Author Topic: [IC] GMK Shashin | GB 1st of July!  (Read 190460 times)
Offline S3LQ
  • Designer and keyboard enthusiast
Re: [IC] GMK Shashin
« Reply #100 on: Sun, 21 March 2021, 15:53:52 »
Looking good! Are alpha colors WS1/N9 same as alphas in GMK Evil Dolch? I'm wondering if I could mix NorDeUk kit from Evil Dolch with this one?
Correct! Same colors  :thumb:
Offline HelloThisIsDog
« Reply #101 on: Sun, 21 March 2021, 23:07:31 »
Just for context, are the mods the same colors as GMK WoB?
Offline S3LQ
« Reply #102 on: Mon, 22 March 2021, 02:10:40 »
Yes, they are. The mods are CR base with WS1 Legends, the alphas are N9 base with WS1 Legends and the accent is WS1 base with CR legends
« Reply #103 on: Mon, 22 March 2021, 12:42:17 »
That’s perfect thanks! Definitely getting this
Offline Steve Laroo
« Reply #104 on: Mon, 22 March 2021, 22:13:12 »
What are the odds we could get 3 (R3 1.25 tab, R3 1.5u enter/fn, R2 1.75 BS) 40s keys added to base that would cover a healthy portion of the community?
Offline shortdog6
    • Casper Keys
« Reply #105 on: Mon, 22 March 2021, 22:25:43 »
Love the set, but honestly the novelties are almost exactly like GMK Film's from November.
https://geekhack.org/index.php?topic=109791.msg2983296#msg2983296
Could cause some friction.
But again, love the set! Super clean.
Offline santela
« Reply #106 on: Mon, 22 March 2021, 23:17:10 »
Not sure if this has been asked before, but the novelty for the enter key, what does the 1,2,3 supposed to be? I would love an aperture ring themed enter key.
Hey! The 1,2,3 novelty for the R3 Ansi Enter is supposed to symbolize the exposure indicator found in most camera hud's!
Ahh, okay, exposure compensation, right.
« Reply #107 on: Tue, 23 March 2021, 00:31:29 »
Hmm, on the other hand these images are similar because they are ubiquitous though - they reference a set of icons so commonplace that any argument of copying might as well be moot.
Offline HappyB0T
  • I'm a Piggie
« Reply #108 on: Tue, 23 March 2021, 01:16:42 »
woah where's this hustle by you guys for those non licensed anime/video game sets?
i don't often see those keycap designers thanking the animators or publishers for those.....
I spit my drink after reading.
What a fun IC to look at. I really appreciate all of the work you put into this IC. Love the theme - sub legends look great!
« Last Edit: Tue, 23 March 2021, 01:18:35 by HappyB0T »
Offline shortdog6
    • Casper Keys
« Reply #109 on: Tue, 23 March 2021, 13:53:58 »
Yeah I agree. I doubt it was copying. But there has to be a line where you consider changing if someone has already displayed your idea a while ago.
Offline nvh2092
Re: [IC] GMK Shashin | Novelty Update + Deskmat
« Reply #110 on: Tue, 23 March 2021, 17:28:28 »
ISO novelties look like the best in the kit, also, can we have these 2 as R2 - R3 for 65/75s layouts (for the right macro column)?
« Last Edit: Tue, 23 March 2021, 17:35:54 by nvh2092 »
Offline Alessio
    • YT Channel
« Reply #111 on: Tue, 23 March 2021, 19:11:17 »
i really like this set, but why in the **** is it weeb
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #112 on: Tue, 23 March 2021, 20:15:48 »
« Last Edit: Wed, 24 March 2021, 00:46:08 by loop | esc lab »
« Reply #113 on: Tue, 23 March 2021, 20:54:37 »
I feel similarly and I'm glad they put in a Latin base set and not separate alphas you have to pay extra for.
Offline sub0001
« Reply #114 on: Tue, 23 March 2021, 21:29:16 »
Definitely in for a set, but would be great to see 1u novs that fill the right column of a 65%.
