Author Topic: Case compatibility  (Read 1476 times)
Offline NilKeebs
Case compatibility
« on: Mon, 15 March 2021, 13:40:20 »
Hi, I'm wondering if there is a resource either here at GK or somewhere else where I can get full info as to whether a Certain PCB is compatible with a certain case regardless of the brand.
For example, would a KBD 5° 60% case only be compatible with KBD PCB's or can I use other branded PCB's.
  :D
Offline Leslieann
Re: Case compatibility
« Reply #1 on: Mon, 15 March 2021, 21:30:51 »
Generally, no.
Pretty much every pcb/case is different there are a handfull TKls that are similar but generally consider every pcb/case to be a matched set.
60% is the one exception, anything Tofu/Poker/GH60/DZ60 based will fit that case (pretty much any 60% will fit).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
