Author Topic: [IC] ePBT Camo | GB LIVE  (Read 52019 times)
Offline mvkb
  • Designer
    • MVKB
« on: Thu, 28 January 2021, 08:00:13 »
| GB IS LIVE |
ePBT Camo
📝 IC Form
📸 Instagram
💬 MVKB Discord (🆕)
📬 Newsletter
Blending in. This set isn’t about the keyboard grabbing all the attention on your desk, it’s a set you’d see in a remote cabin in the snowy mountains, the type a famous writer would flee to to finish the successor to their breakthrough debut, far away from all distractions. They should really call their spouse, it’s been a while since they’ve been in contact.
| Kits |
2 themes, 8 kits.
| Deskmats |
| Collaborations |
Collaborations include 2 brass novelty caps by Salvun, a custom D60lite by KBDfans, custom cables by Kat Koil, and a split wrist rest by Digital Carpentry.
Brass artisans by Salvun.
D60lite by KBDfans.
Split wrist rest by Digital Carpentry,  already available.
Cables by Kat Koil.
| Colors |
  • RAL 7035
  • RAL 7045
  • RAL 7031
  • RAL 7015
  • RAL 7016
LTR: RAL 7035, RAL 7045, RAL 7031, RAL 7015, RAL 7016 (6th color in photo unused)
| Vendors & Pricing |
Huge thanks to drbparsons, avintagephoto, sailer, to1ne, matts, noudadrichem, Fresh, Matej, ulliam, Chet, backyardhero3, Martin, edit, imyke, brammm, funky, ectoplasmatic...
📝 IC Form
📸 Instagram
💬 MVKB Discord (🆕)
📬 Newsletter
Be excellent to each other.
« Last Edit: Mon, 14 June 2021, 12:49:45 by mvkb »
Offline Alessio
    • YT Channel
Re: [IC] ePBT Camo
« Reply #1 on: Thu, 28 January 2021, 08:01:38 »
why would you post an empty IC
Offline futurecrime
  • Get Zooted
Re: [IC] ePBT Camo
« Reply #2 on: Thu, 28 January 2021, 08:19:29 »
I can see this selling a lot.
2021 year of the abandonment of the mod/alpha segregation. Keycaps now mix freely regardless of the colour of their plastic. Stick that in your mod coloured pipe and smoke it.
Offline BapoDonu
Re: [IC] ePBT Camo
« Reply #3 on: Thu, 28 January 2021, 08:35:37 »
I cant see it
Offline BapoDonu
Re: [IC] ePBT Camo
« Reply #4 on: Thu, 28 January 2021, 08:36:05 »
Offline eskimojo
    • KeycapLendar
Re: [IC] ePBT Camo
« Reply #5 on: Thu, 28 January 2021, 08:45:12 »
I like the idea more than I thought I would  ;)
The alignment for some of the legends is a bit weird - the num row keys etc look odd being centred while the rest of the set is left aligned.
Any plans to get some board renders made?
Offline asherw
    • Personal Site
Re: [IC] ePBT Camo
« Reply #6 on: Thu, 28 January 2021, 09:07:11 »
Not something I really thought I'd like at first but this is great!
The only thing I'd say is make sure the contrast between each key's legend and base color is around the same. It'll look very odd otherwise.
« Last Edit: Thu, 28 January 2021, 11:21:44 by asherw »
cool projects:
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
Re: [IC] ePBT Camo
« Reply #7 on: Thu, 28 January 2021, 10:59:48 »
This is very cool
Offline HoodrowThrillson
Re: [IC] ePBT Camo
« Reply #8 on: Thu, 28 January 2021, 11:28:52 »
I cant see it
damn it i was gonna make that joke
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline treeleaf64
    • treeleaf64
Re: [IC] ePBT Camo
« Reply #9 on: Thu, 28 January 2021, 11:44:24 »
This is a very treeleaf moment. Sometimes there are so many leaves that you cannot see them individually.
And sometimes people blend into the leaves as well
this is Camo!
