Author Topic: [IC] ePBT Camo | GB LIVE  (Read 52024 times)
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo | GB June 1-July 1
« Reply #100 on: Thu, 27 May 2021, 06:06:09 »
Kat Koil put together some awesome cables for Camo and Radio Silence. They'll be available directly from her shop during the group buy (WHICH STARTS NEXT WEEK!)
269278-0269280-1
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo | GB STARTS TOMORROW
« Reply #101 on: Mon, 31 May 2021, 02:36:49 »
GB kicks off tomorrow! We'll have a month filled with giveaways thanks to our amazing vendors and collaborators <3
269464-0
Offline mvkb
  • Designer
    • MVKB
« Reply #102 on: Tue, 01 June 2021, 10:30:59 »
I'd like to thank you all for the support and feedback. The group buy is now live. Please consider ePBT Camo, and the many collaborations we're running. Thank you. ❤️
https://geekhack.org/index.php?topic=113140
Offline gh_pp
« Reply #103 on: Mon, 14 June 2021, 11:14:24 »
For the short spacebars
are the 1u 1.25u 1.75u 2u 2.25u 2.75u spaces , are they all convex (like 6.25u spacebar) or they are concave (like shift keys)?
thank you
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline mvkb
  • Designer
    • MVKB
« Reply #104 on: Mon, 14 June 2021, 12:49:25 »
thank you
They're all convex.
Offline AshF
Re: [IC] ePBT Camo | GB LIVE
« Reply #105 on: Wed, 30 June 2021, 07:47:28 »
Not too sure on the Camo but the Radio Silence grey is gorgeous! I'm in!
Offline ClerklyTexas
« Reply #106 on: Sat, 30 July 2022, 18:37:39 »
I was referred here from the KBDFans Discord when I was trying to figure out the color of the D60 Camo case. The majority of the newest (to appear) images on the KBDfans page show a very dark case. It doesn't seem to correspond with any of the RAL colors used in the keycap set. There are a couple of older images on the D60 page that do seem matched to the keycaps. I'm guessing they're renders. Can someone assure me that the D60 case is, in fact, color matched to the RAL colors in the keycaps? I know that renders use lighting that can affect the hues and values of the items in the render—I'm not sure that's the issue. See attached:
Offline irithyll
« Reply #107 on: Sat, 30 July 2022, 18:46:42 »
I remember MVKB received a sample of the D60 lite case a couple months ago around December and posted photos of it comparing it to his RAL colors in his discord. If you're curious, you can check on his discord and see those photos.
« Reply #108 on: Sat, 30 July 2022, 18:53:17 »
That answers my question. Thank you.
Offline mvkb
  • Designer
    • MVKB
« Reply #109 on: Mon, 01 August 2022, 03:03:50 »
After a lot of color tweaking, here are photos from the production version of the board:
289719-0289721-1289723-2
Offline nonuser
« Reply #110 on: Fri, 05 August 2022, 22:54:05 »
Where is the keycap at? I only see a blank render :)) :)) :)) :)) (you get it because the set is called camo and when something is camouflage you cannot see it, kinda like the invisibility cloak from harry potter. I see a blank render because the set is camouflage with the render background  :)) :)) :)) :)) ) GLWIC  :thumb: :thumb:
Offline Cylent
  • Formerly cylentshadows
« Reply #111 on: Fri, 05 August 2022, 22:54:55 »
The GB already ran...
