Author Topic: Finding dimensions for PCB cutout holes  (Read 1404 times)
Offline Leopard223
« on: Sun, 28 February 2021, 07:56:51 »
Working on some 3D printed macro pads, had the idea of making it hotswap.
Had an idea to make sort of a PCB, basically 2 layers holding hotswap sockets, and thought I might as well make cutout for the pins for proper fitting and alignment.
But I cant seem to find dimenions for the PCB, only diameter for the holes, my mockup is fairly accurate but the 2 extra PCB pins are definitely too far apart and cause them to bend.
Is there a blueprint available for PCB cutout dimenions?
Here's an example of my plan
« Last Edit: Sun, 28 February 2021, 07:58:32 by Leopard223 »
Re: Finding dimensions for PCB cutout holes
« Reply #1 on: Sun, 28 February 2021, 08:58:15 »
See the Cherry MX datasheet :)
You might also want to see what Leslieann had done with her 3D printed hotswap
« Last Edit: Sun, 28 February 2021, 08:59:57 by suicidal_orange »
Offline Leopard223
« Reply #2 on: Sun, 28 February 2021, 09:47:31 »
Seems like I missed that section of Geekhack, good to know, thank you!
