Author Topic: SA keycaps, high or low profile case?  (Read 2555 times)
Offline scowdawg
« on: Sat, 16 January 2021, 22:34:19 »
Building my first keyboard from parts. I have settled on an SA keycaps set from max keys because I like the colors, but I've never typed on SA keycaps before. I'm a little unsure what profile of case is better for SA keycaps. Should I go for a low profile case or a high? What looks better, what feels better? Also I've never used a wrist rest before; should I think about using one with SA keycaps?
Edit: In your opinion.
« Last Edit: Sat, 16 January 2021, 22:44:34 by scowdawg »
Offline Sup
Re: SA keycaps, high or low profile case?
« Reply #1 on: Sat, 16 January 2021, 22:41:36 »
personal preference , personal preference  , personal preference , personal preference and personal preference
current
Coming soon
Offline kajahtaa
« Reply #2 on: Sat, 16 January 2021, 23:49:41 »
SA always looks great
Offline whezil
« Reply #3 on: Sun, 17 January 2021, 05:55:00 »
From my experience SA keycaps are very high so I would recommend a lower profile case. From my usage the angle of my wrist was not too comfortable so I resorted to lifting my wrists off my desk to type at a more comfortable angle. However if you use a wrist pad/rest then a higher profile should be fine. SA is my favorite profile to type on it feels retro and to me that is amazing.
Offline S61
« Reply #4 on: Sun, 24 January 2021, 01:00:41 »
In my opinion, it's best to use Sa with hand support
