Author Topic: [IC] Wire Switch Deskmat  (Read 6475 times)
Offline EthanN
« on: Sat, 09 January 2021, 18:53:21 »
Hey Geekhack!
I created this deskmat design based on the outline of a mechanical switch.
Render:
Thanks to Bachoo for the keyboard model! Render done by me.
Colorways:
Grey
White
Extra Dark
Blue
Green
Beige
Patterns/Layouts
Standard
Standard with smaller switches
Large Switch (Right)
Large Switch (Centered)
Large Switch (Left)
IC form: https://forms.gle/CjJ2bzfv576BAYhq8
Specs:
900x400x4mm
Stitched Edging (Color TBD)
Vendors:
TBD
Offline hangedtofu
Re: [IC] Wire Switch Deskmat
« Reply #1 on: Sat, 09 January 2021, 18:57:51 »
100% buying!
Hope you get EU vendors
Offline Anthixious
« Reply #2 on: Sat, 09 January 2021, 20:50:20 »
Left some good feedback in the IC check. These also look like mats I would definitely buy.
Offline kapowaz
    • kapowaz industries
« Reply #3 on: Sat, 09 January 2021, 20:53:15 »
Hope you get EU UK vendors
A suggestion, since post-Brexit VAT is proving problematic, particularly for smaller orders.
Offline EthanN
« Reply #4 on: Sat, 09 January 2021, 21:03:21 »
100% buying!
Thanks for the feedback, glad that you like the design. I'm not entirely sure what I'll do for vendors yet, so far I'm just trying to figure out if people would be interested in the design.
Offline EthanN
« Reply #5 on: Sun, 10 January 2021, 22:58:28 »
Bump