Offline Nukz
  • ig: nukzak
« Reply #115 on: Wed, 24 March 2021, 02:26:19 »
this is officially my favourite set, this looks so so good maaan :eek:
Offline MajorZoT
« Reply #116 on: Wed, 24 March 2021, 07:47:49 »
This is what it could look like (except for the alpha legends that are L9):
https://imgur.com/a/wdDi2n5
Offline S3LQ
« Reply #117 on: Wed, 24 March 2021, 11:39:23 »
If that's N9 Alphas and CR Mods you are correct!  :thumb:
Offline nvh2092
« Reply #118 on: Wed, 24 March 2021, 11:45:32 »
I joined Evil Dolch so I'm gonna join this as well just to mix the 2 sets to make a third set called Weird Dolch. Please keep it as 1 1 2 3 4 4.
Offline S3LQ
« Reply #119 on: Thu, 25 March 2021, 02:01:23 »
Will be keeping it 1 1 2 3 4 4.
Offline S3LQ
« Reply #120 on: Fri, 26 March 2021, 13:53:01 »
this IC looks very promising. will def jump in.
Appreciate the support!  :thumb:
Re: [IC] GMK Shashin | Kitting update + New renders!
« Reply #121 on: Fri, 26 March 2021, 19:43:31 »
Big sad on the Latin base turned to Latin alphas. Was this a GMK pricing/kitting issue?
Offline andtar2
« Reply #122 on: Sat, 27 March 2021, 02:27:10 »
Same here :( What happened here? Everything looked good with two base kits
Offline HappyB0T
  • I'm a Piggie
« Reply #123 on: Sat, 27 March 2021, 18:00:13 »
+1
It will be $45 or more for the alphas solo on top of base.
Offline woyaodapian
« Reply #124 on: Sat, 27 March 2021, 22:03:52 »
Please keep the latin base set or offer both.
« Reply #125 on: Sat, 27 March 2021, 22:12:08 »
Hope there is enough response for OP to reconsider adding Latin Base back into the options.
Offline S3LQ
« Reply #126 on: Sun, 28 March 2021, 09:37:00 »
+1
I appreciate the support on the Latin base kit. The reasoning why this was replaced with the Latin alpha kit as for now, is because I and the vendors rather wanted to reach a higher MOQ on one of the base kits. That way we can try to adjust the pricing and make it more pleasing for you guys. Also ranging from feedback from the google form, the Hiragana Base was leading with over 20% in votes, so that was an easy choice to decide which base to keep.
This being said, it is very hard to please everyone, but I'm trying my best. Once we submit quotes to GMK, we will throw in all kits, to see what we can do. The Latin base isn't gone yet, it's still a possibility that we might run with it, but this will all be taken into consideration! Thanks
« Reply #127 on: Sun, 28 March 2021, 12:53:41 »
Thanks for your reply and effort! As someone whose first language is an alphabet that has never been offered by GMK or any other premium manufacturer, I feel somewhat strongly about using keycaps with legends from languages that I do not speak. I recognize that many people appreciate "exotic" sublegends regardless of whether they understand that language for practical purpose, but I think it is also ethical to reflect on how you're using someone else's language as a way to fill an aesthetic space. Not trying to specifically call out anyone else's preferences as problematic, sorry that is not my intention at all. I just wanted to share the reason for why I am asking for a Latin base, others asking for a Latin base may of course have different reasons.
Offline S3LQ
« Reply #128 on: Mon, 29 March 2021, 09:11:35 »
I can understand. We will still offer Latin alphas, but maybe not as a base kit. But all the feedback regarding this update will be taken into consideration!
Offline CookieFlow
« Reply #129 on: Mon, 29 March 2021, 09:34:29 »
Personally I think the Hiragana sub legends in base kit make a lot of sense considering so many camera brands are from Japan (and the name of the set, mats etc).
Also a big fan of higher MOQ sets, which makes them more affordable and hard to do when running 2 base kits. I understand running 2 base kits, if the IC results are close to 50/50, but over 20% lead for Hiragana is fairly significant.
Hoping we get a Rama soon  :thumb:
Offline snaiL678
« Reply #130 on: Mon, 29 March 2021, 15:32:09 »
nice set, what is the iso hhkb keyboard in the first picture?
