Author Topic: [IC] Mountain Alice - Southpaw Alice with ISO support! (KEYCAP RENDERS OUT)  (Read 97833 times)
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
Hello keyboard people!
I present to you first ever southpaw 1800 Alice.
DISCORD SERVER - For updates regarding Mountain Alice
https://discord.gg/tnJNZJy6Tf
GMK Marmoreal
Renders by pararch
Top angle renders
Bottom angle renders
One tone color renders
Two tone color renders
Wrist rest
Wrist rest is a concept, will not be polycarbonate because it is too large to be PC and will definitely yellow overtime.
Most likely if this is going to come to reality the body might be anodized aluminum or wood (not decided yet)
and will have an colored anodized aluminum accent at the end of it.
Physical specs:
- Typing angle 5.5
- Mounting: Top mount + Burger mount using o-rings
- Front height: 20.6mm
- Seamless design
- Anodized aluminum body
- Internal brass weight sandblasted
- Anodized aluminum plate (Only aluminum material option for now, will try including PC and brass)
PCB Specs: (Designed by Gondolindrum)
- Features daughterboard
- VIA/QMK compatible
- ESD protection
- USB-C port
- Mirrored numpad
- ISO support
- Clicky rotary encoder
- LED indicators
- 9.5 degree angle on alphanumericals
- Soldered only
Layout of the PCB
USB-C port
Exploded render of knob, top frame, bottom frame, and case foam.
Flex cuts on plate which will create a more flexible typing experience.
Internal of mounting which is top mount + burger mount with o-rings
Plate is sandwiched between o-rings from bottom and top.
Knob will come in silver option too, or gold if you prefer it like in the renders.
FAQ
When will keycap renders come in??
- Soon, sometime around this month. Just wanted to update this post since it was gaining a lot of attention.
How many units?
- Depends on demand
Any estimation on price?
- TBD
When will prototype happen?
- Will order prototype hopefully around this month or end of this month.
Any more questions please comment below and I'll respond!
VENDORS
- Vala Supply (US)
- Keebwerk (EU)
« Last Edit: Wed, 21 July 2021, 09:01:57 by yoboard »
Offline MIGHTY CHICKEN
Love the layout
Offline HoodrowThrillson
Re: [IC] Mountain Alice - Full-sized Alice, Southpaw, Seamless
« Reply #2 on: Sun, 14 February 2021, 18:12:17 »
so the renders are wrong?
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #3 on: Sun, 14 February 2021, 18:13:42 »
No, they are what the Alice keyboard is now, and update model will be posted soon.
Offline Alejo1707
  • Gimme some more caps!
« Reply #4 on: Sun, 14 February 2021, 18:15:42 »
Make it south paw!
Sent from my GM1917 using Tapatalk
Offline Jacki
« Reply #5 on: Sun, 14 February 2021, 18:17:42 »
Any chance for supporting ISO enter :-[?
[img width=267 height=120]https://i.imgur.com/in3VqH2.jpg[/img
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #6 on: Sun, 14 February 2021, 18:20:13 »
Unfortunately, I tried and it is possible but the position of the keys would be similar to an ortholinear and would be awkward. This isn't the final design, I still am trying ways to add ISO support.
It might be added to the next revision the model!
Offline klexoslethal
« Reply #7 on: Sun, 14 February 2021, 18:22:39 »
This looks insane, what are the dimensions of the board?
Offline o3okevin
« Reply #8 on: Sun, 14 February 2021, 18:25:32 »
Cool stuff! Excited to see how this goes
Offline Nyeezy
« Reply #9 on: Sun, 14 February 2021, 18:25:41 »
In for southpaw
Offline noodleman
« Reply #10 on: Sun, 14 February 2021, 18:36:06 »
would actually prefer non-southpaw, looks very interesting tho!
Offline Tree_
« Reply #11 on: Sun, 14 February 2021, 19:19:34 »
Would prefer non-southpaw.
But who am I kidding? At $500USD I'm not copping anyway.
Offline hali
    • hali.studio
« Reply #12 on: Sun, 14 February 2021, 19:30:03 »
godspeed gk64 shift
Offline vi0till
« Reply #13 on: Sun, 14 February 2021, 20:49:48 »
Yeah, any chance to offer both layout?
