Author Topic: [IC]NIZ Duo82 update more design 3rd March updated  (Read 24455 times)
Offline Nizkeyboard
    • nizkeyboard
« on: Sun, 21 February 2021, 19:58:01 »
Hello everyone,
With production underway for our last project, the NiZ Atom 68 II, we are now ready to begin the Interest Check phase for our new project: the NiZ Duo82. The NiZ Duo82 is a custom aluminum case for the NiZ Micro82 electrostatic-capacitive keyboard, with a design inspired by the Anologue Duo video game console (https://www.analogue.co/duo).
We built the first prototype months ago and have produced more than 20 samples since then, improving the design based on the feedback we have received on the early renders and prototypes from our communities on Discord and zFrontier. Most notably, the design of the decorative waves on the back of the case has been altered to optimize the size and shape, at the suggestion of our users. The rendering below shows the improved design, and we expect to have a new prototype using this design produced in 2-3 weeks.
Basic Information
Typing Angle: 6°
Case options:
Aluminum:Coating( Black, Gray, Silver, Yellow, White, Blue,Pink)
Polycarbonate: Frosted White with anti-scratch coating
Weight options: Coating( Black, Gray, Silver, Yellow, White, Blue,Pink)
Brass: Transparent electrophoresis coating
Plate options:
Alu:Coating( Black, Gray, Silver, Yellow, White, Blue,Pink)
Brass:Transparent electrophoresis,coating( Black, Gray, Silver, Yellow, White, Blue,Pink)
FR4:Black with gold trim, White with platinum trim
*Plates are 1.5mm thick
Stabilizer options:
    Costar stabilizers
    Cherry-style plate-mount stabilizers
   *Each plate will be cut to support only one style of stabilizers
Plate mounting system:
Top mount
PCB:
NIZ electrostatic-capacitive PCB with USB Type-C daughterboard
Programmability:
Fully programmable using NiZ software
Battery:
2500mah - 5000mah
Keycaps:
Compatible with all profiles of Cherry MX-style keycaps
Domes:
35g/45g/50g/60g/65g
Layout:
   75% layout
1.75u Right Shift
1u Right Ctrl, Fn, and Alt
6.25u Spacebar
Price:
      TBD
Pictures:
Add more pic
FAQ:
Q:What quality can be achieved in the finished?
A:Allows some blemishes that are usually not seen when the keyboard is assembled or built. This can be anode or tooling marks. Small color differences between different same-color parts can be seen as well.
Q: Can you change the layout?
A:No
Q:How will the keyboards be programmed?
A: Will be programmable by NIZ firmwire, and the latest firmwire will regularly update by discord.
https://discord.gg/fKdrR8Manj
« Last Edit: Thu, 04 March 2021, 03:27:58 by Nizkeyboard »
Offline firewrath9
Re: [IC]NIZ Duo82
« Reply #1 on: Sun, 21 February 2021, 19:59:59 »
ooh i like!
cool to see some custom electrocapacitive boards!
GLWIC!
Offline mydens
Re: [IC]NIZ Duo82
« Reply #2 on: Sun, 21 February 2021, 20:09:12 »
how about a 1800 layout
Offline IMZO
  • Matrix shill, and TKL WKL Lover
Re: [IC]NIZ Duo82
« Reply #3 on: Sun, 21 February 2021, 20:50:04 »
Ok , i like it
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline tehfrawg
Re: [IC]NIZ Duo82
« Reply #4 on: Sun, 21 February 2021, 21:06:45 »
Have you seen this yet?
Offline online
Re: [IC]NIZ Duo82
« Reply #5 on: Sun, 21 February 2021, 23:29:29 »
Love to have a 82 ec board. not so sure about the bump on the forehead tho...
Offline ycanales
    • keybordist
Re: [IC]NIZ Duo82
« Reply #6 on: Mon, 22 February 2021, 06:29:49 »
Sweet
Offline powwu
    • Discord
Re: [IC]NIZ Duo82
« Reply #7 on: Mon, 22 February 2021, 07:27:29 »
Definitely interesting. EC is nice, glad there's more stuff coming out for it.
The layout reminds me of the Toad, which I have been a fan of for a while.
I'm not a big fan of the forehead extrusion. It's like you birthed a baby, and then purposefully gave it a defect so it would be different.
Offline Livid
Re: [IC]NIZ Duo82
« Reply #8 on: Mon, 22 February 2021, 12:56:09 »
But at least it looks different, much better than looking the same as everything else out there imo. And I actually like it, I can definitely see the inspiration
Offline online
Re: [IC]NIZ Duo82
« Reply #9 on: Mon, 22 February 2021, 14:10:50 »
I'm not sure about the forehead too, it reminds me of HHKB Bluetooth hump. Look from the top view is okay, but the grill and USB cutout seems to be overdesigned. (I'm also curious about the machinability of the grill.)
The design stands out from other boards for sure, but I don't think it works well here tho. Too much going on and yet they don't serve any purpose to set a theme or provide utility.
I also think brass strip and weight are becoming cliche in custom keyboards. I guess that's just my personal taste.
IMO, 75 EC board with Bluetooth in a simple custom case alone is different enough to stand out from the crowd.
I'm not trying to hate on this. I've been watching this on Discord and drooling for a custom 75 EC board for a long time.
