Author Topic: [IC] SP SA Prism | All in one | GB very soon  (Read 20193 times)
Offline RivieraS
  • Yutop
« on: Mon, 01 March 2021, 05:33:04 »
Hello everyone, welcome to the IC for SA Prism.
The set is based on Solarized Dark colorway, featuring support for 60%, 65%, 75%, 80%, 100% keyboards.
Renders
                                                           CA66 + SA Prism
                                                           U80 + SA Prism
  • Produced by Signature Plastics
  • SA profile
  • MX-style stem
  • ABS doubleshot legends
  • Made in the USA
Kit
2021/3/29 updated
GB Plan
TBC
« Last Edit: Mon, 29 March 2021, 09:00:11 by RivieraS »
Offline pears
  • Sneezing is painful
    • Bad Produce
Re: [IC]SP SA Prism
« Reply #1 on: Mon, 01 March 2021, 05:41:41 »
    Based on Solarized Dark colorway, featuring support for 60%, 65%, 75%, 80%, 100% keyboards.
    Rendering
    SA profile
    MX-style stem
    Made in the USA[/li]
    [li][/li]
I'm in
Getting punched in the face was the best thing that ever happened to me.
Offline RivieraS
  • Yutop
Re: [IC]SP SA Prism
« Reply #2 on: Mon, 01 March 2021, 05:50:50 »
    Rendering
    SA profile
    MX-style stem
    [li][/li]
I'm in
What? I pressed the wrong button. I haven't finished writing
Offline Alejo1707
  • Gimme some more caps!
Re: [IC]SP SA Prism - All-in-one
« Reply #3 on: Mon, 01 March 2021, 06:02:43 »
In as well.
Sent from my GM1917 using Tapatalk
Offline Darth_munkee
« Reply #4 on: Mon, 01 March 2021, 06:41:10 »
Any plans for ortho and/or ergo?
Offline thecyangiant
« Reply #5 on: Mon, 01 March 2021, 07:58:15 »
Yes, although very much looking forward to more info.
As mentioned above: Ortho & Ergo?
Will it have the non color mods?
Sent from my Pixel 4a using Tapatalk
« Last Edit: Mon, 01 March 2021, 08:00:18 by thecyangiant »
Offline RivieraS
  • Yutop
« Reply #6 on: Mon, 01 March 2021, 08:26:56 »
Sorry, maybe next time.
Re: [IC]SP SA Prism | All-in-one
« Reply #7 on: Mon, 01 March 2021, 08:39:22 »
Thanks for adding the kit render. I think there's a bit of work still.
- are the arrows supposed to be text in the dark color and symbols on the light color?
- R2 backspace?
- Alice support?
I think it's great to revive this clw (my all time favorite). I would bet that a lot of people would find the current offering insufficient for their needs
Offline valen_c13
« Reply #8 on: Mon, 01 March 2021, 09:09:19 »
"Made in the USA" for sure its very very interesting, but can we have at least split space?
Отправлено с моего HD1913 через Tapatalk
Offline RivieraS
  • Yutop
« Reply #9 on: Mon, 01 March 2021, 09:15:20 »
- R2 backspace?
- Alice support?
Arrows only suppose symbols on the dark color.We cut other plans.
R2 backspace.. You are right! Thanks! Revising
No Alice support this time. Sorry.
Offline yukitoki
« Reply #10 on: Mon, 01 March 2021, 09:21:49 »
gimmie  :eek:
Offline RivieraS
  • Yutop
« Reply #11 on: Mon, 01 March 2021, 09:25:31 »
Split space does not make much sense for 60%-100%, but it can be further expanded to support 40% and Alice, but more keys need to be added.
So we cut out split space.
« Reply #12 on: Mon, 01 March 2021, 09:29:45 »
To be fair, I run split space on all 60's and even some 65's
Offline darthcapn
« Reply #13 on: Mon, 01 March 2021, 09:34:33 »
In
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline NovaRMK
« Reply #14 on: Mon, 01 March 2021, 10:07:00 »
100% a buy from me. GLWIC!