Everyone must pay the cat tax
Offline Dazon
Re: [IC] ePBT Camo
« Reply #10 on: Thu, 28 January 2021, 12:00:45 »
this was something i thought i'd hate but actually really really love. keepin my eye on this one :thumb:
Offline Sunhwan Jeong
Re: [IC] ePBT Camo
« Reply #11 on: Thu, 28 January 2021, 12:16:06 »
Are you planning to use reverse dye-sub for this kit?
Offline whirlwind
Re: [IC] ePBT Camo
« Reply #12 on: Thu, 28 January 2021, 13:41:45 »
I'm wondering what the inspiration is behind this set.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] ePBT Camo
« Reply #13 on: Thu, 28 January 2021, 13:44:01 »
finally pre-selected vomit sets; no longer do i have to sift through grab bags!
Offline ravermeister
Re: [IC] ePBT Camo
« Reply #14 on: Thu, 28 January 2021, 13:46:47 »
Add 40s and NorDe/Intl. Thank you!
Offline Lenux
Re: [IC] ePBT Camo
« Reply #15 on: Thu, 28 January 2021, 13:55:26 »
Love the mods and the theme. GLWIC !
Offline avintagephoto
    • apriendeau
Re: [IC] ePBT Camo
« Reply #16 on: Thu, 28 January 2021, 14:55:57 »
Renders are currently in the works. :)
Offline LittleAad
  • Hello
Re: [IC] ePBT Camo
« Reply #17 on: Thu, 28 January 2021, 14:59:02 »
I cant really tell which keys are which in the kitting, it would be quite nice to see some renders......  ^-^
Offline powwu
    • Discord
Re: [IC] ePBT Camo
« Reply #18 on: Thu, 28 January 2021, 15:34:09 »
ePBT Hairballs
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #19 on: Thu, 28 January 2021, 15:41:45 »
Board renders are in the works!
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #20 on: Thu, 28 January 2021, 15:42:37 »
I’ll be reaching out for samples ASAP! Meanwhile, every single person who fills out the IC form helps
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #21 on: Thu, 28 January 2021, 15:43:25 »
Yes, but I’m open to any feedback or expertise to help make this set perfect.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #22 on: Thu, 28 January 2021, 15:43:50 »
“What if?” Simple as that.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #23 on: Thu, 28 January 2021, 15:44:18 »
World’s most expensive grab bag.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #24 on: Thu, 28 January 2021, 15:45:36 »
What is missing from the extension sets for 40s to work? Legit question, I’m seeing cross-eyed from staring at kits...
NorDeUk or more would mean 2 more sets. Wonder if they’d reach MOQ.
Offline srioz
Re: [IC] ePBT Camo
« Reply #25 on: Fri, 29 January 2021, 07:39:32 »
Congrets for your first IC Tim, looking forward to this
Offline xlSantos
Re: [IC] ePBT Camo
« Reply #26 on: Fri, 29 January 2021, 10:47:47 »
This is a pretty cool theme! GLWIC
Offline BraveOtter
Re: [IC] ePBT Camo
« Reply #27 on: Fri, 29 January 2021, 10:54:52 »
It would be great if there was an ISO Spanish kit. I love the colors.
Offline iinko_mk
  • Status: broke
Re: [IC] ePBT Camo
« Reply #28 on: Fri, 29 January 2021, 16:51:05 »
same problem, can't fuking see anything, what type of IC is this
Offline pararch
Re: [IC] ePBT Camo
« Reply #29 on: Fri, 29 January 2021, 20:51:06 »
I really like the urban camo theme on this, but regarding overall arrangement, have you considered referencing digi-camo shapes more? its camo, but sort of too broken up for my taste? Kind of an oxymoron though.
Offline Xeryn
Re: [IC] ePBT Camo
« Reply #30 on: Fri, 29 January 2021, 21:29:59 »
Great job on the set! The pattern of the base kit render is well balanced, not too much of one color anywhere. Filled the IC form!
