Author Topic: Left-handed or ambidextrous wireless mouse?  (Read 11474 times)
Offline iri
« on: Sat, 30 January 2021, 06:41:36 »
Hello everyone,
I'm looking for a good wireless mouse to use with my left hand. I don't need more than two buttons and the scrolling wheel. I think it'd be best if the buttons and the wheel are quiet and lightweight. (EDIT: the mouse is not for gaming).
Searching GH, it seems like the natural choice for a mouse like this (that is currently available) is Logitech G900/G903. But those seem a bit overkill since I don't need all the extra buttons. Any other mice I might look at?
Thanks
« Last Edit: Sun, 31 January 2021, 07:31:03 by iri »
-Ray Bradbury
Offline Leslieann
Re: Left-handed or ambidextrous wireless mouse?
« Reply #1 on: Sun, 31 January 2021, 00:15:22 »
The 900/903 has block offs to remove side buttons you don't need. As for the rest, the big middle  nub is actually scroll release, not a button for function, the two below are the only other extras. Compared to many mice (I had a G700 prior), it's rather minimalistic. I call it the most boring expensive mouse you can buy, but I do agree it's overkill for "just a mouse".
On the other hand you can find 900's new in box for about the price or a refurbished 903 (under $90) and it is a great mouse with relatively easy Omron switch replacement (unlike many other Logitech) so it may still be your best bet in the long run if you burn through switches like I do.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline iri
« Reply #2 on: Sun, 31 January 2021, 06:14:59 »
Unfortunately, I can't find a new G900 here in the UK for less than £99 :(
-Ray Bradbury
Offline TalkingTree
    • My projects
« Reply #3 on: Sun, 31 January 2021, 06:24:39 »
If it's not for gaming and you can live with tacticle switches then the Logitech M350 Pebble would do just fine.
Offline iri
« Reply #4 on: Sun, 31 January 2021, 07:41:37 »
Thanks TalkingTree. Yeah, the mouse is not for gaming.
-Ray Bradbury
