Author Topic: [GB] MACRO-1 (Extras In Stock!)  (Read 48041 times)
Offline Laneware
    • Laneware Peripherals
« on: Fri, 05 March 2021, 00:19:50 »
Extras now Available
MACRO - 1
By Laneware Peripherals
Sound Tests by ByteSizedSeamus
SOUND TEST 1
SOUND TEST 2
Prototype Photos by Taeha Types
Prototype Stream & Photos by Manoli Visuals
Stream Highlight: Laneware MACRO-01 Thoughts
Full Build Stream
Build Streams & More Prototype Photos
Still to Come:
Build Streams: By ByteSizedSeamus & Manoli Visuals
Prototype Photos: By Taeha Types, ByteSizedSeamus & Manoli Visuals
Feedback Form
The design is finalised, however you can still use the below feedback form to register your interest and be notified when the build streams and GB goes live!
GB Key Information
Quantity: 500 Orders
Timing: 27th March 2021 at 20:00 PST for 1 Month or Until Sold Out
Projected Shipping Date: Late October
Details
Form Factor: Numpad
Layouts: Regular, Southpaw, Macropad
Angle: 7 Degrees
PCB: Type C, QMK/VIA, Rotary Encoder, Hotswap Option
Encoder: With Press Function
Plate: Aluminium 1.5mm
Weight: ~802g / 1.77lb
MACRO - 1 Kit Includes
Case: Annodized/Powder Coated Aluminium Top and Bottom
Switch Plate: Annodizes Aluminium, 1.5mm
PCB: Supports Layouts Shown Below
Hardware: Screws, Bumpons, Encoder Knob, Gaskets
Color Options
See the first comment on this thread for color and finish samples
Top:
Annodized Grey
Annodized Blue
Annodized Gold
Powder Coated White
Base:
Annodized Grey
Annodized Blue
Powder Coated White
Plate:
Annodized Gold
Price Tags (USD)
MACRO-1 Full Kit: $175
Brass Plate Upgrade: $15
Hotswap PCB Upgrade: $20 (Numpad layout only, encoder will also come pre-soldered)
Extra Top Color: $45
Extra Plate Aluminium/Brass: $20/$35
Extra PCB Standard/Hotswap: $30/$50
Extra Encoder & Knob: $10
Extra Feet and Gaskets: $5
Gallery
Ft. GMK Godspeed
Ft. GMK Striker, RAMA Striker, RAMA Kuro/Shiro
Ft. GMK Oblivion V2
Ft. ePTB Kuro/Shiro, S-Craft Artesian
Size Comparison
Ft. Raindrop 60%
Internals
Renders
Bullet
Monochrome
Raindrop (Blue Top also Available)
Cloud
Gilded Cloud
USB Location
Encoder Knob Options
Layouts
Contact
My Personal Discord: LANEWARE#0468
Email: support@laneware.xyz
Update Fequency, Terms & Conditions
We will update you on GB progress, manufacturing and shipping details at minium once every 2 weeks, or when important information becomes available.
You can expect to recieve your items before the advertised time, however uncontrollable circumstances may cause this time frame to be extended.
We aim to provide the highest quality Keyboards to our users. Our QA process should pick up any imperfections, however if a sub-par keyboard does manage to reach you, imperfections will be evaluated based on their location and size. The outcome of this evaluation may result in a full/partial replacement, full/partial refund or return depending on the severity of the imperfection.
Specific Pantone Colours and Switch Plate .stp files will be released after the GB.