Offline gbchk
« Reply #15 on: Mon, 01 March 2021, 10:42:22 »
Why 1.5u "Delete" instead of "Backspace"? It's the same key, just moved down a row and narrower, so why change the legend?
Offline thoughtworth123
« Reply #16 on: Mon, 01 March 2021, 11:42:00 »
Ah, my beloved blue. Definitely in!
Offline ManoliVisuals
« Reply #17 on: Mon, 01 March 2021, 13:05:31 »
In there like swim wear
Offline mimalik
Re: [IC] SP SA Prism | All in one
« Reply #18 on: Wed, 03 March 2021, 13:00:16 »
If possible, can the alphas, mods, numpad be split into 3 separate kits?? Def in.
Offline RivieraS
  • Yutop
Re: [IC] SP SA Prism | All in one | GB very soon
« Reply #19 on: Mon, 29 March 2021, 09:04:10 »
2021/3/29 updated
Offline Oddstag
« Reply #20 on: Mon, 29 March 2021, 10:34:37 »
UK ISO?
Offline hyppialonso
« Reply #21 on: Mon, 29 March 2021, 11:36:03 »
Told myself not to buy SP SA again after receiving the bad SP SA Laser set, but is a big friend of this colorway....
Offline Morgan3Wheeler
« Reply #22 on: Mon, 05 April 2021, 15:25:05 »
Need 1U R2'PgUp', R3''PgDn', R4'End' for 65%
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline gbchk
« Reply #23 on: Mon, 05 April 2021, 15:48:04 »
R3 PgUp and R4 PgDn would be super nice as well.
Offline fruitykeeb
    • Storefront
« Reply #24 on: Mon, 05 April 2021, 21:59:51 »
Wow, really love those colors. Count me in  ;)
Offline whezil
« Reply #25 on: Thu, 08 April 2021, 07:56:59 »
What about non-coloured mod's? Also, any estimate on pricing?
Offline Kerasan
« Reply #26 on: Fri, 16 April 2021, 04:21:57 »
Any news?
Offline singabore
« Reply #27 on: Mon, 03 May 2021, 17:51:31 »
looks like it ran in china this month! maybe intl. gb soon?
« Reply #28 on: Sun, 09 May 2021, 08:28:44 »
Do you have any plans for international GB?
Offline Alejo1707
« Reply #29 on: Mon, 17 May 2021, 09:15:36 »
Can I haz it pleaaase?
Offline D3LTA
« Reply #30 on: Mon, 17 May 2021, 09:47:56 »
Would have loved an ortho & colevrak+ kit. Will keep an eye out if there's ever a R2.
Offline Alejo1707
« Reply #31 on: Mon, 07 June 2021, 23:32:17 »
Any news on this front mate?
Offline oblivion3k
« Reply #32 on: Sun, 13 June 2021, 22:09:02 »
Definitely interested!
Offline HungHingDaiLo
  • 無間道
« Reply #33 on: Mon, 14 June 2021, 06:40:50 »
Will there be regional vendors for this set?
IG: @rayhhdailo
Offline ThickJimmy
« Reply #34 on: Tue, 15 June 2021, 21:21:47 »
Oh this is prettyyyyyyy. All I ask for is more renders please?
Offline Krionking
« Reply #35 on: Thu, 17 June 2021, 10:46:48 »
Are you not missing a 1.25 u shift and something for NUBS in row 4, for ISO?
Offline Bonobo
« Reply #36 on: Mon, 28 June 2021, 11:33:12 »
I'm in, yeah some new renders it would be good
Offline gbchk
« Reply #37 on: Sat, 17 July 2021, 11:10:58 »
Is this dead?
Offline Alejo1707
« Reply #38 on: Sat, 17 July 2021, 14:30:22 »
Is this dead?
Looks like, apparently it was run in China and that was it
Offline hqnam
« Reply #39 on: Sat, 07 August 2021, 13:34:51 »
Hello sir, any update on this?
