Author Topic: Cheapest hotswap board to test switches?  (Read 2498 times)
Offline Crabby
« on: Sun, 07 February 2021, 08:19:58 »
Hey everyone, I'm working on a Boston 120% keyboard build and the switches I'm using for it are box pinks. Chyrosran22 had mentioned that he liked them more with lighter springs because they let him follow through more, and since I align very well with Chyro's opinion on clicky switches I'd hate to have even partially soldered a board to find I'd want to mod them with lighter springs.
So my question is are there any bargain basement hotswap setups that'll let me test the feel of these switches? I have no intention of using it as a regular keyboard at all.
Switch testers aren't good enough for me, I can't really judge unless I'm at least "typing".
Offline RandmoCrystal
Re: Cheapest hotswap board to test switches?
« Reply #1 on: Sun, 07 February 2021, 08:35:50 »
i know my $40 redragon board has hotswap switches, but ive heard that theres questionable compatibility with anything other than outemu switches
Sent from my LM-V450 using Tapatalk
Offline Crabby
« Reply #2 on: Sun, 07 February 2021, 09:27:29 »
Ah yeah, I forgot about the red dragon boards. I'd have to look into it.
Offline Leslieann
« Reply #3 on: Sun, 07 February 2021, 20:46:56 »
If it uses Outemu hot swaps it could have issues with other switches.
Spend a bit more and get a barebones GMMK, it uses Kailh hot swaps that work with pretty much any MX switch and it's a pretty decent board as well that you can resell or give away to someone without feeling bad.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Crabby
« Reply #4 on: Sun, 07 February 2021, 22:03:00 »
I managed to get a bluetooth GK64 for 50 bucks new on ebay. Works out for me cause I needed a new wireless keyboard for my home theatre pc.
