Author Topic: What tolerance in dimensions should allow from the manufacture?  (Read 2780 times)
Offline Jparis1138
« on: Sat, 06 February 2021, 16:15:20 »
I am about to send my design to a manufacturer, but I’m not sure what tolerance I can allow in my design . I’m especially worried about the screw holes as I’m not sure how precise the dimensions need to be for the screws to fit. If anyone can help I’d be really thankful.
Offline nevin
Re: What tolerance in dimensions should allow from the manufacture?
« Reply #1 on: Sat, 06 February 2021, 19:16:50 »
Ask that manufacturer your planning on sending it to.
Offline xudongz
    • Personal Site
« Reply #2 on: Tue, 09 February 2021, 12:55:58 »
It depends on what you're getting manufactured (PCB, CNC, laser cutting, etc). If the manufacturer needs to tap screw threads for CNC, you'll likely need to provide them with a technical drawing with details on what/where to tap.
If you don't need threads but only need the screw to fit through, you can do something like 3.1mm holes for M3 screws based on the manufacturer's specified tolerance.
SliceMK | ErgoDox Wireless group buy round 2 running until November 16, 2021
Offline Leslieann
« Reply #3 on: Tue, 09 February 2021, 22:05:56 »
Laser and water also have kerf to deal with (beam spread).
There are charts that tell you the proper dimension for screw holes prior to tapping.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