I hope there will be an option with no grill. I'll definitely in for 75 EC board in PC case, but not with the grill.
Offline LeoneShamoth
Re: [IC]NIZ Duo82
« Reply #10 on: Mon, 22 February 2021, 15:01:27 »
All jokes aside I think the board looks great and I am definitely interested. I hope the bluetooth is done well and will wait to see how prototypes go.
Offline Tree_
Re: [IC]NIZ Duo82
« Reply #11 on: Mon, 22 February 2021, 15:56:15 »
Not a fan of the "forehead" but I do like the wave design piece.
What's the purpose of the acrylic window on the bottom of the case?
Offline HelloThisIsDog
Re: [IC]NIZ Duo82
« Reply #12 on: Mon, 22 February 2021, 16:14:37 »
The forehead is over designed and gaudy and I want it. It looks over the top in an industry aesthetic where most boards look the same except for one tiny gimmick. I for one find it attractive and refreshing.
Offline Nizkeyboard
    • nizkeyboard
Re: [IC]NIZ Duo82
« Reply #13 on: Mon, 22 February 2021, 20:56:36 »
For Bluetooth signal
Offline Nizkeyboard
    • nizkeyboard
Re: [IC]NIZ Duo82
« Reply #14 on: Mon, 22 February 2021, 20:57:52 »
thanks you
Offline Nizkeyboard
    • nizkeyboard
Re: [IC]NIZ Duo82
« Reply #15 on: Mon, 22 February 2021, 22:22:34 »
 Could you take a quick poll when you have time?https://forms.gle/DUJHqcwsJMzx2CKn6
Offline Suavity
  • Smile more! 🙂
Re: [IC]NIZ Duo82
« Reply #16 on: Mon, 22 February 2021, 23:01:09 »
Any considerations for a southpaw 1800 layout?
Offline Nizkeyboard
    • nizkeyboard
Re: [IC]NIZ Duo82
« Reply #17 on: Mon, 22 February 2021, 23:21:28 »
sorry,not yet
Offline CodeMayhem
Re: [IC]NIZ Duo82
« Reply #18 on: Tue, 23 February 2021, 09:59:30 »
The one brass accent that has visible screws is the one that is one top, no way to modify the way those two accents are mounted so that they're on the under side?
also is that a 3/4ths spacing between the esc and f-row and then 1/3rd spacings from there?
« Last Edit: Tue, 23 February 2021, 10:06:30 by CodeMayhem »
Offline made in China
Re: [IC]NIZ Duo82
« Reply #19 on: Tue, 23 February 2021, 20:24:45 »
As for the appearance, we are collecting opinions. If it is convenient, you can join our Discord and discuss together
Offline Nizkeyboard
    • nizkeyboard
Re: [IC]NIZ Duo82
« Reply #20 on: Wed, 03 March 2021, 04:37:30 »
add more renders
Offline Oni74
Re: [IC]NIZ Duo82 update more design 3rd March updated
« Reply #21 on: Sat, 17 April 2021, 01:53:30 »
Thanks for bringing a premium 75% EC board to IC. Very much interested, without the funny protrusion up top.
I do have a specific request:
Can you PLEASE make it easier to swap domes on your board? I have a Micro 82 and the lack of dome guides makes it all but impossible to eliminate spring noise due to misaligned domes. I understand you are making different dome sheets of varying weights available, but many of us want to use BKE/DES domes.
Offline samuryan
« Reply #22 on: Tue, 20 April 2021, 19:10:29 »
I really enjoy the look of this case.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #23 on: Mon, 03 May 2021, 17:15:43 »
Just found out about this yesterday, are they already sold out or just not available yet?
Offline strongly-typed
  • lux et veritas
    • Github
« Reply #24 on: Tue, 04 May 2021, 19:20:08 »
It's not available yet.
Realforce 87U 45g Silent :: Realforce 87U 30g Silent :: Realforce R2 55g :: Niz Plum 87 with 45g topre domes
English | Spanish | Italian | Latin | Portuguese | Mandarin | Cantonese | Japanese | Welsh | OCaml
Offline u1ti
« Reply #25 on: Sun, 09 May 2021, 14:17:46 »
I love that pink/green version!  Would go perfect with epbt Aesthetic.
Offline gloomycloud
  • me enjoy 60s
Re: [IC]NIZ Duo82
« Reply #26 on: Tue, 11 May 2021, 07:53:36 »
Excited about this, how about smaller blocker? like 0.5u
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline i luv chuletas
« Reply #27 on: Tue, 11 May 2021, 08:48:22 »
Holy hell, I was not ready for that teal and orange combo in WKL... :eek:
Congrats guys, the design will be polarizing but damn it's beautiful.
Reading through the description it seems that this IC is for the case and the PCB, is this correct?
Also, is this planned to be an unlimited gb?
Either way, please keep the WKL as an option, looks much better than without the blocker IMO.
Thank you, this for sure will be my first EC board, very exciting!
« Last Edit: Tue, 11 May 2021, 09:03:32 by i luv chuletas »
Offline Necrolegion
« Reply #28 on: Thu, 13 May 2021, 03:22:46 »
Please go through with this. Keyboard is beautiful! I love all the complicated pieces. That teal and orange will go perfect with GMK Retrocast, GMK Kaiju, or GMK Baltic!
