Author Topic: QMK config problem or sticky key?  (Read 2345 times)
Offline slowtyping
« on: Wed, 17 March 2021, 04:28:13 »
I have had an Atreus62 with Gateron Browns for over four years as my daily driver. I like it a lot. I do however have a problem with one of my modifier keys apparently not returning to normal after being hit. It doesn't seem to happen every time, just under certain circumstances that I can't pinpoint. I've included my entire keymap.c file. The modifier is the MO(_NUM). I thought all I needed to do was use KC_TRNS in this position in all the other layers, but maybe it's not enough?
As an example of what happens, sometimes I find I have used MO(_NUM) and the volume control is displayed on screen, suggesting that KC_VOLU is active (that is located in the NUM layer where KC_INS is on my base layer).
I guess it could be a hardware problem like a sticky key, but I thought I'd ask here for pointers on QMK before I rip the keyboard apart and clean it. Any help much appreciated!
ST
Code: [Select]
const uint16_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
  [_DEFAULT] = { /* base layer */
    { KC_ESC,   LCTL(KC_C),    LCTL(KC_X),    LCTL(KC_V),    LCTL(KC_F),    LCTL(KC_Z),    KC_TRNS,  S(KC_QUOT),    KC_SLSH,    KC_LPRN,    KC_RPRN,    KC_MINS,    KC_EQL },
    { KC_TAB,  KC_Q,    KC_W,    KC_D,    KC_F,    KC_K,    KC_TRNS,  KC_J,    KC_U,    KC_R,    KC_L,    KC_QUOT,    KC_SCLN },
    { KC_LCTL,   KC_A,    KC_S,    KC_E,   KC_T,    KC_G,    KC_TRNS,  KC_Y,    KC_N,    KC_I,    KC_O,   KC_H, KC_LCTL },
    { KC_LSFT,  KC_Z,    KC_X,    KC_C,    KC_V,    KC_B,    KC_BSPC,  KC_P,    KC_M,    KC_COMM, KC_DOT,  KC_QUES, KC_RSFT },
    { KC_TRNS,  KC_LGUI, KC_INS, KC_LALT,  MO(_NAV), KC_DELT, KC_ENT,   KC_SPC,  MO(_NUM),  KC_LALT, TG(_NUM), KC_CAPS, KC_APP }
  [_NAV] = {
    { TO(_DEFAULT),  KC_F1,   KC_F2,   KC_F3,   KC_F4,   KC_F5,   KC_TRNS,  KC_F6,   KC_F7,   KC_F8,   KC_F9,   KC_F10,  KC_F11  },
    { KC_TRNS,       KC_F12, F(5), F(8), F(6), KC_TRNS, KC_TRNS,  KC_TRNS,  KC_HOME, KC_UP,   KC_END, KC_LBRC, KC_RBRC },
    { KC_LCTL,       KC_TRNS, F(3), KC_TRNS, F(4), KC_TRNS, KC_TRNS,  KC_TRNS, KC_LEFT, KC_DOWN, KC_RGHT, KC_TRNS, KC_LCTL },
    { KC_LSFT,    KC_TRNS, F(1), F(7), F(2), KC_TRNS, KC_TRNS,  LALT(KC_ENT), KC_PGUP, KC_DOWN, KC_PGDN, KC_TRNS, KC_TRNS },
    { TO(_RESET),    KC_LGUI, KC_TRNS, KC_LALT, KC_TRNS, KC_TRNS, KC_TRNS,  KC_TRNS, KC_TRNS, KC_TRNS, KC_TRNS, KC_TRNS }
  [_NUM] = {
    { KC_ESC,   KC_EXLM,    KC_AT,    KC_HASH,    KC_DLR,    KC_PERC,    KC_TRNS,  KC_AMPERSAND,    KC_7,    KC_8,    KC_9,    KC_SLSH,    KC_RPRN },
    { KC_TAB,  KC_TILD,    KC_GRV,    KC_SCLN,    KC_COLN,    KC_UNDS,    KC_TRNS,  KC_CIRC,    KC_4,    KC_5,    KC_6,    KC_ASTR, KC_TRNS },
    { KC_LCTL,   KC_LCBR,    KC_RCBR,    KC_LBRC,    KC_RBRC,    KC_BSLS,    KC_TRNS,  KC_PIPE,    KC_1,    KC_2,    KC_3,    KC_MINS, KC_LCTL },
    { KC_LSFT,  KC_TRNS,    KC_TRNS,    KC_TRNS,    KC_TRNS,    KC_TRNS ,    KC_BSPC,  KC_SLSH,    KC_0,    KC_TRNS, KC_TRNS,  KC_TRNS, KC_TRNS },
    { KC_VOLD,  KC_MUTE, KC_VOLU, KC_MPLY,  KC_MPRV, KC_MNXT, KC_ENT,   KC_SPC,  KC_TRNS,  KC_TRNS, KC_TRNS, KC_TRNS, KC_TRNS }
  [_RESET] = {
    { TO(_DEFAULT),  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  ,  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO   },
    { F(9)  ,       KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  ,  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO   },
    { F(10)  ,       KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  ,  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO   },
    { KC_NO  ,       KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  ,  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO   },
    { KC_NO  ,       KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  ,  KC_NO  , KC_NO  , KC_NO  , KC_NO  , KC_NO  , RESET }
« Last Edit: Sun, 21 March 2021, 03:01:23 by slowtyping »
