Author Topic: Aluminium TKL Keyboard case  (Read 4669 times)
Offline MrBoron
« on: Wed, 03 March 2021, 17:03:50 »
Hello,
I'm currently looking to build a custom keyboard and am looking for a Aluminium TKL keyboard case for around $150 USD (can go slightly over)
If anyone has any recommendations if you could send a link it would be greatly appreciated.
Offline Leslieann
Re: Aluminium TKL Keyboard case
« Reply #1 on: Wed, 03 March 2021, 20:57:45 »
Are you looking for just a case or a case and pcb, VERY few cases alone are made and they are usually made to be a matched set.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline subramandal
« Reply #2 on: Fri, 05 March 2021, 12:12:23 »
What you are asking for, is simply not feasible. TKLs are by far and large the most expensive out of any custom keyboard layouts. Their minimum price starts at around $350 and there are group buys right now selling just the alu case (w/o PCB) for $500+
KBDfans currently have some extra kits for their KBD8x MKII in alu and polycarbonate, and is probably the cheapest custom TKL you can buy right now:
https://kbdfans.com/search?page=2&q=kbd8x&type=product
The only other option closest to your price range is the Drop CTRL high-profile. While more of a 'barebones' kit than a 'custom' kit, this is as close as possible you can get to a custom 'feeling' keyboard.
Offline Maledicted
« Reply #3 on: Fri, 05 March 2021, 13:07:58 »
XD87 Custom Mechanical Keyboard Kit 80% Supports TKG-TOOLS Underglow RGB
https://kprepublic.com/search?type=product&q=tkl+kit
Offline Riverman
« Reply #4 on: Fri, 05 March 2021, 14:52:55 »
WASD Keyboards makes a TKL aluminum case for their keyboards that sells for $150.  I don't know what the chances are of another keyboard manufacturer's PCBs fitting in one of their cases, and they're out of stock of all three colors at the moment, but that might be something to consider.
https://www.wasdkeyboards.com/products/accessories/keyboard-parts.html
Offline phinix
« Reply #5 on: Fri, 05 March 2021, 15:40:18 »
I have one for sale - ID87 TKL alu hot-swappable Mechanical Keyboard Kit.
Its in perfect condition, already added Durock stabilisers but I can take them out and put original ones.
Its a bit more than you looking for but this is a full kit - case, pcb, full size original foam.
Just add switches and caps.
PMed