Offline Lenux
Re: [IC] ePBT Camo
« Reply #31 on: Sat, 30 January 2021, 16:00:45 »
Filled in the IC. GLWIC
Offline paczki
Re: [IC] ePBT Camo
« Reply #32 on: Sat, 30 January 2021, 19:09:51 »
Omg I filled the IC! These look so beautiful especially imagining it on a white case.  :p
Offline Ustinj
Re: [IC] ePBT Camo
« Reply #33 on: Sat, 30 January 2021, 22:37:20 »
those are some dope icon mods. not a fan of the camo base kit, but radio silence i would be inclined to pick up
Offline York Chan
Re: [IC] ePBT Camo
« Reply #34 on: Sun, 31 January 2021, 02:40:30 »
The combination of different gray levels looks very harmonious :thumb:
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #35 on: Mon, 01 February 2021, 19:13:17 »
I played with a bunch of pattern options. Tried making it as random as possible, but it didn't feel right. Ended up manually creating this pattern, making sure to balance colors (tricky with the space bar).
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo
« Reply #36 on: Mon, 01 February 2021, 20:17:23 »
Just updated the Auxiliary set to include more keys for 40's, ortho's, and languages. It was a small change but hopefully has a large impact on the layouts and languages supported.
Offline Sullivan
Re: [IC] ePBT Camo
« Reply #37 on: Sat, 20 February 2021, 18:49:04 »
Filled out IC, would look great on a future build I'm working on. Good luck!
Offline Jacki
Re: [IC] ePBT Camo
« Reply #38 on: Sat, 20 February 2021, 19:02:27 »
The camouflage works so well i can't even tell what i'm looking at.
[img width=267 height=120]https://i.imgur.com/in3VqH2.jpg[/img
Offline HappyB0T
  • I'm a Piggie
Re: [IC] ePBT Camo
« Reply #39 on: Sun, 21 February 2021, 00:41:01 »
@*#&$*#@__nø__@#(*$(*@#$&
Offline KucherenkoZZZ
Re: [IC] ePBT Camo
« Reply #40 on: Sun, 21 February 2021, 10:58:20 »
Good kitting
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo | Added Renders
« Reply #41 on: Tue, 23 February 2021, 20:14:38 »
Renders! We've got renders! Also revamped the post, added tons of new details. More news soon.
Offline acitrin
    • https://acitrin.design/
« Reply #42 on: Tue, 23 February 2021, 20:33:32 »
Wait... isn't Protozoa a UK vendor? They're listed as both a UK and US vendor...
Honestly, the set isn't for me... but I can see it selling really well! GLWGB!
Offline mvkb
  • Designer
    • MVKB
« Reply #43 on: Tue, 23 February 2021, 20:38:13 »
They’re setting up shop in the US too.
Offline acitrin
« Reply #44 on: Tue, 23 February 2021, 20:39:38 »
Oh? That's cool! Will they have a separate site for the US branch?
Offline mvkb
  • Designer
    • MVKB
« Reply #45 on: Tue, 23 February 2021, 20:45:56 »
They have more information to share soon
Offline mvkb
  • Designer
    • MVKB
Re: [IC] ePBT Camo | All Vendors Confirmed
« Reply #46 on: Thu, 25 February 2021, 17:02:17 »
Just added the final vendor (KBDFans for China!) and Salvun will be doing a novelty. GB date announcement soon! <3
Offline HelloThisIsDog
« Reply #47 on: Thu, 25 February 2021, 23:33:35 »
Looks really cool! Can't wait! Are you actually teasing the "novelties" or is the joke that they're camouflaged and are just blanks
Offline jmgfx
« Reply #48 on: Sun, 28 February 2021, 04:55:24 »
Love this, very sleek. Gonna look good in a lot of different cases
« Reply #49 on: Sun, 28 February 2021, 14:55:32 »
Sorry to voice a nitpicky observation, but is anyone else concerned about the stacking of the lightest color at F6, F7, 7, and 8?
