Author Topic: [IC] Regarding GMK Orochi  (Read 23870 times)
Offline Snotburger
  • Snotburger#0001
« on: Sun, 07 March 2021, 03:01:37 »
INTEREST CHECK FORM
Introducing: GMK Orochi, a keycap set based on the Japanese legend of an eight-headed, eight-tailed serpent dragon.
A woodblock print by 月岡 芳年 was used as inspiration. It depicts Yamata-no-Orochi, the dragon, being slain by the banished god Susano-o.
Colours
GMK WS1: Alphas, Accent Legends, Mods Legends
GMK RO1: Accent
Pantone 7449 C: Mods, Alpha Legends
Kits
Keep in mind that these kits are subject to change, depending on feedback.
Base Kit
Alternate Alphas Kit
Novelties Kit
40% Kit
Spacebars Kit
Renders
RAMA U80
Nemui by Bachoo
Maja by Vulcan
Vendors
OCE: SwitchKeys
CA: DESK[H]ERO
SEA: iLumbkb
UK: proto[Typist]
KO: Swagkeys
US: TBD
EU: TBD
To-do list
- Get community feedback, modify kits accordingly
- Revamp Novelties
- Decide other products (deskmats, RAMA, cable?)
- Establish vendors :thumb:
- Get pricing
- Make it to GB ;D
Signature
If you're interested and want to support the set, plug this into your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=111577.0][img width=360 height=100]https://i.imgur.com/lHUHHpp.png[/img][/url]
INTEREST CHECK FORM
TY to: Stick for being cool :thumb:, and the guys over at Keycap Designers Discord and SwitchKeys Discord
« Last Edit: Thu, 15 April 2021, 04:32:57 by Snotburger »
Offline Stickk
Re: [IC] GMK Orochi
« Reply #1 on: Sun, 07 March 2021, 03:02:18 »
Nice set, who's Stick
Offline Snotburger
  • Snotburger#0001
Re: [IC] GMK Orochi
« Reply #2 on: Sun, 07 March 2021, 03:02:47 »
16 March 2021
- Added proto[Typist] as Vendor for UK
- Added Swagkeys as Vendor for KO
15 March 2021
- Added iLumbkb as Vendor for SEA
Happy to have iLumbkb as our vendor for SEA! Also novelties update coming soon (TM)
12 March 2021
- Minor changes to base kit
- Added DeskHero as Vendor for CA
Just some minor changes, glad to have DeskHero as a vendor as well :thumb:
10 March 2021
Big (and hopefully last) update on kitting and vendors:
- Removed GMK CR as Alpha Legends Colour
- Changed Alpha Legends Colour to Pantone 7449 C
- Removed one of the novelties
- Added Hiragana Sublegends to base kit
- Added 40s Kit
- Updated Spacebars Kit
- Added Alternate Alphas Kit
- Added SwitchKeys as vendor for OCE
Happy to take on SwitchKeys as a vendor for the OCE region, they've been helping out with the set as well, I can't thank them enough.
Took in some of the feedback like swapping the alpha legend colour with the mod colour to save cost, and adding hiragana sublegends.
I also added a 40s and an Alternate Alphas Kit with just the mod colour, and I'm eager to get feedback on those as well.
Again, appreciation for any comments, keep them coming :thumb:
8 March 2021
Hey guys, a quick update to the IC:
- Moved B from Spacebars to Base
- Changed Print, Scroll and Pause to mod colours
- Removed 1.75u Backspace
- Changed R3 pipe to alpha colors
- Removed mod colour R1 pipe
- Added mod colour arrows
- Added 1.5u Supers
- Added F13 Key
Just did these because I wanted to iron out the kitting errors I made so that I can focus more on collabs, novelties etc.
Thanks to all of the suggestions and support, whether praise or criticism, everything is appreciated!
I didn't really make it clear but if you're down for a collab just DM me on Discord: Snotburger#0001.
Was the captcha that I got for this post lol
« Last Edit: Tue, 16 March 2021, 01:10:21 by Snotburger »
Offline SirTimmyTimbit
Re: [IC] GMK Orochi
« Reply #3 on: Sun, 07 March 2021, 03:15:31 »
wow! So beautiful 😍
Love the Novelties! Great work!
Offline bigern302
Re: [IC] GMK Orochi
« Reply #4 on: Sun, 07 March 2021, 03:21:50 »
It’s less good plum.