Offline jonnybueno
« Reply #131 on: Mon, 29 March 2021, 15:45:59 »
Sad to see latin base go... I like this set but unfortunately am out if without the latin base as im not willing to pay extra for the alphas.
Offline S3LQ
Re: [IC] GMK Shashin | Vendors!
« Reply #132 on: Tue, 30 March 2021, 19:41:40 »
I appreciate your understanding! This is a big part of why I chose to run with subs!
Regarding Rama, there will most definitely be a Shashin x Rama collab :D
Hey, thanks! The hhkb keyboard in the header picture would be the Rama M60-A
I understand your decision!
Offline S3LQ
« Reply #133 on: Wed, 31 March 2021, 22:41:14 »
Offline lush_bunny
« Reply #134 on: Wed, 31 March 2021, 23:05:00 »
ilumkb as SEA vendor? aww yis.
Offline sub0001
« Reply #135 on: Wed, 31 March 2021, 23:42:49 »
Thank you for adding 65%-focused novelties! Really hoping for a RAMA collab  :thumb:
Offline S3LQ
« Reply #136 on: Fri, 02 April 2021, 07:40:24 »
Will try to sort that out for you!  :cool:
Offline azzipa
Re: [IC] GMK Shashin | GB 1st of May!
« Reply #137 on: Sat, 03 April 2021, 18:39:14 »
nice looking set, and i think the japanese tie-in makes sense. classic names like canon, nikon, pentax, contax, ricoh, olympus, fuji, and on and on. glwic!
Offline S3LQ
« Reply #138 on: Mon, 05 April 2021, 05:15:41 »
Offline S3LQ
« Reply #139 on: Thu, 08 April 2021, 09:14:23 »
GMK Quote has been submitted! Once we receive it we'll work on pricing!
Offline AlfredK
« Reply #140 on: Fri, 09 April 2021, 05:58:31 »
Looks Great S3LQ, All the drama and complaint aside. it's safe to say you nailed the design!
« Reply #141 on: Fri, 09 April 2021, 19:27:59 »
Am I totally blind, or is the list of vendors not posted?
I'm blind  ;D
« Last Edit: Fri, 09 April 2021, 19:29:41 by byfuryattheheart »
Offline S3LQ
« Reply #142 on: Sat, 10 April 2021, 17:45:26 »
Appreciate the support Alfred!
Offline Biskwit157
« Reply #143 on: Sat, 10 April 2021, 18:14:48 »
I wish the Latin kit included mods, I would have bought both kits. Great job can't wait to cop
Offline zionsped
    • Simbusped
« Reply #144 on: Thu, 15 April 2021, 21:08:36 »
Will definitely get one! GLWIC!
Offline S3LQ
« Reply #145 on: Sun, 18 April 2021, 06:38:34 »
Appreciate it!
Offline HappyB0T
  • I'm a Piggie
« Reply #146 on: Sun, 18 April 2021, 21:26:57 »
Really cool looking set - Good Luck with your Group Buy!
Offline n1KKei
« Reply #147 on: Wed, 21 April 2021, 02:37:24 »
The colorway is great and the novelties look surprisingly good, BUT! with this set those tiny tiny Hiragana sub-legends just doesn't work at all imho, I don't get it, why make them so small? I'd go full Hiragana (no sub legends) base kit and Alphas base kit and everybody is happy, problem solved, right?
Offline S3LQ
« Reply #148 on: Wed, 21 April 2021, 15:34:19 »
Hey, thanks for your reply! Wish the decision was this easy. We are still waiting on a reply for the GMK quote, once that arrives we will see what the bet price/moq options will be. Once that's settled we will decide upon what kits to bring on to the GB!
Offline S3LQ
« Reply #149 on: Sun, 25 April 2021, 08:12:04 »
Small update!
Pricing is a bit delayed, sorry for that, but waiting on a quote reply from GMK! Once we receive that, we will do everything we can to make the pricing as pleasing as possible!
Collabs have also been picked up for the set, and I can’t wait to announce them! See you guys 1st of May!
