Author Topic: [IC] Mountain Alice - Southpaw Alice with ISO support! (KEYCAP RENDERS OUT)  (Read 122287 times)
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
Re: [IC] Mountain Alice - Full-sized Alice: IC FORM is out for southpaw layout!
« Reply #50 on: Tue, 16 February 2021, 10:36:22 »
+1 for southpaw, I forgot to mention the mirrored numpad for southpaw in the IC form.
TY for making this, would be my first ergo Alice style keyboard if this some to fruition
You're welcome  ;)
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #51 on: Tue, 16 February 2021, 10:36:46 »
Offline mutthunt
« Reply #52 on: Tue, 16 February 2021, 11:42:55 »
I would absolutely love an ISO version, though I understand the constraints of asking for that.
Regardless this looks amazing..
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #53 on: Wed, 17 February 2021, 10:05:50 »
I'm trying my best to add ISO support without ruining the layout! thank you.
Offline Full
Re: [IC] Mountain Alice - Full-sized, IC FORM: One week left.
« Reply #54 on: Wed, 17 February 2021, 14:16:50 »
Love it!  :thumb:
Hi!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
Offline Unenlightenment
« Reply #56 on: Wed, 17 February 2021, 20:46:24 »
Please, southpaw alice, it will be beautiful
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #57 on: Thu, 18 February 2021, 07:11:20 »
Enter the IC form if you prefer a southpaw alice.
Offline FlitzDeelman
« Reply #58 on: Thu, 18 February 2021, 08:09:03 »
Thanks, I see you have updated the IC with details around PCB (ESD protection, etc).
Once the design has progressed that far, I would like an exploded view, like huey asked earlier as well, to show the internals. And if you could also organise some renders of the board with some keycaps, in planned colours, that would be great.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #59 on: Thu, 18 February 2021, 08:28:45 »
All of that will be included.
« Reply #60 on: Thu, 18 February 2021, 08:31:06 »
Great, thanks!
Offline msieben
« Reply #61 on: Thu, 18 February 2021, 10:11:57 »
Love the non-southpaw!
I was pissed I JUST missed the FLX Virgo which is essentially this keyboard, with with 10-key.  And I work in IT and use the 10-key a TON!  Would be perfect keeb.
I would also like to see color renders.  HUGE fan of the Dark Purple, Dark Green, Deep Burgundy color swatches.
Cheers!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #62 on: Thu, 18 February 2021, 12:56:03 »
Cheers!
I will be including multiple color renders and I am also trying to make the whole layout symmetrical as possible!
Offline treeleaf64
    • treeleaf64
« Reply #63 on: Thu, 18 February 2021, 20:22:00 »
What does Gasket + Top mount mean
Can you do more renders
Do you have a prototype coming
Everyone must pay the cat tax
Offline not-a-seal
« Reply #64 on: Fri, 19 February 2021, 00:03:35 »
you got +1 for southpaw
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #65 on: Fri, 19 February 2021, 03:22:09 »
I have enough budget for a prototype. Gasket means there are foams on the side of the plate to dampen sound and reduce vibrations when typing and top mount means it's mounted to the top frame of the keyboard.
There's an IC form to determine the final layout of the design. Once it is done I will design the case and PCB and have the prototypes ready by then.
Offline vi0till
« Reply #66 on: Fri, 19 February 2021, 03:24:00 »
You will use o-ring for the gasket mount?
Sent from my VOG-L29 using Tapatalk
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #67 on: Fri, 19 February 2021, 04:08:08 »
No, it will be foam. The material of the foam is not decided yet. But i'm thinking of neoprene.
Offline Rx003
« Reply #68 on: Fri, 19 February 2021, 04:59:50 »
Very very interesting design choice for the Alice. Glwic
Offline mechs
  • www.mechs.io
    • The Mechanical Keyboard Directory
« Reply #69 on: Fri, 19 February 2021, 05:15:25 »
IC submitted. +1 Southpaw! Been waiting for this layout since forever.
Offline Draxthor
« Reply #70 on: Fri, 19 February 2021, 05:38:42 »
Love the southpaw version. Only I would change is not have a spacer/gap that elavates the F1~F12 row, in doing so it will resemble a true 1800 compact layout. This is insta buy!
Offline RicWatt
« Reply #71 on: Fri, 19 February 2021, 06:35:07 »
In for a south paw variant, this look amazing!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #72 on: Fri, 19 February 2021, 13:00:46 »
 :thumb:
Offline Fraudrin
Re: [IC] Mountain Alice - Full-sized, IC FORM: 4 days left!
« Reply #73 on: Sat, 20 February 2021, 14:38:48 »
Interested in this greatly.
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #74 on: Sun, 21 February 2021, 08:59:52 »
i like this
pls make this
big thank
yes
Offline 2Moons
« Reply #75 on: Sun, 21 February 2021, 09:01:26 »
If there is an option for a full 2U numpad 0 key, I'm in.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #76 on: Sun, 21 February 2021, 09:11:40 »
It is a mirrored numpad. So yes.
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #77 on: Sun, 21 February 2021, 13:59:55 »
i like this
pls make this
big thank
yes
no problem
saw ur stream
big thank for feedback
Offline 2Moons
« Reply #78 on: Sun, 21 February 2021, 15:42:22 »
If there is a normal full size option, not a southpaw or 1800, that would be awesome.
Offline handmademedal
« Reply #79 on: Mon, 22 February 2021, 00:18:41 »
this is so good
Offline Draxthor
Re: [IC] Mountain Alice - Full-sized, IC FORM: closed. (Southpaw wins)
« Reply #80 on: Wed, 03 March 2021, 17:28:47 »
Hey!