« Last Edit: Sat, 04 December 2021, 22:16:32 by Laneware »
Offline Laneware
Re: [GB] MACRO-1 (Rotary Encoder, Gasket Mounted) by Laneware
« Reply #1 on: Fri, 05 March 2021, 00:24:47 »
If you are after any more specific Photos please let me know and I will update this comment
Real Color & Finish Sample:
The colors used for the MACRO-1 are the same that we used for the Raindrop 60%. See the below image, unedited, taken next to a window to show the color gradient
263991-0
« Last Edit: Sun, 07 March 2021, 18:34:58 by Laneware »
« Reply #2 on: Fri, 05 March 2021, 16:05:36 »
Approved :thumb:
Offline Chippy
  • sus chef
« Reply #3 on: Fri, 05 March 2021, 16:58:08 »
fancy macro pad good. knob good. gl with buy. I like seeing these over the top macro pads.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Laneware
« Reply #4 on: Fri, 05 March 2021, 19:03:15 »
Internal case details added to GB post
Offline totalemon
  • good morning :)
« Reply #5 on: Fri, 05 March 2021, 23:08:58 »
consider my interest checked :thumb:
Offline Ayeinw
« Reply #6 on: Sat, 06 March 2021, 01:23:42 »
I want all the colors :(
Offline Inversecrowd
« Reply #7 on: Sat, 06 March 2021, 04:12:00 »
Count me in, is there an option for blue top and bottom as a base kit?
Offline PotatoTM
« Reply #8 on: Sat, 06 March 2021, 07:17:47 »
il need to remind myself of this somehow, looks good / looking forward to it!
Offline jimmythetooth
« Reply #9 on: Sat, 06 March 2021, 09:47:19 »
I think you said you were considering usb pass-through. Did that make it in as an option?
Offline Laneware
« Reply #10 on: Sat, 06 March 2021, 15:18:35 »
Jump into the discord listed at the bottom of the post to be reminded when the GB is about to go live 😁
Offline Laneware
« Reply #11 on: Sat, 06 March 2021, 18:12:09 »
We decided not to persue this idea. It would have required re-prototyping both the case and PCB, we were to far along in the process to go back that far.
Offline CookieFlow
« Reply #12 on: Sat, 06 March 2021, 18:39:46 »
Been looking for a nice Numpad for a while and this one looks very appealing.
The price tag sounds pretty hefty, but if the quality is there I could justify it.
-Are the available colors not listed? Both base colors and extra top color?
-Will the knob work for volume control in macOS? (heard from other macropads that their volume knob didn't work in the latest Mac Os releases)
-Is there any way to make it wireless? I like my coiled cable for my keyboards, but don't really want another cable.
Offline Laneware
« Reply #13 on: Sat, 06 March 2021, 18:50:59 »
Be sure to keep an eye out for the build streams!
I realise that the colour options isn't super obvious, I will update the GB thread:
Base colors: Blue, White, Dark Grey
Top Colors: Blue, White, Dark Grey, Gold
The PCB will come with the most revent version of QMK installed. If the volume issue is not fixed by the delivery date, the current fix for volume control in Mac OS is quite easy and can be found here https://andywarburton.co.uk/fix-mac-osx-volume-keys-not-working-with-via-qmk/
The PCB is not bluetooth compatible.
I hope this answers all of your questions  :D
« Last Edit: Sun, 07 March 2021, 01:24:57 by Laneware »
Offline CookieFlow
« Reply #14 on: Sun, 07 March 2021, 07:01:47 »
Thanks for the info !
The 50$ extra Hotswap PCB, is it because it comes with the encoder pre-soldered also?
A bit sad about the top-color options, as the ones I would have liked the most are missing  (maroon/burgundy, a nice green, and like a copper or rose gold)
But I'll try to join for one still.
Offline Laneware
« Reply #15 on: Sun, 07 March 2021, 14:55:08 »
To upgrade the included PCB to hotswap is $20. To purchase an extra hotswap PCB is $50 and yes, it will include the encoder pre-soldered as well :)
« Last Edit: Sun, 07 March 2021, 15:14:51 by Laneware »
Offline damsenviet
« Reply #16 on: Sun, 07 March 2021, 15:14:14 »
Are these prototypes in Bullet and Monochrome? The photos make it look slightly blue but I'm more than 100% happy to have that color if that's the way the lighting affects it.
If you could provide annotations as to what colorway the prototypes are in that would be nice>
Offline Laneware
« Reply #17 on: Sun, 07 March 2021, 15:17:54 »
Yes, the prototypes are in bullet and monochrome :) The color options are the same as my previous board the Raindrop 60%, so will post some photos of the colors up close and un-edited :) Also stay posted for prototype photos and videos from our content creators Taeha Types, ByteSizedSeamus & Manoli Visuals, they will be much better at accuratly capturing the true look of the board than I am :D
« Last Edit: Sun, 07 March 2021, 15:28:50 by Laneware »
Offline CookieFlow
« Reply #18 on: Sun, 07 March 2021, 18:18:42 »
Alright thanks.
