Author Topic: [IC] TMT TAHO | DONE!  (Read 194653 times)
Offline ArkOberon
Re: [IC] Geekark TAHO | Deskmat Collab
« Reply #100 on: Thu, 28 October 2021, 15:13:10 »
My brother and I just stumbled upon this set. Hopefully, this goes for GB soon, because I'm def in. GL with the set.
Offline Serval
« Reply #101 on: Fri, 29 October 2021, 15:12:24 »
Then you should be excited. It will be in-stock this coming November.
They're just waiting for the sample before announcing an exact date.
Offline moonciti
« Reply #102 on: Thu, 06 January 2022, 09:45:49 »
Nice set! Well thought out concept and idea. I can see the 'taho' in the color combination.
One more thing, this is basically GMK Bread  :thumb:
- Totally condescending and unnecessary comment. It's like saying GMK minimal, hennessey, art, are basically GMK bow? GMK Banana Bread is basically GMK Tiramisu? GMK Red alert is  just a lighter GMK Red Honey?
Offline BloremBipsum
  • Yes, I am a Dumb Ass Boi
« Reply #103 on: Thu, 06 January 2022, 09:53:05 »
thanks im hungy now
Offline BloodyDayDream97
« Reply #104 on: Wed, 12 January 2022, 09:28:28 »
Love this!
Offline shendoo
  • *RAUGHS*
« Reply #105 on: Wed, 12 January 2022, 12:44:33 »
Really like the set !! Did you think about going with another manu? GA have been having a lot of issues from crooked stems to warped space bars to smudges.
good work!
Offline napostrophe
« Reply #106 on: Wed, 16 February 2022, 22:57:28 »
If there are still any intentions of running this set, I strongly request that Geekark be dropped as the manufacturer. Bunch of quality concerns are coming from other GBs like WoB involving smudging and legend fading, really bad warping, and cracked stems. Take this with a massive grain of salt, but it's possible Geekark may even be falsely advertising pad printing as dye-sub. It's absolutely abysmal.
I'd love to see this make it to GB, but with all of the issues with Geekark, it'll be hard pass from many people, myself included, if the manu doesn't change.
Offline doggo1dance
« Reply #107 on: Wed, 16 February 2022, 23:25:34 »
GA is big yikes now, better change to a different manu
Offline Serval
« Reply #108 on: Thu, 17 February 2022, 10:07:13 »
The thread hasn't been updated, but they're going with TMT (TomatoCaps) now. They also received the samples the last time I checked and a streamer, Xanniard, showcased it when he built a client's Tiramisuit.
Offline zionsped
    • Simbusped
Re: [IC] TMT TAHO | SAMPLES COLORS IN!
« Reply #109 on: Fri, 18 February 2022, 07:40:31 »
WOW!!! Thank you so much guys for your wonderful feedback!!! ❤❤❤
I apologize for the late update, been busy quite a while for double-triple checking all the kits and colors and doing some vendor works.
Hope you guys have a great day ahead!
« Last Edit: Fri, 18 February 2022, 08:09:37 by zionsped »
Offline AraAra
Re: [IC] TMT TAHO | SAMPLE COLORS IN!
« Reply #110 on: Fri, 13 May 2022, 18:38:53 »
Still excited to see this one. Any updates on production? Or a possible GB date?
Offline Eufrosino
« Reply #111 on: Mon, 16 May 2022, 16:01:19 »
Made an account just to say that I'm also interested! Looking forward to more updates :)
Offline ibcruzn408
« Reply #112 on: Thu, 12 January 2023, 02:31:40 »
any status? I really hope this pushes through.  =)
