trying an Alice style board but I can't live without arrow keys so this is perfect.
The IC form says port top with stainless bottom but this thread says brass bottom. Which one would it be?
I hope the port color is similar to the prototype. The renders appears almost brown to me.
And happy to see that Europe shipping is confirmed. And same as others I'd happily purchase a wrist rest.
Would have loved hotswap as an option, but millmax support is better than nothing.
Offline Jefff
    • jlabs.co
« Reply #23 on: Sat, 09 January 2021, 21:43:07 »
This looks awesome.
Yeah, Port will ship with brass bottoms. Thanks for pointing out the mistake on the IC form! The prototype is an example of the final color, please excuse my bad renders. Wrist rests will probably run shortly after the board GB, but ship in the same box.
Offline msieben
« Reply #24 on: Wed, 27 January 2021, 16:16:45 »
OMG, you add a ten key to this, and I will give you my moneys.
Offline vutid
« Reply #25 on: Sat, 06 March 2021, 23:43:56 »
the imgur page for the album is down, is it normal?
GMK Rave
