Author Topic: Repair USB "C" plug on cable?  (Read 4591 times)
Offline typo
« on: Tue, 12 January 2021, 20:37:14 »
Custom cable was plugged into faulty USB component. Now no data/power from plug on cable. Assuming the traces are not ruined. Which is unlikely. Anything small enough to clean it or something? Use Alcohol? Thank you
Offline Leslieann
Re: Repair USB "C" plug on cable?
« Reply #1 on: Tue, 12 January 2021, 21:16:07 »
That connector is borked, replace it before you f-up anything else, which is what will happen if you keep trying to use it once damaged.
They are not repairable, even if you get it to work it's damaged and can damage other components leading to no end of problems with usb cables.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