Any updates on this?
And will it support bluetooth?
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #81 on: Thu, 04 March 2021, 06:07:39 »
Hey!
Yes, I have been working non-stop and with the PCB designer (Gondolindrum) who will be designing the PCB of this board. (Unfortunately no bluetooth)
I can give you the official details of the new Mountain Alice
- Rotary Encoder
- ISO Support
- Mirrored Numpad
- Southpaw
- OLED Screen
More details will come by soon when the decision is final.
« Last Edit: Thu, 04 March 2021, 06:14:02 by yoboard »
Offline yui
« Reply #82 on: Thu, 04 March 2021, 07:03:07 »
- ISO Support
nice to see iso support, although i thought it was impossible on alice-style boards curious to see how it will work.
and being left handed on computers (my mouse is on the left, i am somewhat ambidextrous, depends on what i do) i do not really understand how having the numpad on the left helps, i would actually think that to be better for right handed peoples? or am i completely wrong in understanding that southpaw layouts were for lefties?
Offline Lord_Rabel
  • The geek that doctors trust.
« Reply #83 on: Thu, 04 March 2021, 08:06:50 »
So that the southpaw wins in your IC does that mean, that there will be no regular 1800 version?
Offline Reaper235
« Reply #84 on: Thu, 04 March 2021, 08:30:49 »
- ISO Support
some people who play these Video Games prefer having more space for their mice with compact boards and with a southpaw you can have more Space for your mouse AND still have Numpad :-)
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #85 on: Thu, 04 March 2021, 12:16:20 »
It's still a 1800 Alice. Just southpaw
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #86 on: Thu, 04 March 2021, 12:17:35 »
- ISO Support
Purely for ergonomic or aesthetic preferences. There was an IC form between Southpaw and non-southpaw layout and southpaw won by a significant.
Offline Lord_Rabel
« Reply #87 on: Thu, 04 March 2021, 12:38:20 »
Yeah, so no regular 1800. :C What a bummer. Would have been an instant buy if it would be
Offline yui
« Reply #88 on: Fri, 05 March 2021, 03:15:59 »
- ISO Support
I understand why this board is southpaw, what i did not understand was the popularity of southpaw, because my understanding was that it was meant to be more ergonomic for left handed peoples, and that made no sense to me, but someone else corrected my wrong beliefs on the subject
still rather curious about how the iso is going to fit, as i stayed away from alice for the lack of ISO support.
Thanks for the reply though :).
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #89 on: Fri, 05 March 2021, 04:29:53 »
- ISO Support
I can assure the ISO fits quite nicely! It took me a week trying to make it fit without ruining the alice layout symmetry.
Offline Hi !!
  • Kiimari
« Reply #90 on: Fri, 05 March 2021, 04:34:28 »
Yes to Southpaw! although not a fans of knob. looking forward for proto and such.
Offline DERBS
  • N E 3u bars avail?
« Reply #91 on: Fri, 05 March 2021, 04:56:46 »
Hey!
- Rotary Encoder
- ISO Support
- Mirrored Numpad
- Southpaw
- OLED Screen
Not really a fan of the OLED at all
I can live with the rotary encoder(although prefer not to)
Love me some mirrored numpad :p
Also 3u support!( Which I think was already confirmed!) ^-^
Thanks again for making this!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #92 on: Fri, 05 March 2021, 07:41:50 »
Hey!
- Rotary Encoder
- ISO Support
- Mirrored Numpad
- Southpaw
- OLED Screen
Yes. 3u bar support for both sides.
My pleasure!
Offline vallaton
« Reply #93 on: Fri, 05 March 2021, 14:05:06 »
got really excited about the extra key on the left side y-spot, but i see that it's gone now. i feel like this is the biggest issue i have with split keebs as i tend to lean right with my right hand (finnish speaker/writer here, so heavy usage of the scandi keys).
would love to get a full size alice (don't really care if the numpad is regular or southpaw as long as there is a fully functional one) for my home studio, but not so keen on added rotary or oled.
i'll follow the progress with great interest. good luck with everything!
Offline yoboard
  • Keyboard Designer
    • Keyboard Designer
« Reply #94 on: Fri, 05 March 2021, 14:29:37 »
The extra Y is added back, don't worry.
Offline dudewth
« Reply #95 on: Fri, 05 March 2021, 16:32:18 »
Didn't realize southpaw was so popular. I was hoping for regular. Thanks for IC.
Offline MarshNoFufu
« Reply #96 on: Mon, 08 March 2021, 06:17:01 »
I absolutely love this case, specially in southpaw :thumb: :thumb:
Offline AdeelDante
« Reply #97 on: Mon, 08 March 2021, 13:11:09 »
Great Keyboard. But you are not the first. There is a Korean designer who made this style of keyboard already. Its called the COX CA106. Here is the link. https://www.reddit.com/r/MechanicalKeyboards/comments/jv2tmp/cox_ca106_korean_fullsize_ergo_keyboard/
Regardless big fan of this with Southpaw!
« Last Edit: Mon, 08 March 2021, 16:46:26 by AdeelDante »
Offline Rika
« Reply #98 on: Wed, 10 March 2021, 11:14:38 »
ooooh this looks neat
Southpaw good!
Offline tngpq
« Reply #99 on: Wed, 10 March 2021, 11:29:50 »
Yup. FYI, that is not a custom. Cox is a sub-brand of Abko which is a pretty big company.