Offline AJPlus
Re: [IC] GMK Orochi
« Reply #5 on: Sun, 07 March 2021, 03:33:08 »
These are nice always a fan of Japanese art inspired caps
Offline JumpStream
Re: [IC] GMK Orochi
« Reply #6 on: Sun, 07 March 2021, 05:16:20 »
I'm a sucker for anything Japanese, glwic
Sent from my IN2023 using Tapatalk
Offline Izeri
Re: [IC] GMK Orochi
« Reply #7 on: Sun, 07 March 2021, 05:33:06 »
Almost based Shinobu poster, you haven't included non accented arrows anywhere and Print|Scroll|Pause is wrong color. GLWIC!
Offline pupper125
Re: [IC] GMK Orochi
« Reply #8 on: Sun, 07 March 2021, 06:05:47 »
Okay so a few things to consider here regarding kitting:
-First off you say that 40s will not be supported, but in your base kit you have a 1.75u backspace, this is a key used in 40s support.
-A 1.5u super key would be appreciated for 65 layouts that use a 1.5u super.
-Accent arrows are forced, leaving you with no option for mod arrows, but every other accent key has the mod equivalent.
-R3 pipe being in mod is a weird choice, its typically an alpha key.
-Consider moving B into base for easier alice compat, and to reduce the number of colours in your spacebar kit.
-R1 1u pipe doesnt need to be mod either, its standard to do it in alpha.
Regarding IC Formatting, you currently have the IC Form in 2 locations, once at the very top, and once at the very bottom, which looks a little odd, not sure if that's intentional. Its also typically standard practice to credit the designers behind the boards that you use in renders, just to show appreciation for their work. Hopefully some of this comes in handy when working on this set, because it definitely has potential!
« Last Edit: Sun, 07 March 2021, 06:14:27 by pupper125 »
Offline TyPo.mk
Re: [IC] GMK Orochi
« Reply #9 on: Sun, 07 March 2021, 06:41:25 »
While I agree with the above points, I think pupper is nitpicking your renders a bit so I wouldn’t worry about it too much. I will second the second B in base kit because it will make your bars kit appreciably cheaper while not making your base price change much.
Also would it be possible to get the dragon head novelty or a version of it onto a key that isn’t ISO enter? It is kind of a shame that imo the coolest novelty and the one that represents the theme the best is in ISO only...
Offline nvh2092
Re: [IC] GMK Orochi
« Reply #10 on: Sun, 07 March 2021, 06:43:00 »
Some kitting errors need to be fixed:
- Print, Scroll and Pause should be in mod color.
- R3 1u "\|" key should be in alpha color.
- Lack of mod color arrow keys.
- You've already had a 1.75u backspace in base kit, if you add a R3 1.25u tab key plus a R3 1.5u enter key, you can cover the majority of 40s layouts.
- And a F13 in base please.
Offline chat and team
Re: [IC] GMK Orochi
« Reply #11 on: Sun, 07 March 2021, 12:05:26 »
weeb set ==
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Vadurr
  • Valar Morghulis
Re: [IC] GMK Orochi
« Reply #12 on: Sun, 07 March 2021, 12:12:56 »
I hate to be that guy, but NE sub legends avail?
Offline Kinesiologist
Re: [IC] GMK Orochi
« Reply #13 on: Sun, 07 March 2021, 12:26:09 »
Looks good, can you please add the following into the base kit?
mod-colored: F13, Print, Scroll, Pause, Arrows
Offline Auracity
Re: [IC] GMK Orochi
« Reply #14 on: Sun, 07 March 2021, 13:47:13 »
r1 1u mod pipe gg
Offline LeCado
Re: [IC] GMK Orochi
« Reply #15 on: Sun, 07 March 2021, 13:50:32 »
Looks very cool! The colour scheme is nice and the novelties are really cool.
Offline Snotburger
  • Snotburger#0001
Re: [IC] GMK Orochi - Minor Updates to Kits
« Reply #16 on: Sun, 07 March 2021, 14:18:13 »
8 March 2021
- Added 1.5u Supers
- Added F13 Key
« Reply #17 on: Sun, 07 March 2021, 14:21:37 »
Appreciate all the wonderful additions you have made to the base kit. Love the colors and the theme.
« Last Edit: Sun, 07 March 2021, 16:13:56 by Kinesiologist »
Offline nvh2092
« Reply #18 on: Sun, 07 March 2021, 14:23:45 »
8 March 2021
- Added 1.5u Supers
- Added F13 Key
I think that follow the color rules in the F-row, F13 should be in mod color. Also, have you tried mod color for alpha legends? This will reduce to 3 colors and surely will reduce the final price of the base kit.