Will we be able to mix and match base and top color, or will it automatically come with a matching base and top color? (and thus forced into an extra top color)
Still hoping some extra top colors could be available. Really think a copper or nice rose gold could have worked well.
Offline Laneware
« Reply #19 on: Sun, 07 March 2021, 18:38:20 »
Alright thanks.
No worries,
You will be able to choose between either a top color of gold or the same color as the base
E.g Blue base and top OR Blue base and Gold top
All of the top colors will also be available to purchase individually.
E.g if you want a blue base with a white top, you will need to buy a base kit and an extra top. I hope this clears things up :)
Offline Laneware
« Reply #20 on: Wed, 10 March 2021, 17:03:33 »
There sure is!
Offline hiddensong
  • this too shall pass
« Reply #21 on: Fri, 12 March 2021, 03:18:35 »
I almost fell in love. That pricetag doe!! It's literally the price of an ano keeb. And with no bells and whistles? No bluetooth, no speakers, no OLED, no nada. Well there is a $1 EC11 rotary encoder. Really is a beautiful itsy bitsy tiny board. And I try to grab every macro/numpad I come across. This one, however is a hard pill bebe.
Offline Laneware
« Reply #22 on: Sat, 13 March 2021, 17:24:31 »
Hi, thankyou for the kind words, we are glad you love the design :D I understand your concerns. The "MACRO-1" is quite a large macro pad, the case weights in at ~700g, compare this to our "Raindrop 60%" weighing in at ~950g. The manufacturing cost of low quantity production items lays mostly outside the actual material cost, as such size isn't a huge factor in cost. This alongside the falling USD and sky rocketing raw material and electrical component costs is really hurting the custom keeb scene at the moment. You can see more discussion about this on the IC https://geekhack.org/index.php?topic=110130.msg2990781#msg2990781
We did poll this to the community, and with over 1000 responses, the overwhelming majority viewed the price point as fair. If you have any other questions please feel free to ask :)
Case Weights:
264417-0 264419-1
« Last Edit: Sat, 13 March 2021, 17:33:03 by Laneware »
Offline handmademedal
« Reply #23 on: Thu, 18 March 2021, 14:19:49 »
Can't wait to see more updates on this, good luck!
Offline Laneware
« Reply #24 on: Sun, 21 March 2021, 02:56:26 »
Thanks! Stay posted, we should have some stream content up in the coming days :D
Offline 24kpurehandsome
« Reply #25 on: Sun, 21 March 2021, 23:10:17 »
There aren't enough numpads in the mechmarket community. You think there is going to be a bluetooth version of this? My brother and I ran out of ports on our laptops.
Offline Domantas
« Reply #26 on: Mon, 22 March 2021, 09:46:34 »
whyyyyyy knob is on left. Unless it is sounthpaw, but it is weird for me still :(. Would have like two options
Offline bobtheguitar
« Reply #27 on: Mon, 22 March 2021, 15:44:15 »
I was thinking this looked great, but... this is a good point! Might still try to get one though.
Offline Laneware
« Reply #28 on: Wed, 24 March 2021, 03:43:55 »
Agreed! This one will be wired only :)
Offline Laneware
« Reply #29 on: Wed, 24 March 2021, 03:48:02 »
We had a similar query during the IC. To us, it felt more natural and ergonomic to have the knob on the left and control the encoder with your index and thumb whilst supporting your hand with your pinky and ring finger on the sides of the case. Looking at other projects, I would say at a rough estimate, 70% of macropads have followed this same logic. The feedback that we received from the testers is that the encoder feels comfortable and natural in its current position :)
Offline Harue
« Reply #30 on: Fri, 26 March 2021, 16:25:57 »
Tomorrow the day, Pog (replied accidently on IC instead of GB)
Offline Laneware
« Reply #31 on: Fri, 26 March 2021, 20:55:55 »
It sure is!
