Author Topic: [IC]Sun20 Pad+Giveaway  (Read 12824 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Mon, 18 January 2021, 04:04:30 »
Edit: February 18
We launched the GB some days ago and would also love to giveaway one Sun20 pad, Fee free to join the giveaway
Final Render Gallery: https://imgur.com/a/InWpjPY
GB PAGE here
Specifications:
Aluminum alloy case
Tray mount
Wired QMK/VIA
Hot-swap
Type-c
RGB
6° typing angle
Price:$79+shipping fee
Vesrion A
Version B
Version C
Tell us which version you want, fill in the IC Form HERE
Render: https://imgur.com/a/C7GVMiU
Specifications:
Aluminum alloy case
Tray mount
Wired QMK/VIA
Hot-swap
Type-c
RGB
Colors:TBD
Price: No more than $99 USD
Please feel free to comment or join in the discord if you have any questions or suggestions :)
« Last Edit: Thu, 18 February 2021, 20:21:40 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline alper_maestro
Re: [IC]Sun20 Pad
« Reply #1 on: Mon, 18 January 2021, 04:08:19 »
I like the front view and option B for my preferences. But why a flat design and not angled?
Ergonomically, I do not find that comfortable and that is why I am personally not a fan of this.
Offline Kajoler
Re: [IC]Sun20 Pad
« Reply #2 on: Mon, 18 January 2021, 04:45:42 »
oh.. john
How come both versions cant just be offered in 1 non-hotswap pcb? Will there be options for feet? Not a fan as well of the flat design
« Last Edit: Mon, 18 January 2021, 04:50:58 by Kajoler »
>:0
Offline mustardgreens
Re: [IC]Sun20 Pad
« Reply #3 on: Mon, 18 January 2021, 17:26:44 »
I am in the market for a 17-key numpad, so I am your ideal customer. But... correct me if I'm wrong... this has a 0 degree typing angle? :S
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #4 on: Mon, 18 January 2021, 19:17:10 »
Considering the price, but we will add your suggestions :)
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #5 on: Mon, 18 January 2021, 21:39:39 »
oh.. john
Will add an option for typing angle in the form. Thanks :thumb:
Offline treeleaf64
    • treeleaf64
Re: [IC]Sun20 Pad
« Reply #6 on: Mon, 18 January 2021, 21:53:36 »
260020-0
Everyone must pay the cat tax
Offline Domantas
Re: [IC]Sun20 Pad
« Reply #7 on: Tue, 19 January 2021, 14:43:09 »
If it is (in order of importance):
* Sounthfacing switches (mandatory for me)
* All 1 u (mandatory for me)
* VIA (mandatory for me, because I will use this as macropad too duh)
* White (or at least black) (not mandatory but who doesn't like these colors)
I am IN FOR THIS, YEAH!
If not, goodbye :)
P. S. Honestly I congratz that it is without top row
« Last Edit: Tue, 19 January 2021, 14:47:26 by Domantas »
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #8 on: Tue, 19 January 2021, 20:30:14 »
If not, goodbye :)
Thanks for your feedback  :thumb:
Offline Domantas
Re: [IC]Sun20 Pad
« Reply #9 on: Thu, 21 January 2021, 13:45:27 »
If not, goodbye :)
I have a q about rgb: would it be per-key rgb?
Btw being completely honest if it would be flat you could use it horzontally (just think about it people) for gaming or more as macropad. Though I liked angled numpad, so either decision is kinda ok
« Last Edit: Thu, 21 January 2021, 13:54:40 by Domantas »
Offline keeganzero
  • huhu
Re: [IC]Sun20 Pad
« Reply #10 on: Thu, 21 January 2021, 22:33:12 »
I'm not sure what is more lazy, the product or the IC.
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #11 on: Fri, 22 January 2021, 00:21:03 »
If not, goodbye :)
Sure
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #12 on: Thu, 04 February 2021, 02:35:33 »
Final render gallery updated
Re: [IC]Sun20 Pad
« Reply #13 on: Fri, 05 February 2021, 04:07:51 »
 per-key rgb?
And thanks for making it 6° typing angle .
Offline IceHawk
Re: [IC]Sun20 Pad
« Reply #14 on: Fri, 05 February 2021, 06:39:27 »
This looks super clean, I like it. I would love to see a bluetooth version, maybe in the next release.
Offline Groom
Re: [IC]Sun20 Pad
« Reply #15 on: Fri, 05 February 2021, 09:06:04 »
I like the 5X4 layout pad, and thin border .
practical and compact
Offline Raravin
Re: [IC]Sun20 Pad
« Reply #16 on: Fri, 05 February 2021, 12:42:35 »
What is supported VIA QMK how can I change what the keys do? THere seems to be no information.
Offline Domantas
Re: [IC]Sun20 Pad
« Reply #17 on: Tue, 09 February 2021, 16:04:18 »
Couldn't agree more. Hope for round 2 with grid layout (v 1) if default numpad layout (version 2) is decided already
« Last Edit: Tue, 09 February 2021, 16:12:58 by Domantas »
Offline Domantas
Re: [IC]Sun20 Pad
« Reply #18 on: Sat, 13 February 2021, 18:55:18 »
Is it sounth facing or north facing? I may try this (if find something closer to my liking probably easily sell since there isn;t a lot of numpads haha) since it is 100 usd but this is really important for me
« Last Edit: Sat, 13 February 2021, 18:57:26 by Domantas »
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #19 on: Thu, 18 February 2021, 20:23:32 »
per-key rgb?
Yes, per-key rgb.
Offline john08099
  • Velocifire MK
Re: [IC]Sun20 Pad
« Reply #20 on: Thu, 18 February 2021, 20:59:13 »
It's south facing
Offline Rx003
Re: [IC]Sun20 Pad+Giveaway
« Reply #21 on: Fri, 19 February 2021, 03:31:45 »
Its alright! Good luck with the IC wish you all the best for this  :thumb:
Offline SpinningHook
  • "I can't know how to hear anymore about tables!."
« Reply #22 on: Sat, 29 May 2021, 11:55:53 »
I just finally received mine. However, there doesn't seem to be any instructions on how to flash the PCB for VIA compatibility, as the device isn't being recognized right out of the box. Some instructions would be appreciated.
"Brevity is the soul of wit."