Offline Snotburger
  • Snotburger#0001
« Reply #19 on: Sun, 07 March 2021, 14:41:10 »
Whoops, that's my bad. It should be fixed now.
Offline Rpmorrison10
« Reply #20 on: Sun, 07 March 2021, 16:08:23 »
instead of removing the 1.75 backspace, why don't you just add the other 2 keys (r3 1.25 tab, and r3 1.5 enter) to help out a portion of the community? Those 3 keys might raise your cost by $1 but will get more people to buy.
Offline psxndc
« Reply #21 on: Sun, 07 March 2021, 23:20:36 »
40s will not be supported.
I say this not to be "wah wah *crying*", you're certainly entitled to run this how you want. But if I didn't say anything, you'd never have the feedback: upfront lack of 40s support is why I'm not going to get the set.
GLWIC!
Ortho. Always.
Offline gex
« Reply #22 on: Mon, 08 March 2021, 10:13:30 »
i'd buy this with with an ortho kit in an instant
Offline Snotburger
  • Snotburger#0001
Re: [IC] GMK Orochi - New Kits and Vendor!
« Reply #23 on: Tue, 09 March 2021, 23:39:55 »
- Added 40s Kit
« Last Edit: Tue, 09 March 2021, 23:41:42 by Snotburger »
Offline Snotburger
  • Snotburger#0001
Re: [IC] GMK Orochi - New CA Vendor
« Reply #24 on: Fri, 12 March 2021, 05:05:25 »
12 March 2021
Offline vladimir108
« Reply #25 on: Fri, 12 March 2021, 13:23:13 »
Hello, in thread "GMK Beta" was published update of basic Latin/Hiragana GMK keycaps from Zambumon:
https://geekhack.org/index.php?topic=108290.msg3009840#msg3009840
Zambumon_GMK_Hiragana_Latin_RFC.pdf  https://geekhack.org/index.php?action=dlattach;topic=108290.0;attach=261369
Offline pntm2006
« Reply #26 on: Sat, 13 March 2021, 02:00:18 »
My input would be to make the alternate alpha kit the base kit and the white alphas the alternate. Give it a darker red esc, enter and spacebar and it would look amazing in my opinion.
Or please provide an option of the base kit with the alternate alphas if you don't want to change anything from the current base kit.
Offline tunb
« Reply #27 on: Sat, 13 March 2021, 09:13:08 »
look amazing
Offline CodeMayhem
« Reply #28 on: Sat, 13 March 2021, 18:40:23 »
I don't plan on buying for the record but what is that 40s kit? no 1u r2 backspace and no 1u tab of either row for ortho support, despite having the lower raise and 2u space-bar?
edit: wait so just the lower not the raise too.
« Last Edit: Sat, 13 March 2021, 18:43:18 by CodeMayhem »
« Reply #29 on: Sat, 13 March 2021, 20:08:06 »
Does the Alternate Alphas Kit have support to cover the function row keys too? F1-F4, F9-F12
Offline Snotburger
  • Snotburger#0001
« Reply #30 on: Mon, 15 March 2021, 01:09:47 »
15 March 2021
Offline Snotburger
  • Snotburger#0001
Re: [IC] GMK Orochi - New Vendors
« Reply #31 on: Tue, 16 March 2021, 01:09:30 »
16 March 2021
Offline Snotburger
  • Snotburger#0001
« Reply #32 on: Thu, 15 April 2021, 04:32:40 »
I'll keep this short, but basically I'm going to be taking a break from this project. I don't know how long it will be for, or if it will be temporary at all. For the record, I did have other changes planned before group buy such as switching from Pantone to RAL, updating novelties, redoing the 40s kit, adding other vendors and others.
I'm leaving entirely because of personal reasons. To be clear, I never expected to make it this far to begin with and I would consider this to be a great learning experience.
Thank you
Offline YoungTerror
Re: [IC] Regarding GMK Orochi
« Reply #33 on: Thu, 15 April 2021, 13:06:00 »
GL and hope to see you back soon.
Offline Vadurr
  • Valar Morghulis
« Reply #34 on: Thu, 15 April 2021, 13:45:04 »
Hope all is well! Lookin forward to your return.
Offline chonkbabu
« Reply #35 on: Fri, 03 December 2021, 07:23:07 »
Hey man just stumbled upon this set and fell in love with it, hope to see you back soon! Best of luck and hope all is well.
Offline keebsalad
« Reply #36 on: Sun, 23 January 2022, 08:57:49 »
I'm not a fan of purple sets, but I absolutely love this one. looking forward for your comeback too! you did such a great job!