Sent from my VOG-L29 using Tapatalk
Offline Dunne
    • Dunne
« Reply #14 on: Sun, 14 February 2021, 21:55:24 »
This is big brain, do you have any socials or do we keep track of your project solely on GH?
Offline Aritega
    • Art by ringo
« Reply #15 on: Sun, 14 February 2021, 22:00:30 »
What I like about the old layout is the extra key next to the "T" key, as for those who press "Y" with both left and right fingers might bind that. I think adding it back to the new layout could make it more easier to adjust.
Offline FlitzDeelman
« Reply #16 on: Sun, 14 February 2021, 23:18:35 »
I like the Southpaw!
Will the PCB have features like ESD protection? And I could have missed this - will it be VIA / QMK compatible?
Offline rooski15
« Reply #17 on: Sun, 14 February 2021, 23:54:06 »
That 2u right shift is kind of a compatibility killer - any chance at either a 2.25 or 1.75, making it a more standard size?
Offline dudewth
« Reply #18 on: Mon, 15 February 2021, 00:24:44 »
Looks nice. Interested in old/non-southpaw
Offline 2QT2BSTR8
« Reply #19 on: Mon, 15 February 2021, 00:46:03 »
Amazing. Will be following closely.
Offline Ustinj
« Reply #20 on: Mon, 15 February 2021, 01:03:28 »
I like the new and fresh variation on the Alice layout, but not so excited about having 'Alice' in the name.
Offline danieljgrouse
« Reply #21 on: Mon, 15 February 2021, 01:31:15 »
I absolutely love this and am looking forward to the southpaw renders. I’d love to see stepped caps lock be available on the non-southpaw version as well.
Offline hottrout
  • I'd Hit Dat Key
« Reply #22 on: Mon, 15 February 2021, 02:19:36 »
Yes, yes , yes.  Love everything about this, a full size alice for work.  Are you going to do a southpaw as well or replace this design with it?  Please if possible run this version first.  If I can also suggest that you run the wrist rest for it at the same time as the correct wrist rest is needed for proper alice use.
Good luck with this.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline ctrl+shift+n
« Reply #23 on: Mon, 15 February 2021, 02:33:32 »
interesting.
Offline Suavity
  • Smile more! 🙂
« Reply #24 on: Mon, 15 February 2021, 02:54:53 »
Now this is super cool. Mirrored Southpaw please. :thumb:
Offline cmadrid
« Reply #25 on: Mon, 15 February 2021, 03:47:21 »
Wow, that is impressive AND awesome looking!
Offline RA Can
« Reply #26 on: Mon, 15 February 2021, 05:09:45 »
looks nice. hope to see a proto soon
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #27 on: Mon, 15 February 2021, 05:32:41 »
It will be supporting stepped caps lock as well!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #28 on: Mon, 15 February 2021, 05:33:44 »
Planned on also modelling a custom wrist wrest for this. Will see how it goes if the people like it or not.
I'll probably make it an option for extras.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #29 on: Mon, 15 February 2021, 05:34:17 »
43cm by 14cm
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #30 on: Mon, 15 February 2021, 05:35:03 »
Will add that extra key back.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #31 on: Mon, 15 February 2021, 05:35:45 »
Very unlikely. Most likely depends on demand which layout receives the most attention and that will be the final layout.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #32 on: Mon, 15 February 2021, 05:36:36 »
I will be creating a discord server for updates regarding this Alice Mountain.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #33 on: Mon, 15 February 2021, 05:37:20 »
Yes, it will have ESD protection and be VIA / QMK compatible.
That is our initial plan for the PCB.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #34 on: Mon, 15 February 2021, 05:39:03 »
Yes, I could change it to either 2.25 or 1.75. I'll update you on the second revision of the model.
Offline vi0till
« Reply #35 on: Mon, 15 February 2021, 05:55:19 »
ok. Most likely depends on demand which layout receives the most attention and that will be the final layout.
Maybe IC form to vote the layout?
