Author Topic: 3D printed Keycaps  (Read 4900 times)
Offline NilKeebs
3D printed Keycaps
« on: Thu, 18 February 2021, 12:28:37 »
Hi everyone,
Just wondering if 3D printing a keycap is a viable process compared to creating it using other methods?
I have a friend who has a 3D printer and I wanted to know if it's cost effective and if it will work at all?
  :D
Offline nevin
Re: 3D printed Keycaps
« Reply #1 on: Thu, 18 February 2021, 13:16:23 »
yes, caps have been made in various profiles with varying success. check thingiverse or similar, sure you'll find a handful.
Offline Keyboard_Warrior364
  • Instagram: armourgrade
« Reply #2 on: Thu, 18 February 2021, 15:34:44 »
Its possible, I've done it, but the finish wasnt that great. It's usefull for prototyping, but casting it is obviously better. If your friend has a UV printer then the finish will be a bit better, but youll need to paint it for UV protection.
Offline Leslieann
« Reply #3 on: Thu, 18 February 2021, 20:41:56 »
Yes, it can be done, but it;s not so easy on an common FDM to get the fit right and the finish isn't great as mentioned.
A resin printer will do a better job but may not be what you're expecting.
In all cases it's quite a lot of work for something you can buy in better quality in more colors, with or without legends for the price of a roll of plastic. You can more than likely order and recieve them from Amazon faster and cheaper than you can print them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline NilKeebs
« Reply #4 on: Fri, 19 February 2021, 02:36:25 »
Thanks everyone! I'll skip 3d printing for now then cause it seems that the cons outweigh the pros for now. ;D
  :D
