Author Topic: [GB] KORNO65 - 65% screwless Keyboard(living now)  (Read 11781 times)
Offline antcrm
« on: Wed, 24 February 2021, 04:45:06 »
Hello here is what I am going to show today-Korno65.The author is Zhou from China. Korno65 has already had a groupbuy on ZF about 3 months ago, and has been well received by everyone. After improving part of the structure, we brought it to Geekhack this time, I hope you like it.
Basic information
Typing Angle: 6.5 °
Case  options:
Aluminum: Anodized Black & Grey& Silver, E-White & Yellow;
Mounting method: typing feel awesome gasket
Plate:Polycarbonate (White Frosted) and FR4 (Black with Gold Trim) plate has fixed points at four corners to ensure the same typing feel throughout the keyboard
PCB:1.6mm Black-Gold with USB Type-C DaughterBoard,Fully Programmable Using QMK&VIA
  1 hot swapped
  2 solided
The whole case adopts the hidden screw design, after the completion of the installation of the keyboard, the whole external surface is invisible screw.
Pics:
 renders
prototype:The image is from the previous version. The weight section has a slight appearance change
The suite includes:
1, Top and bottom case *1;
2, PC plate *1 and FR4 plate *1;
3. Brass weight*1
4, PCB (including Type-C daughter  board) *1;
5. Muffler poron pad;
6, sandwich poron pad;
7, poron strip;
8. Cherry-style pcb-mount stabilizers
9. screws.
Group Buy Information
1 Launch Date:2021.02.26(Beijing time 9:00)
2 Group Buy duration:the group buy will run for 7 days 3Shipping estimate:within 2 months after the close of the GB
3 Price:suite:300usd,not contain platform fee 20$(papal) and shipping fee TBD(The freight is expensive in a short period of time, so no charge will be charged. The final freight will be confirmed before delivery and then the bill will be sent)
4 GroupBuy Link:https://eschit.com/collections/ic-gb/products/gb-korno65s-r2-v3.
discord:https://discord.gg/PEqKw96qUq
2021.4.20 already shipped
« Last Edit: Sun, 20 June 2021, 03:03:19 by antcrm »
Re: [GB] KORNO65 - 65% Keyboard
« Reply #1 on: Wed, 24 February 2021, 16:12:18 »
Approved :thumb:
Offline Gondolindrim
    • My GitHub
« Reply #2 on: Wed, 24 February 2021, 16:27:22 »
Aren't you the Cello65 designer/vendor?
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline HoodrowThrillson
« Reply #3 on: Wed, 24 February 2021, 17:19:57 »
ne photos avail
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #4 on: Wed, 24 February 2021, 18:17:10 »
In 2021, it's reasonable to expect a prototype demonstrating good-quality anodizing, parts that fit well together, a sensible USB port, and the internal design. Where is yours?
Offline antcrm
« Reply #5 on: Wed, 24 February 2021, 19:15:24 »
Add prototype pic,thank you
Offline firewrath9
Re: [GB] KORNO65 - 65% screwless Keyboard
« Reply #6 on: Thu, 25 February 2021, 11:23:41 »
actually looks pretty good tbh.
GLWGB!
Offline antcrm
Re: [GB] KORNO65 - 65% screwless Keyboard(living now)
« Reply #7 on: Fri, 26 February 2021, 20:43:12 »
GB is living now