« Last Edit: Mon, 15 February 2021, 05:57:21 by vi0till »
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #36 on: Mon, 15 February 2021, 06:06:48 »
Yes, that will happen very soon. Anytime this week.
« Last Edit: Mon, 15 February 2021, 06:09:07 by yoboard »
Offline El_Jackador
« Reply #37 on: Mon, 15 February 2021, 06:19:11 »
I dont like full size but damn this is cool!
« Reply #38 on: Mon, 15 February 2021, 09:29:27 »
I want it, yes.
« Reply #39 on: Mon, 15 February 2021, 10:25:53 »
Great, thanks!
Offline Jinho
  • hello
    • i used to build keyboards
« Reply #40 on: Mon, 15 February 2021, 11:55:53 »
i am so confused, is this a southpaw board or not
iu / jinsoul / xiyeon / ogre / nunu / 378 / x60 v2 / derivative / unikorn hk / lamy / calliope / dolice / harbour / xeno / 87u
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #41 on: Mon, 15 February 2021, 12:01:09 »
There will be soon an IC Form to determine what majority of people like. (Southpaw or not)
For now this is a non-southpaw board.
Offline huey
« Reply #42 on: Mon, 15 February 2021, 12:08:24 »
Interesting project. Do you care to provide more details about the mounting system and case screws? The renders do a fine job of explaining the exterior but there is nothing for the internals.
You are going "screw-less", but the only way I can see that being possible(based off the renders you have provided) is having 4 screws under the feet(which isn't enough for even a 60% gasket board).
I'm very confused about the move to a south-paw design. This is generally a polarising opinion. Is this something you actually wanted to do before posting the IC, and couldn't decide on? Or are you just accomodating to requests made by people in this thread? It's been live for a day and you're fundamentally changing the layout and will have to remodel everything. This is incredibly odd for a personal project but makes sense if you're just designing for what "people want"(which isn't the way to go about projects imo).
I personally deteste designer names or logos on the exterior of boards("designed by X") because I believe it only serves a purpose for the board designer and no one else. I think an internal engraving is much more fitting for this application. Understandable if you wouldn't want to make this change; I understand it's an opinion.
GLWIC
Offline Alejo1707
Re: [IC] Mountain Alice - Full-sized Alice: IC FORM is out for southpaw layout!
« Reply #43 on: Mon, 15 February 2021, 12:53:15 »
Man there are people interested in your project, please update renders and reply to suggestions.
I personally don't like the designer's name on the board either, the name of the keeb is fine tho :D
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #44 on: Mon, 15 February 2021, 13:05:50 »
GLWIC
Thanks for you reply, I wanted to create a keyboard for myself and the community too. But I couldn't decide if whether people wanted southpaw or not. (I don't mind southpaw or not). So I created an IC Form for the community to decide whether they want southpaw or non.
I'm just showing the incomplete version of the non-southpaw version of the model. Screws will be from the top of the board, not under the feet.
The brass weight will also have some changes in the second model.
I also plan on removing that designed by yoboard and adding a aesthetic logo instead.
I know you can't see them but I will only complete this model (non-southpaw) if the community prefers this layout. For now, there is no point putting any more work into this model until the community votes on the layouts in the IC form.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #45 on: Mon, 15 February 2021, 13:07:42 »
Thank you! I'll update the renders when the IC form is complete.
I need to know if the community prefers a southpaw or non-southpaw layout. Then I will do a remodel of this keeb.
For now the renders just show a representation of the board. (non-southpaw)
Offline noodleman
« Reply #46 on: Mon, 15 February 2021, 16:43:11 »
i think if you can do a quick render of the southpaw version so people can compare the two and make a decision
Offline Alejo1707
« Reply #47 on: Mon, 15 February 2021, 18:16:37 »
+1 on the idea
Offline FaIIen
« Reply #48 on: Mon, 15 February 2021, 18:57:07 »
What a layout, love it!
Offline DERBS
  • N E 3u bars avail?
« Reply #49 on: Tue, 16 February 2021, 06:53:04 »
+1 for southpaw, I forgot to mention the mirrored numpad for southpaw in the IC form.
TY for making this, would be my first ergo Alice style keyboard if this some to fruition