A little over 24 hrs until the GB is live! We have just just put the product pages up for you to have a look through and decide what you would like before the GB opens :D https://lanewareperipherals.com/collections/keyboard-cases
« Last Edit: Fri, 26 March 2021, 21:03:52 by Laneware »
Offline Dius
« Reply #32 on: Sat, 27 March 2021, 20:28:05 »
Did I miss this? Or did it not go live yet?
Edit: never mind I see 20 pst live - sorry
« Last Edit: Sat, 27 March 2021, 20:29:52 by Dius »
Offline Laneware
« Reply #33 on: Sat, 27 March 2021, 20:29:43 »
Not live yet! About 90mins remaining :)
« Reply #34 on: Sun, 28 March 2021, 13:04:52 »
I’m in! Have gone for the grey. Already wondering if I erred in not getting the gold top though...
Offline cigs_coffee
« Reply #35 on: Sun, 28 March 2021, 14:13:21 »
Haha, gone for the grey with gold top and black knob. It will look great :)
Ask for a change ;)
Offline Laneware
Re: [GB] MACRO-1 (200/500 Units Sold in First 24Hrs)
« Reply #36 on: Sun, 28 March 2021, 21:45:13 »
The support so far for this project has been amazing! We have sold approximatly 200/500 units in the first 24 hrs. Thankyou to everyone that has supported this project and provided feedback during the IC phase <3
Offline //gainsborough
  • MATRIXの日常
« Reply #37 on: Mon, 29 March 2021, 11:28:04 »
Is the prototype you made the grey color?  It almost has a hint of blue/green, which looks awesome.
« Reply #38 on: Mon, 29 March 2021, 13:11:38 »
Ask for a change ;)
Nice. Think I’m too aesthetically conservative to go for only the gold top. Maybe I should just order an extra... Certainly tempted. But the $$$...
« Last Edit: Tue, 30 March 2021, 04:03:20 by bobtheguitar »
Offline Laneware
« Reply #39 on: Mon, 29 March 2021, 17:00:09 »
Yes it is the grey color :) the true color is better represented in the first comment on this thread. The sheen and lighting effected the way the MACRO-1 prototype photos came out.
Offline Xury46
« Reply #40 on: Tue, 30 March 2021, 16:01:25 »
What a wild ride, the "launch party" on Discord was fun!
I'm so glad I got in on this, I can't wait to have this on my desk!
Offline Laneware
« Reply #41 on: Tue, 30 March 2021, 17:37:51 »
It was awesome! So cool to see such a turn up and hear everyones plans for their pad :D
« Reply #42 on: Thu, 01 April 2021, 04:09:35 »
Easy cop 👌
Offline treeleaf64
    • treeleaf64
« Reply #43 on: Thu, 01 April 2021, 12:09:35 »
Treeleaf like the knob yea yea
Everyone must pay the cat tax
Offline Laneware
« Reply #44 on: Fri, 02 April 2021, 07:58:36 »
Knob always good  yea yea
Offline Laneware
Re: [GB] MACRO-1 (300+/500 Units Sold in First Week)
« Reply #45 on: Mon, 05 April 2021, 00:56:58 »
Just over a week now after opening the GB and we have sold over 300/500 units. We have other projects in the works, so if you are afer a unit, please don't hold out, because at this stage we don't have plans to re-run the MACRO-1 in the near future!
Offline Kalliste
Re: [GB] MACRO-1 (Over 300/500 Units Sold in First Week)
« Reply #46 on: Fri, 09 April 2021, 01:37:53 »
Just picked mine up in all white, can't wait to see it on my desk along with the think 6.5 v2. I feel like they will go great together!   :D
Offline Laneware
« Reply #47 on: Sun, 11 April 2021, 05:37:43 »
Welcome aboard! I'd love to see a photo of the final builds sitting together :D
Offline Laneware
Re: [GB] MACRO-1 (Build Stream Live!)
« Reply #48 on: Fri, 16 April 2021, 20:48:58 »
Build stream is live! Link at the top of the thread :D
Offline Laneware
Re: [GB] MACRO-1 (2 Days left, 450/500 Units Sold!)
« Reply #49 on: Sun, 25 April 2021, 18:02:07 »
Only 2 days left to grab your MACRO-1! There are only 50 units remaining so be sure not to miss out  :thumb:
